Second gen manual swap.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SparkyIX, Apr 18, 2020.
  1. Apr 18, 2020 at 12:15 PM
    SparkyIX
    SparkyIX [OP] Well-Known Member
    Anthony
    Tonopah, AZ
    2009 TM 4x4 DCSB 6-Speed Swap
    Been tossing the idea of a manual swap for a good while. 2009 v6 4x4 dcsb. Found a Trans and sourcing all parts needed. Not using a donor truck because space is limited. Yes I know “cheaper to buy one already manual”, but Its the build I look forward too. The truck has sentimental value. Plus I haven’t seen a full build thread on this yet.
    BassAckwards likes this.
  2. Apr 18, 2020 at 12:26 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    I have an 2007, its in French Canadian though...o_O
    SparkyIX[OP] likes this.
  3. Apr 18, 2020 at 1:41 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Check the threads on using an FJCruiser transfer case since you are doing all that
  4. Apr 18, 2020 at 2:30 PM
    SparkyIX
    Anthony
    Tonopah, AZ
    been thinking about that idea too, not sure if I'm going to immediately go through with it though. ill probably get the truck mobile then ill eventually ditch the ADD
