Second Power Steering Pump in 6 months - Need Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NumNutz, Dec 30, 2013.
  1. Dec 30, 2013 at 6:18 AM
    NumNutz
    NumNutz [OP] One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I have had 33s on my truck for a year now. My original power steering pump lasted about 6 months with 33s. I figured it was just on the way out because the truck had 90k miles on her. Well now, 6 months later, the truck has 96k miles and the Toyota replacement power steering pump is starting to go. This is truly frustrating and I am looking for solutions.
    Do they make a heavy duty replacement? What could be causing this?
    MTopp likes this.
  2. Dec 30, 2013 at 9:42 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    My mechanic friend just replaced the PS pump on my buddies heep XJ and he said that you have to use a vacuum pump to suck all the air bubbles out or the pump will go bad in about 6 mos. (suprizing that he did this on Fri. and you post this quest. today)
    He said you have to keep pumping until it holds 25in of vacuum
    MTopp likes this.
  3. Dec 30, 2013 at 9:48 AM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    May I ask, what were/are your symptoms? My engine bay is making a knocking noise, and I'm suspecting it is something in the belt drive system. I've replaced idler pullies.
  4. Dec 30, 2013 at 10:05 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Your steering rack, maybe bad. Which is causing your pump to go bad. Just a thought. I don't think it's because your running 33" tires
  5. Dec 30, 2013 at 10:10 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Contaminated/incorrect fluid?
    Bad/leaking rack?
    If there are metal shavings in the system, either from the previous pump or from the rack, it could kill every component in the loop. Do a power steering flush.
    Do you hold the steering wheel at full lock often?
    33" tires shouldn't be an issue, or else a lot of trucks on TW would need pump replacements.
  6. Dec 30, 2013 at 3:26 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    I'll do that, but the last time the pump failed I didn't find a metal in the fluid . I make a point to not hold the steering wheel at full lock.
  7. Dec 30, 2013 at 3:27 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Failing pulleys and power steering pumps make a whine. If you are hearing a "knocking" that sounds more like a tie rod issue, but to be honest you're asking the wrong guy.
  8. Dec 31, 2013 at 5:29 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Bump. Anymore ideas guys?
  9. Dec 31, 2013 at 5:47 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I got nothing, because the guys above me already said most of what I was thinking. I did, however, want to come in here and say you got one SWEET looking rig!
  10. Dec 31, 2013 at 6:05 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Hahaha well thank you for the support. Love your truck as well! Wheels look really good.
    I just hate it when things break. Gotta pay to play.:rolleyes:
  11. Dec 31, 2013 at 6:09 AM
    Swamp Donkey
    Swamp Donkey Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    My power steering pump went from contaminated fluid. I had a hole in my inner tierod end boot and the mud and dirt and water etc worked its way into my rack and pinion. So lucky me got to replace both the power steering pump and the rack and pinion.
  12. Dec 31, 2013 at 6:25 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I've never pulled a vacuum on a power steering system. First time I've heard of that. Sure they always have air in them at first but they self-bleed pretty quick just by turning the wheel back and forth. That's how I've been doing it for 25 years and I've yet to replace a pump twice. But if a pump fails there's a reason. Some vehicles have a filter in the reservoir that should be periodically changed and always changed when replacing racks or pumps. I don't know if our trucks do or not. I think not. But all the BMW's I've had used them. What I've done a number of times when replacing pumps and racks is to flush out all of the lines off the vehicle. A few times I've seen some pretty big chunks of crud come out.
    MTopp likes this.
  13. Dec 31, 2013 at 6:44 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Uh oh. How much did that cost?
  14. Dec 31, 2013 at 6:56 AM
    BamaToy1997
    Bill
    Navarre, FL
    You mechanic friend is lost in the head! lol. There is no reason whatsoever to use a vacuum pump. Besides, it's not going to work that way. These systems are self-bleeding and will easily bleed out the air bubbles in minutes after replacing. Now you don't want to start the pump dry of course, but a vacuum pump? I've been doing this for over 25 years and have never once needed to do anything more than remove old pump, blow out old fluid, install new pump, fill with fresh fluid, and self-bleed the system.
    The majority of pumps that fail repeatedly will fail because fluid contamination, or other components that cause excessive load on the pump.
    MTopp likes this.
  15. Dec 31, 2013 at 7:16 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    So what's your best guess? Why am I having such trouble?
  16. Dec 31, 2013 at 7:24 AM
    BamaToy1997
    Bill
    Navarre, FL
    If you are 100% positive your fluid is clean, then I would check the lines to be sure they are not kinked anywhere, then if I remember correctly there is a pressure control switch on the back of the pump, or the line right there at the pump. Make sure the connector is in good shape and the terminals are good.
    MTopp likes this.
  17. Dec 31, 2013 at 8:12 AM
    NumNutz
    Virginia Beach, VA
    Lots.
    Alright I'll do that. If that all checks out?
    MTopp likes this.
  18. Dec 31, 2013 at 10:42 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Did you clean the reservoir screen?
  19. Jan 1, 2014 at 5:28 AM
    Swamp Donkey
    Fort St John B.C
    Keep in mind these are Canadian prices...... Dealer wanted 825 for just the ps pump alone. I got a reman ps pump from local parts shop for around 250. When I finally figured out that I had a bad rack and pinion, it was around 550 for that part from napa. Add in about 5 liters of synthetic trans fluid and the cost creeps up there. All work done by me.
  20. Jan 1, 2014 at 6:07 AM
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    Many of my local parts stores sell a pump with a lifetime warranty. A pain if you have to change one out, but parts would be free.
