Seatbelt Retractor Rattle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4Cylinders, Jun 11, 2025.
  1. Jun 11, 2025 at 12:28 PM
    4Cylinders
    4Cylinders [OP] Well-Known Member
    Anthony
    2023 Tacoma 2.7L 4x4 Auto
    2023 Tacoma SR 2.7L 4x4 Access Cab
    This rattle is driving me crazy. Replacements are over $300. The front passenger side doesn't make a noise at all but the front driver's side does. Is this a known problem? I didn't find much about it on this forum.
    HondaGM likes this.
  2. Jun 11, 2025 at 12:31 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  3. Jun 11, 2025 at 12:32 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    What is this rattle? Is bolt that holds seat belt bracket to inside of cab loose?
  4. Jun 11, 2025 at 1:57 PM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    :popcorn:
    Is it friday again?
  5. Jun 11, 2025 at 2:14 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
  6. Jun 11, 2025 at 2:33 PM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    I have noticed a rattle sometimes with mine and it does get annoying. It's the tensioner on mine doing it. It has to much slop and me bouncing in the seat ever so slightly makes the slop in the ratchet of the tensioner rattle as the belt gets pulled slightly. Adjusting the height of the shoulder belt on the B pillar seemed to help so it isn't always doing it.
  7. Jun 11, 2025 at 3:21 PM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    I have this rattle too on my sport access cab. I hear it mostly when I go around a turn and hit a bounce in the road. It is coming from the tensioner as described above. I looked in to fixing it when I had the door panel off to fix others squeaks and rattles but could not find a solution and did not want to replace the tensioner. I have lived with it and will try adjusting the height of seat belt as mentioned by Darty03.
