Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Feb 18, 2016 at 1:13 PM
    #181
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This "detecting exhaust pulses" info is new to me.
    On my Tundra, I never got around to making the block off plates. In did the bypass mod with intentions to make the plates the next weekend. I completly forgot about them. I've been driving the thing for 40000 miles with a valve stuck open.
    The truck hasn't burnt to the ground yet.
  2. Feb 20, 2016 at 3:54 PM
    #182
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    OK so I've run Into an issue.
    I made and installed my block plates(throws stuck closed codes now instead of open)
    Wired my resistor into my relay wiring. And very roughly connected everything up.
    Started truck and pump ran. Grabbed my scanner and watch the iat on the graph. It spikes to - 7C for about 1 second then goes back to +12 so I know it's working.
    My issue is that I need a timer I'm guessing. The resistor is not triggering the iat long enough. If I hold key in crank a few seconds longer it doesn't come on
  3. Feb 21, 2016 at 5:38 AM
    #183
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    The 2TR has had this system since 2005. My '06 has 94,000 miles and I haven't had any issues with it, and I haven't heard of any widespread problems with other 4 bangers. It would be interesting to see what the differences are between the 4 and 6 cylinder setups.
  4. Feb 21, 2016 at 7:24 PM
    #184
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    I was referring to Tacoma's with the 4.0 as those are the ones experiencing the issues. 4bangers have one less valve, I'm unsure if it is the same style or not though.
  5. Feb 26, 2016 at 8:01 PM
    #185
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I have a question, I have a 13 DCSB does anyone hear this pump turn on when you start the truck, it will run for a 1minute or so and then shuts off, at least I don't hear it any more. It also turns on for about 10 second after I turn the truck off. Is this normal??
  6. Feb 27, 2016 at 6:36 AM
    #186
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    I'm guessing it's trying to help the catalytic converter burn off what little fuel vapors that are left in the cylinders and manifold. The same goes with the charcoal vapor screen in the intake next to the air filter. When you turn off the engine, the remaining minute fuel vapors sit in the cylinder and intake. To keep it from going out into the atmosphere that filter suppose to clean it of gasoline fumes.
  7. Feb 27, 2016 at 7:07 AM
    #187
    gmann1972
    Greg
    Rhode Island
    Thanks for the explanation, Here's what happen and why I am asking this question. I removed the original pump (which I never heard turn on and off before), to install a Volant cold air intake system and I dropped the original pump on the floor of the garage...oooops, and of course I broke it. Purchased a new / used from e-bay, installed it in its new location inside the Volant system and now is when I heard it turn on and of...I guess if I really think about it, what you indicate make sense, due to the installation of the Volant cold air intake and a throttle spacer, there is more air going into the engine, and this pump needs to scavenge off any extra exhaust fumes that the engine and catalytic produce.
  8. Feb 27, 2016 at 7:16 AM
    #188
    billybob50
    Bob
    All it is, is a small motor. I assume what you're hearing is the motor bearings. Being a used one, most likely it's not going to last long. Maybe if you still have the old one a local shop could repair the motor?
  9. Feb 27, 2016 at 7:19 AM
    #189
    gmann1972
    Greg
    Rhode Island
    maybe what I will do is, install the original one, the only thing that broke on it was the plastic housing where the hoses go. I can swap out the plastic housings and see what happens...Thanks for the info...
  10. Feb 27, 2016 at 9:22 AM
    #190
    billybob50
    Bob
    Funny my 05 4 cylinder with 92K miles on the pump shorted out this 2015 summer, and I live in Florida! It's only a matter of time.
  11. Feb 27, 2016 at 9:29 AM
    #191
    billybob50
    Bob
    Their's only one torx screw holding the top housing on. I also broke the cheap plastic top piece trying to get it off! Just work with it, until it finally comes off. Suggest to leave the used one in place until you need to swap them. Worse case you'll break the used one you just purchased.
  12. Feb 27, 2016 at 1:23 PM
    #192
    gmann1972
    Greg
    Rhode Island
    Just swapped the pumps out, the original one does the same thing...I never did before...?
  13. Feb 27, 2016 at 2:13 PM
    #193
    tamaui
    tamaui Member
    2015 Tacoma TRD Sport
    2015 dbcsport auto 12k miles. Had same light come on driving home last night 10 min into drive....engine and trac off. No noticeable difference in driving. Came on again at start up this morning.....dash initially looked like an xmas tree with all the icons lighting up at start then they went off and engine/trac off stayed on. Filled up gas tank from 1/4 tank....lights still there. Drove 1/2 hour, truck sat for 2 hours.....lights gone when started. Havnt been back on since. Put another 50 or so miles on it and turned it off & on several times....hasnt returned. Made appt with dealer on monday while light was on....keeping appt
  14. Mar 1, 2016 at 1:43 PM
    #194
    lisag508
    lisag508 New Member
    Lisa
    Tacoma
    I live in Massachusetts, a Cali emissions state and I also work as a service writer in the automotive field. I pulled a few strings with the guys I know at the Toyota parts department. He read from the "dealer" warranty manual that secondary air pump systems fall into the 7 year, 70,000 mile emissions warranty. I have an appointment this Friday. My contact in the parts department already ordered the part for me. If you're not in a CA emissions state you may have to cough up the $800+ to repair it but I would try pushing the federal emission law with your local dealership regardless. I've seen the OEM air pumps for sale online in the $550 range for the DIYers. I've been carrying around one of our expensive shop scan tools to erase the P2445 code whenever the light goes on. IMO it's dangerous to drive since the truck goes into a low power or "limp" mode! I live in New England with a lot of hills, my poor Taco can't get out of its own way. I'll try to post my results after my appointment.
    ruffridha9 likes this.
  15. Mar 1, 2016 at 4:29 PM
    #195
    tamaui
    tamaui Member
    Lights havnt returned....dealer said cant help unless lights are on. Hopefully it was just a pressure issue in gas tank.
  16. Mar 6, 2016 at 11:36 AM
    #196
    Large
    Large Red
    pray man .. pray. unless you still have a warranty. I didn't so I had to do the bypass module fix.
  17. Apr 4, 2016 at 11:34 PM
    #197
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    My 12 was just at the dealer for this!! I wonder how many people are have this issue?
  18. Apr 5, 2016 at 3:04 AM
    #198
    billybob50
    Bob
    Not sure who you're fooling, when you keep erasing the code and keep driving. It's just a matter of time where it'll go completely bad, get it fixed or get that by pass system and be done with it! https://www.hewitt-tech.com/store/
  19. Apr 5, 2016 at 6:33 AM
    #199
    Large
    Large Red
    Do you happen to know if toyota did a TSB for our tacos like they did for the tundras?
  20. Apr 5, 2016 at 2:25 PM
    #200
    billybob50
    Bob
    No they haven't, you might get lucky. Check with your dealer maybe there's a change or your state requires a longer warranty.
