Second battery to run refrigerator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by denver osborne, Jun 29, 2020.
  1. Jun 29, 2020 at 9:57 AM
    denver osborne
    denver osborne [OP] Octoyota
    Deej
    California coast
    toyotatruckonly
    Does anyone have any solid feedback on adding a second battery to run a refrigerator mounted in the Bed? Many of the fridges have AC and DC power options, it seems the best route is to not tax the built in inverter of the truck and run a second battery that just runs the DC powered fridge. Wondering if there are any trick under the hood installation options. I suppose down the road it would be nice to add solar charging to this battery as well.
    Thanks for sharing your experiences, would save me a lot of time. Am having to travel across the country this summer with my family and would rather bring all our food in general rather than be stopping all the time to purchase.
    Gunshot-6A likes this.
  2. Jun 29, 2020 at 10:04 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    You could either run a dedicated second battery, or run a larger main battery like a group 31 instead of the oem 24 or 27. A second battery would have the benefit of giving you self jumping capabilities as well as the safety measure of depleting a house battery and being able to start the truck.
    Most install kits are pretty straight forward, so not much advice to give there, just follow the instructions.
  3. Jun 29, 2020 at 10:07 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I run mine 24/7 off my main Northstar Battery without issue. I do have a second Northstar Battery in the bed not integrated yet.
  4. Jun 29, 2020 at 10:10 AM
    CoTacos
    CoTacos Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    My plan to run a fridge (though in cab) was a jackery 500 watt battery and a solar panel on the roof if you're interested in that option too. Then you can also charge your other electronics too
    WrecklessAbandon likes this.
  5. Jun 29, 2020 at 10:12 AM
    Vacationgangster
    Vacationgangster Well-Known Member
    2005 silver Tacoma
    OME 886's, Dakar Leafs, fk29 cb shim, 3deg spacers, 17" Method Vex, 255/80/17 Cooper S/T maxx, Leer shell, frontrunner rack, Thule bars, 40" light bar, Hids, Seat covers, JL's, Headunit
    As long as you use an 8 ga wire to run the fridge, and have the battery saving function set to at least "Ned" you will be fine without a second battery.
  6. Jun 29, 2020 at 10:13 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I just ran my ARB 37qt off my stock 24f battery for over 23 hours and the truck started just fine. You might not need a dual battery for a fridge....just saying.
    When my battery needs to be replaced I will get an AGM (northstar, x2, etc) and call it a day.
    Edit - make sure to keep your fridge as full as you can so it will be more efficient. Air has horrible thermal properties.
    FirstGenTundra, gmtech and Gunshot-6A like this.
  7. Jun 29, 2020 at 10:14 AM
    Shellshock
    Iowa
    I also run mine off the main. Put in a x2power 27f and get plenty of run time.
  8. Jun 29, 2020 at 10:16 AM
    Gunshot-6A
    Conner
    Everett, WA
    X2 Group 31 here. It's a heavy mofo, but power for days and starts the truck with authority since the CCAs are like 2x the oem one.
  9. Jun 29, 2020 at 10:28 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    What fridge do you have? There are wildly difference energy consumption rates depending on what fridge you have and what temp setting you plan to use.
    For everyone claiming to run it off their main battery, that's fine but you are likely destroying your battery. A starter battery isn't designed to be drained repeatedly. You might still be able to start your truck, but that doesn't mean the battery is happy about it.
    Example, my CFX-75 set at 37° can burn through the usable energy in a 100amp Northstar in about 24hr. If I have one of the zone on freezer mode than I can deplete it in under 12 hrs. A typical starter battery isn't going to come close to powering it regularly without killing it.
    So be forewarned, know your batteries and know how much energy you are using or you'll find yourself stranded.
  10. Jun 29, 2020 at 10:32 AM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Noted. I look forward to upgrading my battery when I kill the stock one.
    Bertw192 likes this.
  11. Jun 29, 2020 at 11:10 AM
    denver osborne
    Deej
    California coast
    toyotatruckonly
    Hey gunshot, thanks for the input... hey I am a hokie as well... going back there this summer to visit friends... love the Berg, hope to retire there some day.
    Gunshot-6A[QUOTED] likes this.
  12. Jun 29, 2020 at 11:13 AM
    denver osborne
    Deej
    California coast
    toyotatruckonly
    Sorry, please explain, what do you mean the battery saving function set to 'ned'? I don't think the 2016 Tocomas have that feature?
  13. Jun 29, 2020 at 11:16 AM
    denver osborne
    Deej
    California coast
    toyotatruckonly
    Thanks for asking... as a matter of fact I am in the process of trying to figure out which fridge to purchase. Everything I find of decent size has a freezer as well and I don't want a freezer, I would much rather have more refrigeration space...we don't need ice cream and frozen meat... anyone want to recommend a good size fridge that doesn't require the freezer. Everything on Amazon has the freezer as well. thanks so much for everyones input.
  14. Jun 29, 2020 at 11:18 AM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Presumably he means battery saving function set to “Med” as in medium on the fridge.
  15. Jun 29, 2020 at 11:18 AM
    jowybyo
    Joe
    Baltimore, MD
    All of them can be used as a freezer. Mostly are just a single compartment that can be set to -8° to 50°F. What size cooler do you typically take camping?
  16. Jun 29, 2020 at 11:26 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    I am thinking of adding an Aux battery as well but was looking for a beefier Alt to charge both
  17. Jun 29, 2020 at 11:30 AM
    seattle_taco
    seattle_taco Well-Known Member
    Seattle
    2018 TRD OR DCLB
    I run mine off a secondary AGM battery, which is electrically separated and charged via a CTEK D250SA.
    If you want more information about my setup let me know.
    Triple P, Tacodog and Gunshot-6A like this.
  18. Jun 29, 2020 at 11:34 AM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Tons of info available on this subject, Genesis Offraod and Offgrid Engineering are just to of the manufactures of a plug and play duel battery system that will place your second battery under the hood. Personally I wanted my house battery to be compleatly independent from the truck battery to avoid the headache of dealing with the "smart alternator" so I am using a 120v charger plugged into the factory inverter in the bed as well as solar. I have been running my Dometic DZ75 fridge/freezer in my garage the past two weeks hooked up to a standard led acid 100ah battery and I get roughly two and a half days run time before battery voltage drops to 12-12.3 volts and needs to be recharged to avoid damage to the battery. Using a Victron 120v charger it takes four to five hours to charge the battery all the way back up.
  19. Jun 29, 2020 at 12:13 PM
    Gunshot-6A
    Conner
    Everett, WA
    I think he means "med" as in medium. The ARB fridge I have has a low, medium, and high battery saver function where the fridge shuts itself off to save your battery for starting at 12.0v, 11.5v, and 10.6v or something along those lines. high or medium is for sure plenty to start the truck still. The 10.6 is more to keep the battery healthy if you are running it off a second battery and really drain it down.
  20. Jun 29, 2020 at 12:25 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I built my own system into a plywood and 2x10 box that I set my Fridge on. Added two Optima D27Ms and connected them to the main starting battery under the hood through a Blue Sea ML-ACR and some cheap LONG jumper cables cut to fit with Crimped on lugs. Obviously I've also got Solar, a battery charger, and a fuse panel, but that wouldn't be necessary, as you could simply run a 12v plug with an inline fuse to your Fridge. You don't have to be crazy fancy.
    Rocket Metal, BigWhiteTRD and synaps3 like this.
