Seatbelt won't retract!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lipripr, Nov 21, 2011.
  1. Nov 21, 2011 at 1:58 PM
    lipripr
    lipripr [OP] Member
    Colorado
    2006 TRD 4x4
    Hello,
    Has anyone ever fixed a seatbelt that won't retract? I have the access door panel off, and am just looking for some tips to get the stupid belt to start retracting on its own again. There were three screws/bolts that had backed out, but that doesn't seem to be the only problem. Any suggestions are appreciated.
    Thanks
  2. Nov 21, 2011 at 2:11 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Toyota is real good with extending the warr. on belts. (At least at my shop.)
    If it's not chewed by a dog or cut you could have a chance of having it replaced. I'd head over and see what they say. I just changed one about a week ago and it had a ton of miles on it. No problem.
    Had to change the passenger belt in my Wrangler. 06 21,000 miles. If i hadn't had the ext warr it would have cost me $480.00.
