Seatbelt Light Issue - Safety Inspection
Discussion in '1st Gen. Tacomas (1995-2004)' started by LarryJ1959, Apr 29, 2024.
  1. Apr 29, 2024 at 5:00 PM
    LarryJ1959
    LarryJ1959 [OP] Member
    I've got a '97 Tacoma with a sporadic safety belt light issue that will cause me to fail an upcoming safety inspection. Sometimes the seatbelt light won't light up when starting the vehicle, other times it works fine. I need to resolve this issue before a safety inspection in 2 months. What's the common cause of this. Is it in the seatbelt connection or somewhere else. I don't know how to go about diagnosing the problem.
  2. Apr 30, 2024 at 6:30 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Jeez
    In TX, for safety inspection, the most stringent requirement is that bright lights (and cluster indicator) both work
    Air bag/check engine lights not a requirement
    state u in?
  3. May 1, 2024 at 12:04 PM
    Skulking
    Skulking Well-Known Member
    San Jose, CA
    1998 Xtra Cab v6 4x4 Manual
    Do you mean that it doesn't always come on with all of the other dash lights when you start the car? Does it always work correctly once the car is running, or is it also intermittent when the car is running?
