Seatbelt/Passenger Airbag Light Illuminated
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dsouthard3430, Mar 19, 2019.
  1. Mar 19, 2019 at 1:30 AM
    dsouthard3430
    dsouthard3430 [OP] Member
    Dylan
    Franklin, NC
    1997 Toyota Tacoma 4x4
    Howdy everyone,
    I recently had my passenger airbag and seatbelt light come on my dash in my 2018 Tacoma Pro. I have not done anything to my wiring or screwed with anything it just randomly came on. The seatbelt light blinks at me even when my passenger and myself are both buckled and the passenger airbag stays turned off all the time which illuminates the red light in my dash. HOW CAN I FIX THIS???
  2. Mar 19, 2019 at 1:32 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    This should be under warranty.
  3. Mar 19, 2019 at 1:33 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Dealer. Warranty.
    JCT86, StayinStock, robssol and 3 others like this.
  4. Mar 19, 2019 at 2:03 AM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    does the truck start right up?
    or does it seem to turn over slower than usual?
    sometimes lower voltage makes the
    computer do strange random things on a weak battery.
    if nothing else unplug the battery for
    10 minutes and see if that resets things for you.
  5. Mar 19, 2019 at 2:08 AM
    dsouthard3430
    Dylan
    Franklin, NC
    Nope starts right up. I just installed a light bar and a set of ditch lights and had the entire battery unplugged during the process and still had the lights on afterwords. My closest dealership is two hours away so I guess it is time to make the trip!
  6. Mar 19, 2019 at 2:08 AM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    Don't mess with it. Take it to the dealer !
    The truck has a 36mos/ 36k warranty. Use it.
  7. Mar 19, 2019 at 2:12 AM
    dsouthard3430
    Dylan
    Franklin, NC
    I plan on it! Closest dealer is two hours away so i'll plan a trip soon.
  8. Mar 19, 2019 at 2:17 AM
    Boosted_Carrera
    Hawaii
    Don't mess with it. Don't give the dealers any reason for them to void your warranty.
    Good luck.
  9. Mar 19, 2019 at 2:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It was a bad LF impact sensor on my 2nd gen covered under warranty
    dsouthard3430[OP] likes this.
  10. Mar 19, 2019 at 2:19 AM
    dsouthard3430
    Dylan
    Franklin, NC
    Would me having ditch lights, new headlights bulbs, or a 32in light bar affect my warranty? Need to know what to remove before taking it to them lol
  11. Mar 19, 2019 at 2:23 AM
    Boosted_Carrera
    Hawaii
    Every dealer is different. If its not THAT cumbersome, I'd remove . Headlight bulbs, no.
    All depends how you wired up the accessory lights.
    If you tapped it from a fuse block, DEFINITELY remove it.
    Don't give the dealers any ammo to void your warranty.
    outlawtacoma likes this.
  12. Mar 19, 2019 at 2:25 AM
    dsouthard3430
    Dylan
    Franklin, NC
    Just simple plug and play with their own inline fuses.. don't see any reason they could blame this situation on my install.
  13. Mar 19, 2019 at 2:28 AM
    Boosted_Carrera
    Hawaii
    Lol. You'll be surprised. Not so experienced service personnel may say really off the wall crap. Been there.
    If you have other dealers you can go to, try the closest and see what they say.
  14. Mar 19, 2019 at 2:37 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Odds are you probably just need to recalibrate the weight sensor in the passenger seat
  15. Mar 19, 2019 at 3:28 AM
    ET340f
    ET340f Well-Known Member
    Westechester, NY
    2019 OR MT
    A dealer can't void a warranty.
    CanisLupus and robssol like this.
  16. Mar 19, 2019 at 3:47 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Did you have anything on the passenger seat? Enough weight will trigger this.
  17. Mar 19, 2019 at 10:04 PM
    dsouthard3430
    Dylan
    Franklin, NC
    No I sure didn't! This has been going on for several weeks now just hoping it will go away lol
  18. Mar 19, 2019 at 10:23 PM
    tw4taco
    tw4taco Well-Known Member
    BC, Canada
    2017 TRD OffRoad
    working on it
  19. Mar 19, 2019 at 10:27 PM
    tcjacado
    tcjacado Well-Known Member
    Did the problem start after headlight bulb change ? Maybe a rain storm/ car wash took place just before lights came on?
  20. Mar 20, 2019 at 12:28 AM
    Boosted_Carrera
    Hawaii
    Of course they can . If the OP (not saying you did OP)
    installed aftermarket kits to anywhere related to his problem , you think the dealer will fix it under warranty ?
    If someone installed tap wires to his fuse block and fried the block , you think the dealer will fix it for free??
