seatbelt retracts slowly
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020TacomaGuy, Jul 9, 2025 at 12:58 PM.
  1. Jul 9, 2025 at 12:58 PM
    2020TacomaGuy
    2020TacomaGuy [OP] Well-Known Member
    2020 4x4 DCSB SR5
    My drivers seatbelt retracts slowly.
    Sometimes I have to guide it in.
    Not the end of the world but annoying, especially if it gets worse.
    Is there anything that can be done?
    Can it be lubricated?
    Thanks in advance.
    musicisevil likes this.
  2. Jul 9, 2025 at 8:17 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    Mine started doing this a few days ago. In most other vehicles I'd just pull it slowly all the way out and hold some tension as it retracted but that didn't seem to help it.
  3. Jul 9, 2025 at 9:23 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Maybe it's getting bound up or twisted in the receptacle?
  4. Jul 9, 2025 at 9:38 PM
    Bishop84
    Bishop84 Well-Known Member
    The only thing that I've seen is the plastic pillar trim causes it to bind and retract slow.
    Otherwise lubricating it won't help, its usually dust/hair/debris that causes the seatbelt to retract slowly. Dog hair is murder on them.
  5. Jul 10, 2025 at 12:50 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    First thing to do is clean the seatbelt.
    Black97v6MT and monoman like this.
  6. Jul 10, 2025 at 12:57 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Yup I'd start there. Also, you might want to clean the buckle, (where the slot is, where the belt goes through) as well. Had this happen on my 1st Gen.
  7. Jul 12, 2025 at 4:29 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Mine has done it since that day I picked it up 2 years old used.
    TheWildMan likes this.
  8. Jul 12, 2025 at 4:43 AM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Yeh mine does it most of the time too and I hate it!
    kahanabob likes this.
  9. Jul 12, 2025 at 1:16 PM
    Diver_De_Taco
    Diver_De_Taco Well-Known Member
    ‘23 TRD OR
    Mine is the same way. I did a little bit of research on it but haven’t found any real solutions. Tried every tip I’ve found without success. I just give it a little nudge to help it retract now.
  10. Jul 13, 2025 at 3:01 AM
    swtacos
    swtacos Well-Known Member
    Get this fixed. Might be able to replace it from a junkyard. Loose, you could get thrown even belted.
  11. Jul 13, 2025 at 3:27 AM
    Tacoma Mike
    Southern Maine
    I have replaced several for slow retraction out of warranty for no cost.
    It’s a good idea to stop in a dealer and explain the situation and see if they will do anything for you.
    As long as the interior is clean and not full of dog hair or dirt and it hasn’t gotten into the mechanism they possibly could do something. Doesn’t hurt to ask…
  12. Jul 13, 2025 at 4:51 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
  13. Jul 13, 2025 at 4:54 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    same ish here on the gen1
    it is quite annoying :(
  14. Jul 13, 2025 at 7:19 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    My gen1 does this and it’s annoying and if the belt retractor is still available I intend to replace it. As far as my gen3 if it starts I will replace it I think most of the time the spring just wears out.
    Black97v6MT likes this.
