secondary air filter removal help!!4.0L 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Detective_Dan, Jan 22, 2011.
  1. Jan 22, 2011 at 7:08 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i want to make sure i am removing the right part. is it the part outlined in red or something different?
  2. Jan 22, 2011 at 7:11 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    nope....the secondary filter is wherer the two clips are going into the box before the TB.
  3. Jan 22, 2011 at 7:14 PM
    Detective_Dan
    Colorado Springs
    ok so inside the air box where the normal filter is, when you take that out, it is the weird lookin filter with the thin metal mesh covering it that is left inside?
  4. Jan 22, 2011 at 7:15 PM
    jhodge83
    SC
    17 XLT Sport
    correct...when you open it up and the regular air filter is on the left (while looking at the engine from the front), the secondary is the grey looking one on the right that is attached to the inside of the box.
  5. Jan 22, 2011 at 7:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You wont get anything from removing it. Honestly, Your better off leaving it in.
  6. Jan 22, 2011 at 7:18 PM
    Detective_Dan
    Colorado Springs
    alright, cause i took that hose off that goes all the way to the fender, and i looked through it and didnt see any filter so i put it back on cause it didnt look right.
    so i take the main filter out, unplug the MAF sensor and pull the charcoal filter out?
  7. Jan 22, 2011 at 7:20 PM
    Detective_Dan
    Colorado Springs
    ive heard different things about it. some gain MPG, others dont so idk if im gonna take it out or not. its dark anyways so i wont do it till tommorrow so i have some time to consider it
  8. Jan 22, 2011 at 7:21 PM
    jhodge83
    SC
    17 XLT Sport
    the way i did it, i didnt remove the MAF. i just cut a slit in the filter big enough to grip it and pulled it out. others have simple taken a small bit and drilled out the plastic welds....or even used a screwdriver and hammer to pop them out.
  9. Jan 22, 2011 at 7:22 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    The 2.7's have a better chance of gaining anything from that mod.
  10. Jan 22, 2011 at 7:22 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    After removing mine I felt a much smoother idle,That's about it
  11. Jan 22, 2011 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Placebo. Me and Gaget both tested this, and found nothing.
    This ^^^
  12. Jan 23, 2011 at 12:41 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    I love the "i felt quicker throttle response" ~ whatever stuff on all these mods. I had a guy at work telling me he was getting 28 mpg and +35 hp in his crew cab frontier because he had a magnaflow and k&N. "you can really feel it"... yea.. I can feel the drone of his exhaust in my office when he pulls in. Sounds like a walrus humping.
  13. Jan 23, 2011 at 1:40 AM
    Average JOE
    Average JOE Well-Known Member
    San Diego
    PreRunner
    3'lift,Upgraded sound system,Dyanamat interior flowmaster,K&N,
    Nice! Funny
  14. Jan 23, 2011 at 1:44 AM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    Dude leave it in there. It won't help you.. 2.7, 4.0 either way its not gonna make a difference other then maybe a little sound. Its only there to keep engine gases from escaping into your garage after your turn your engine off. It doesn't restrict shit!
  15. Jan 23, 2011 at 2:47 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    If your going to do it make sure you remove the whole filter box out of the truck so that you do not drop any plastic particals into the intake. The secondary filter is held in with plastic spot welds. You dont have to drill them, Just take a flat blade screwdriver and work it around the edges of the filter popping them as you go. I removed mine I have a 2.7ltr It may have made a very small difference although I have heard in the 6cyl engines it not even worth it.
  16. Jan 23, 2011 at 4:26 AM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    That's some funny shit!
  17. Sep 20, 2011 at 5:26 AM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    i had a 93 5L mustang bone stock(at first). Unplug a few of the smaller vacuum lines and hit the town! It sure sounded bad ass lol.
