Second gear pops out sometimes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brocoma, Apr 17, 2012.
  1. Apr 17, 2012 at 6:38 PM
    Brocoma
    Brocoma [OP] Well-Known Member
    AJ
    Portland, OR
    09 4dr TRD off-road
    Okay so I have 2009 Toyota Tacoma 6spd. And sometimes second gear well pop out as I'm costing down the road. It usually does between 1-2000 rpms.
    Anyone else have this problem?? And don't say the syncros cause it's a newer truck
  2. Jul 16, 2012 at 8:45 AM
    cdoghump
    cdoghump Member
    06' TRD OR DC SR5 4x4
    I just bought an 06 and it does it also, haven't pin pointed when it does it. It seems to be when I down shift. have you found anything else out on this issue?
  3. Jul 16, 2012 at 8:56 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CVT Mt. Bachelor on a home-built bed rack.
    Not sure this would apply, but my '92 pickup did this. It was a $12 nylon bushing at the bottom of the shifter and an easy fix.
  4. Jul 16, 2012 at 1:39 PM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    My '86 4Runner as well...
  5. Jul 16, 2012 at 5:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Why not? Just because it is newer doesn't mean it isn't the cause. That is the most common cause of a transmission popping out of gear. Also the biggest cause for syncro wearing out early is resting your hand/arm on the shifter while driving.
    It is the syncro's.
  6. Jul 16, 2012 at 5:13 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Bingo.
  7. Jul 16, 2012 at 5:53 PM
    moondeath
    moondeath The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Synchros will definitely cause this. Same thing happened to my wife's accord.
  8. Jul 17, 2012 at 12:02 AM
    MotorsportsAustin
    MotorsportsAustin Well-Known Member
    Austin
    Belmont, CA
    2012 Off Road 6spd
    or broken teeth on the gears.
