Seatbelt not on chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kharth, Aug 25, 2019.
  1. Aug 25, 2019 at 5:03 PM
    Kharth
    Kharth [OP] Well-Known Member
    Tim
    West Texas
    '13 Tacoma 135k miles
    Leer Cap, black barrel tire valve caps, Steelers sticker, Air Freshener
    How's this work? Is it a sensor in the buckle itself or it tells if the belts stretched out or what? And if I buy a buckle from a junkyard and plug it in will it shut up?
  2. Aug 25, 2019 at 5:28 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    Mine does that when I load the passenger side front up with groceries. I tried stretching it out to stop the dadgum beeping but it would not stop until I actually buckled it in. I just ignore it now. It eventually stops. My ford had a sequence of things to do to turn that off. Don't know about the toyos though.
  3. Aug 25, 2019 at 5:31 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Thankful I have year where I can disable it myself.
  4. Aug 25, 2019 at 5:38 PM
    Kharth
    Tim
    West Texas
    Yeah I've had a cooler on passenger seat set it off. I had to buckle it in. I wanted to just get one from a junkyard so it don't beep. Also I'm talking driver side. That's the one I want to shut up
    Skyway likes this.
  5. Aug 25, 2019 at 5:40 PM
    FishingPups
    Barry
    Drivers side? You don't wear your seat belt? Or am I missing something here...
    PzTank likes this.
  6. Aug 25, 2019 at 5:50 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    On some roads, like rough, slow driving trails, I don't wear it either. Always use it highway/around town. Mine only lasts 25-30 secs then quits anyway.
    Jeff
    Don't think the junkyard approach will work though.
    FishingPups[QUOTED] likes this.
  7. Aug 25, 2019 at 5:53 PM
    Thompson486
    Thompson486 Well-Known Member
    Sherwood Park, AB
    2022 AC Off-Road Blue Crush
    I had the dealer disable the chime on my truck. Told them I’m often in and out driving at low speeds for work :p
  8. Aug 25, 2019 at 5:55 PM
    FishingPups
    Barry
    That makes sense.
  9. Aug 25, 2019 at 5:56 PM
    ShouldItBeDoingThat
    ShouldItBeDoingThat Well-Known Member
    Unclean
    The West
    18' MGM Tacoma TRD Sport OVTuned
    Eibach pro truck kit + Icon 1.5" progressive AAL 255/75/17 Continental Terrain Contact AT LED interior light kit. Derp: wheels, grill
    I used Techstream and it worked but you have to get Techstream and make it work first.
  10. Aug 25, 2019 at 6:03 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Try this experiment
    Most of us can sprint at 9 mph. A few faster. So, run as fast as you can into a tree. It’s only 9 mph so it won’t hurt.
    eherlihy, Tullie D and FishingPups like this.
  11. Aug 25, 2019 at 6:05 PM
    FishingPups
    Barry
    Physics 101
    Cudgel[QUOTED] likes this.
  12. Aug 25, 2019 at 6:08 PM
    FishingPups
    Barry
    Its not the fall that will kill you, it is the sudden abrupt stop at the end.
  13. Aug 26, 2019 at 5:07 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Techstream will turn it off, as well as a buckle end.
  14. Aug 26, 2019 at 7:43 AM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    This this what you need? Have to do it for both sides & if you disconnect the battery.
    Ignition ON
    Trip reset to ODO
    Ignition OFF
    Ignition ON
    Press & hold trip reset for 12s
    Hold trip reset, fasten seat belt you want to disable
    Release trip reset
    Press trip reset to b-off
    Total PIA, takes me a couple tries even after having done it a couple dozen times.
  15. Aug 26, 2019 at 7:58 AM
    08TacoTrD
    08 TRD Offroad
    Doesn't work for later models. A '13 like subs has needs the techstream.
  16. Aug 26, 2019 at 8:14 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    There is a connection you can unplug under the seat. Worked for me
    Skyway and 70m4h4wk like this.
  17. Aug 26, 2019 at 8:28 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
    Sorry, off the subject, where can I learn more about Techstream?
    What is it? a software I can download to my computer, cell phone?
    I did a search and all I come up is a cable...………...
  18. Aug 26, 2019 at 8:49 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Welcome to 2019 everyone, 2020 is coming up and i hope most of you can get with the times..
    https://www.amazon.com/Interior-Par...argid=aud-829758849484:pla-606481397931&psc=1
    Does this mean if I crash at 9mph with a seat belt I wont come to a complete violent stop?
    What happens when you get into a roll over and you hit your head and get knocked out (side window), your truck is on the roof and your seat belt is latched so you're hanging upside down knocked out and then the flames start to reach you and you wake up but you cant get out of the seat belt and you burn alive? #IdRatherBeEjected
  19. Aug 26, 2019 at 8:54 AM
    TacoBreaker
    08 Rust Bucket
    OME 885, 5100s
    ResearchMonkee likes this.
  20. Aug 26, 2019 at 8:56 AM
    wheeliest
    Json
    TMPE AZ
    yeah, while i'm burning and my contents in my truck have been unorganized everywhere i'ma look for a seat belt cutter.. i race motorcycles and ride them on the street.. still would rather risk getting ejected.
