Seatbelt ordering confusion
Discussion in '1st Gen. Tacomas (1995-2004)' started by FHT95, Jun 29, 2019.
  1. Jul 3, 2019 at 9:04 AM
    #41
    GQ7227
    GQ7227 mw survivor
    J A Y
    so if you keep the speed to under whatever it is you can safely brace yourself (grip the steering wheel) you should be good to go a few days?
    i.e., no more hauling it down the freeway lol
  2. Jul 3, 2019 at 9:13 AM
    #42
    Taco Shepherd
    Taco Shepherd Active Member
    Walt
    2009 Tan Tacoma Base Model
    Interior Mods: custom cluster, accent lights, wired stock backup camera to aftermarket radio, dye carpet and trim black Exterior mods: Headlight lenses and bulbs, fog lights, 3rd brake light, tail lights, bull bar, sport bar, restored sun damaged trim, more to come
    I cannot recommend driving without seatbelts. I was only letting anyone who does this know what they are in for if it comes to that.
    GQ7227[QUOTED] likes this.
  3. Jul 3, 2019 at 10:00 PM
    #43
    Jp Sturm
    Jp Sturm Well-Known Member
    Jp
    Horseshoe Bend Idaho
    95 Sx 5 speed
    That's good to know, my seat belts are also starting to need hand fed back in. Thanks for the info.
  4. Jul 3, 2019 at 10:03 PM
    #44
    GQ7227
    GQ7227 mw survivor
    J A Y
    well i took a look back there to see and my seatbelt change is very much a pain in the
    all the parts to remove, undo the rear side window, a coat hook, moldings
    lotta stuff to take off without damage just to get to a seatbelt!
  5. Jul 3, 2019 at 10:03 PM
    #45
    1997tacomav6
    Denver
    Drivers side is shown
  6. Jul 4, 2019 at 3:52 AM
    #46
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Do our trucks use explosive seat belts tensioners or pre-tensioners that triggered by air-bag deployment?
    https://www.youtube.com/watch?v=sVH9CX7iMp4
    GQ7227 likes this.
  7. Jul 4, 2019 at 5:16 PM
    #47
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @CS_AR I just ordered a new seat belt from CamelBack toyota and had to pay a hazmat shipping fee. So I'm going to assume that there's some type of explosive device incorporated into the seat belt. Somebody with more knowledge than me please chime in.
    CS_AR and GQ7227 like this.
  8. Jul 4, 2019 at 11:36 PM
    #48
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Correct. Late 1st Gens has an explosives pretensioner.
    GQ7227 likes this.
  9. Jul 5, 2019 at 5:12 AM
    #49
    GQ7227
    GQ7227 mw survivor
    J A Y
    i was checking out the back of my xtracab paneling and trims.
    does every bit need to be removed (including undoing the window latch) to access the seatbelt exchange or just the squarish piece needs to come out where the seatbeat comes through :notsure:
  10. Jul 5, 2019 at 5:55 AM
    #50
    CS_AR
    I wonder what year the explosive device was introduced to Tacoma? I've got a 1999 Infiniti that used it but not in the 1998 model. So I had to go back to the salvage yard to get the one for a year later when I needed to replace a set on the 1999 model. If the year requires one and you attempt to use one that does not contain the charge, leaving the yellow connector unplugged will cause an SRS event that will hang around in ECU history forever.
    Be sure to disconnect the battery and reconnect any yellow plugs when working with any part of the SRS system.
  11. Jul 13, 2019 at 11:43 AM
    #51
    FHT95
    FHT95 [OP] Member
    95 stock SR5
    ACE_10 when I looked at the ordering schematics online it seemed like the part number tended to change every one or two years during the first gen series. If you look closely it gives a date range (year&month to year&month) i.e. 199501 to 199609
    ace_10[QUOTED] likes this.
  12. Jul 17, 2019 at 7:00 AM
    #52
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Thx.
    Local dealer looked up the correct part number for my 1995 with blue grey guts and came up with 73220-04030-B0 for driver's side. Still available. $223 locally sourced. $147 online.
