Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Apr 5, 2016 at 2:26 PM
    #201
    Large
    Large Red
    called corporate .. no bueno
    billybob50[QUOTED] likes this.
  2. Apr 5, 2016 at 9:41 PM
    #202
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Were all screwed on this and sad thing is it will happen again, best thing is the bypass like others have stated. Toyota doesn't care that they have a crap part on our trucks.
  3. Apr 6, 2016 at 5:03 AM
    #203
    Large
    Large Red
    Well I put the bypass on and I'm getting the P011B code now .. Which is a known issue with the bypass. Truck is fine and not in limp mode but I hate when the CEL is on.
  4. Apr 6, 2016 at 5:53 AM
    #204
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I get the P011B too. Now on first start, I cut it off after 3 seconds, then turn it back on, so it doesn't set. Im going to see if I can find a way to trick the coolant sensor like the how the bypass kit tricks the AIT sensor at startup. This way they'll match and not throw the P011B code. Just need some time on the weekends to get in there.
  5. Apr 6, 2016 at 6:26 AM
    #205
    Large
    Large Red
    I called hewitt tech and he said he's working on a fix for it and should be out in a few months. I still have a while before I have to get an inspection.
    Where in Houston are you? I am in La Porte
  6. Apr 6, 2016 at 6:40 AM
    #206
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    FYI, warranty coverage--2012 not covered, 2013 and later covered.
  7. Apr 6, 2016 at 7:08 AM
    #207
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Awesome, if he's coming out with a fix, I may just hold off. I just moved from the Energy Corridor to the Friendswood area.
    Large[QUOTED] likes this.
  8. Apr 6, 2016 at 5:55 PM
    #208
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Under what warranty is 13-up covered?
  9. Apr 7, 2016 at 6:39 AM
    #209
    Y2kbaja
    Sacramento
    Total Chaos
    7/70 in some states for 13 and up. 2012 is not covered beyond 3/36.
  10. Apr 7, 2016 at 7:41 AM
    #210
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    It's basically cover differently from state to state, usually only 3 years or 36,000 miles. Only sure way to know suggest to first look at your emission warranty booklet and then call Toyota Corporate office w/vin # in hand.
    Large likes this.
  11. Apr 26, 2016 at 8:09 PM
    #211
    njdevil316
    njdevil316 Active Member
    Michael
    Wanaque, NJ
    2012 Tacoma Double cab SR5
    Where exactly are these valves in reference to the pump? My 2012 just started with these codes at 60122 miles. Talk about bad luck huh?
  12. Apr 27, 2016 at 4:03 AM
    #212
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    They are located passenger side right by the valve cover, seems lots are going to have this issue once they reach 50-60k range so don't feel so bad and welcome to the club. Toyotapartsonline has the valve seat for a pretty good price.
  13. Apr 27, 2016 at 5:07 AM
    #213
    njdevil316
    Michael
    Wanaque, NJ
    Thanks alloutdrs1. I can't even get the code to reset now. Are they hard to get to? I'll go order the set now.
  14. Apr 27, 2016 at 6:23 AM
    #214
    NCTacoma
    NCTacoma [OP] Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    Mine went out at 43000. I am selling the truck so I just purchased the new valves through Toyota. Used a buddies shop account so it went from $650 ish to $430 ish.
  15. Apr 27, 2016 at 6:26 AM
    #215
    NCTacoma
    Caleb
    CLT, NC
    I fought with Toyota locally and HQ and never had any satisfaction. I will buy another Toyota but not with this fuggin secondary injection crap.
  16. Apr 27, 2016 at 7:12 AM
    #216
    njdevil316
    Michael
    Wanaque, NJ
    I feel the same way right now. Do you happen to have the part number for the air switch valve? I keep seeing 25860-0p010 but want to make sure it's right. Lol
  17. Apr 27, 2016 at 7:36 AM
    #217
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  18. Apr 27, 2016 at 7:47 AM
    #218
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Not meaning to take this off course, but is this Secondary Air Injection Switching Valve the device that makes a bit of racket for about 1 second approx. 25-30 seconds after you start up the engine cold?
    Thanks.
  19. Apr 27, 2016 at 8:53 AM
    #219
    NCTacoma
    Caleb
    CLT, NC
    The pump for the valves is the noise you are hearing. Whistling or whining noise?
  20. Apr 27, 2016 at 8:55 AM
    #220
    NCTacoma
    Caleb
    CLT, NC
    I ordered 25710-31022.
