Second gen cheap mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tanner.b16, Aug 13, 2022.
  1. Aug 13, 2022 at 9:01 PM
    Tanner.b16
    Tanner.b16 [OP] Well-Known Member
    Tanner
    South Carolina
    clean 07’ Tacoma
    Hey guys, just tinted my tail lights for around $15. Do y’all think it looks good? Anyone done it with real tint before?
    TegoTaco likes this.
  2. Aug 13, 2022 at 9:08 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Good look. Wonder how tint will hold under bad weather hot or cold
  3. Aug 13, 2022 at 9:15 PM
    Coondawg07
    Coondawg07 Master of none
    Alabama
    2016 DCLB BBP
    Meh. Check night time visibility. Anything to make a motor vehicle less visible is a no for me.
    SomeGuy_GRM, winkel, JustJon and 8 others like this.
  4. Aug 13, 2022 at 9:45 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    It looks nice, but I, too, am not a fan of reducing brake light luminosity. It looks very faint in the daytime. You gonna do the third brake light?
    May also be illegal in your state.
    Key-Rei likes this.
  5. Aug 13, 2022 at 10:14 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    I’m gonna leave the 3rd one be just so it’s easier. PD where I live is usually pretty cool about it. It does still worry me, but I think it will be fine. Just afraid someone will rear end me and it’ll be my fault (south carolina)
  6. Aug 13, 2022 at 10:45 PM
    Chuy
    Lakeside, CA
    Silver Taco
    I only did a quick Google search for SC smoke/tinted brake lights and didn't find anything expressly forbidding it. The only relevant info was for brake lamps, in SC Code, section 56-5-4730, “…A stop lamp shall be plainly visible and understandable from a distance of one hundred feet to the rear both during normal sunlight and at nighttime and a signal lamp or lamps indicating intention to turn shall be visible and understandable during daytime and nighttime from a distance of one hundred feet both to the front and rear...”
    But, that wont stop the other driver from trying to blame you.
    Edit: there is inclement weather to consider - fog, rain, etc …
    Tanner.b16[OP] likes this.
  7. Aug 14, 2022 at 9:54 AM
    Waasheem
    Waasheem
    2007 xrunner
    It’s your vehicle to do as you please.
    That said I’m in the not a fan group. Many times I’ve nearly rear ended someone because their tail lights are spray painted black so the light is barely visible. Yes I follow at a safe distance.
    Chances are good if you get rear ended, the fault could become yours for visually imparing your brake lights.
    I’m stuck in a bad upside down car loan. I’ll just go find someone who spray painted their tail lights and drive into them hard enough to total my car, problem solved.
    Key-Rei likes this.
  8. Aug 14, 2022 at 10:05 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I like it... thanks for sharing! :thumbsup:
  9. Aug 14, 2022 at 10:42 AM
    TacoTuesday1
    FL
    No.
    I don’t put in effort and money to make my truck less safe, less visible, and less legal
    DEPO makes smoked rear housings that are still visible.
    If you’re looking for mods to do, you can do just about any. There’s millions. That truck is stock.
    You can add front axles
    ZColorado likes this.
  10. Aug 14, 2022 at 4:23 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Do your 3rd brake light. :D
  11. Aug 14, 2022 at 4:36 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    Looks like an accident waiting to happen...
  12. Aug 14, 2022 at 5:43 PM
    TacoTuesday1
    FL
    people already rear end stock cars a lot
    I’m sure tint will help
  13. Aug 14, 2022 at 5:44 PM
    TegoTaco
    Ontario, Canada
    You should really tint your 3rd brake light, it’s the last touch your rear end needs. :)
  14. Aug 14, 2022 at 5:45 PM
    TacoTuesday1
    FL
    what about the headlights
  15. Aug 14, 2022 at 5:46 PM
    TegoTaco
    Ontario, Canada
    I’m only going by what I see in the rear…lol!
    One step at a time lol…and it’s not my build lol!
  16. Aug 14, 2022 at 6:39 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    I've got some black vinyl wrap if anyone wants to do their headlights!
    winkel likes this.
  17. Aug 14, 2022 at 6:44 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Nope, not a fan. I used to work for an automotive lighting company. In fact, those tail lights came out of our factory in southern Illinois.
    All tail lights are subject to a minimum light output and visibility at a specified distance. Whether or not you can find anything in the statute, technically, I'd say it's illegal.
  18. Aug 14, 2022 at 7:06 PM
    Tanner.b16
    Tanner
    South Carolina
    clean 07’ Tacoma
    I have some new blacked out ones.
  19. Aug 14, 2022 at 7:22 PM
    steel wheels
    do it, do it, do it ! hahaha...
