second gear grabbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tig1, Jan 21, 2010.
  1. Jan 21, 2010 at 8:33 AM
    tig1
    tig1 [OP] Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    I have a 2009 tacoma 5 speed 10312kms on it, ever since I bought the truck the second gear has been grabbing.does anybody else has this problem.I been to the dealer more than once,they tell me not to worry.:confused:
  2. Jan 21, 2010 at 8:36 AM
    JAG
    JAG Well-Known Member
    Mine will grab ever once in a while. It happens only if I maybe slowed way down and was creeping along and then accelerated. It only has happened a few time.
  3. Jan 21, 2010 at 8:40 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Grabbing?
  4. Jan 21, 2010 at 8:45 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    My '10 5spd 2nd gear does grab a little when cold. It is hard to shift when cold anyway, so I find myself clutch in and hold pressure on the stick and a second or two later it will sorta glide into gear with little effort instead of shifting. It ususally grinds a tad if i force it. It doesnt like shifting at 2500 rpm and tends to be smoother if i take it to 3k rpm just for shifting to second gear(doesn't grab). Its a truck trans so I chalk it up to that.
    It takes more time, but the rest of gears on up are ok. I have 4500 miles on it go im sure its still breaking in some. Want to change to redline oil at 10k down the road.
  5. Jan 21, 2010 at 8:51 AM
    drew02a
    San Antonio, TX
    So you just mean it's hard to shift into 2nd?
    I changed out the gear oil in my tranny for Redline NS and it helped a ton.
  6. Jan 21, 2010 at 8:57 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  7. Jan 21, 2010 at 8:59 AM
    drew02a
    San Antonio, TX
    I assume the original poster has a manual transmission since that what it says in his profile. That TSB is for the Automatic Transmissions on the 4.0L V6s.
  8. Jan 21, 2010 at 9:08 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    what do you mean by grabbing?...mine seems to be fine
  9. Jan 21, 2010 at 9:18 AM
    Crom
    Nick
    San Diego, CA
    Millions
    That is true.
    He said he had a 5-speed transmission in the post. Does Toyota make a 5-speed manual transmission? :confused:
  10. Jan 21, 2010 at 9:20 AM
    drew02a
    San Antonio, TX
    The MTs on the 2.7L are 5 speed
    The MTs on the 4.0L are 6 speed
  11. Jan 21, 2010 at 9:22 AM
    Crom
    Nick
    San Diego, CA
    Millions
    :eek: Thanks.
  12. Jan 21, 2010 at 10:25 AM
    jassco
    NH
    2023 TRD Offroad
    Yes hard to shift to second and even first especially after my URD short shifter install.
    I believe the manual trans for our trucks use brass synchros and a GL-4 spec oil is less harsh on them then a GL-5 oil.....the 75W-90 NS is a GL-5 oil more for copper and other harder metals so you may want to check that out....don't hold me to it though.
    Redline MT-90 and MTL are GL-4
  13. Jan 21, 2010 at 10:28 AM
    kilgoja
    Alabama
    :mudding:
    mine goes into second smother than any car i've ever owned....don't force it into second..don't think of shifting as one motion...like 1st to 2nd....it's more of a two step process with a very slight pause in the middle...also make sure you are pulling the gear shift straight down and not towards your leg
  14. Jan 21, 2010 at 11:32 AM
    drew02a
    San Antonio, TX
    Thanks for the info. Just did some research and am going to switch over to MT-90 just to be safe :thumbsup:
  15. Jan 21, 2010 at 11:34 AM
    drew02a
    San Antonio, TX
    What about the transfer case?
  16. Jan 21, 2010 at 11:37 AM
    drew02a
    San Antonio, TX
  17. Jan 21, 2010 at 11:46 AM
    jassco
    NH
    2023 TRD Offroad
    yes any 75w-90 syn should make things smoother its the detergents in the GL-5 oils that are just harsher on the synchros in these trans over time from what i have read. The issue isn't with the viscosity but the cleaning or additive agents used in Gl-5 as opposed to the Gl-4.
    I believe Gl-5 NS should be good for everything else provided you are a 2009 + and require no limited slip additives for your rear. Check the truck manual and you can always email redline to confirm specs. Lots of good info to search on this and other forums about this.
  18. Jan 21, 2010 at 11:49 AM
    drew02a
    San Antonio, TX
    Okay, did EVEN MORE research specific to our trucks and here's what I came up with. A page straight from the Owners manual saying it's okay to use GL-4 or GL-5 in the manual trannys.
    Still, thanks for the info. I had no idea it would matter at all. Still going to do some more research though.
  19. Jan 23, 2010 at 8:41 AM
    tig1
    Paul
    2009 tacoma
    Hi tig1 calling-sorry I wasn't clear on my post( it was my first one).it is a five speed manual ,it doesn't matter on what the temp is. it only does it from first to second and not third to second.I have been to the dealer more than once,I am at the point of asking for a letter to protect myself in the event the gear goes an they try to blame me.an yes if I shift from first to second with that pause in the middle of the shift it slides in smooth.it does do it at various rpms,most times it is good at around 2500 rpms. thanks to all that responded.
    later tig1:D
  20. Jan 23, 2010 at 10:03 AM
    drew02a
    San Antonio, TX
    That was the same problem I had before changing gear oils.
    The syncros in our trucks are wierd. In the mean time, have you tried double clutching?
    From first to second this is how it goes:
    1) push in clutch
    2) shift to neutral
    3) let out clutch
    4) push in clutch
    5) shift to 2nd
