Second Battery and Inverter
Discussion in '1st Gen. Tacomas (1995-2004)' started by scandoscott, Apr 22, 2010.
  1. Apr 22, 2010 at 3:56 PM
    scandoscott
    scandoscott [OP] New Member
    96 Tacoma
    Wildernest
    So I have a 96 Tacoma with a wildernest and I would like to add an inverter that is accesible from the bed. I would also like to run this inverter off a second battery so that I do not kill my primary while camping. What is the best way to do this, should I still try to install two under the hood or would it be best to find a way to wire the battery to the bed.
  2. Apr 22, 2010 at 5:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw.
    i havent done a 2 battery setup like alot of the guys have..........but best bet is probably, if you dont have room under the hood.......keep the extra battery in the cab, and run longer wires to extend them to the other battery, and run them in series......then you can install the inverter where you want it, and run wires thru a grommet in the back of the cab, or right under one of the seats. you'll probably wanna look into another alternator as well, especially if you are going to hook up alot of lights.
