Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. May 5, 2016 at 5:10 PM
    #261
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Mine had moisture in it as well, major reason why think Toyota changed the programming for the 13'-up trucks and left us with 2012's stuck with an inferior part.
  2. May 5, 2016 at 7:19 PM
    #262
    njdevil316
    njdevil316 Active Member
    Michael
    Wanaque, NJ
    2012 Tacoma Double cab SR5
    I'm going to call the dealer again tomorrow and express my displeasure with lack of coverage on this issue including the fact that they tried to charge me $700 for the valve assembly. I work for a Japanese based company that puts their customers first and number one focus is on customer retention. Toyota operates differently I guess. I'll also write a letter to corporate and see what happens with that. At this point just refund me for the price of the part and I'll feel better about Toyota again.
    ruffridha9 likes this.
  3. May 5, 2016 at 7:58 PM
    #263
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I love it! I did everything you stated above, no refund yet. But the more of us that continue to express our dissatisfaction maybe we will receive reimbursement and owners going forward will actually be taken care of!
    For my truck it had thrown the codes when I was at 29k miles, took it in to document and when it failed outside of the 36k sorry about your luck! So I know how you feel.
  4. May 6, 2016 at 7:26 AM
    #264
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    May I ask you all your trucks born on date? I ask because I want to compare yours to mine. I also notice that BMW and Jetta have this problems too.
  5. May 6, 2016 at 9:36 AM
    #265
    Large
    Large Red
    I've only found 2012 trucks with this issue. I'll look at my build date later.
  6. May 6, 2016 at 5:12 PM
    #266
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yep only seem like 2012 trucks, 13-up trucks have two differences I have noticed: 1) the pump itself has an insulated cover 2) the pump is programmed to run briefly at shutdown to evacuate moisture.
    NCTacoma[OP] likes this.
  7. May 8, 2016 at 11:20 AM
    #267
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    My CEL came on and gave me codes P0412 and P2441. Both relate back to secondary air injection, specifically the valves. My understanding is that the secondary air injection is really just for emissions standards, and that continue to drive with these codes being thrown won't damage the engine. Am I correct in that understanding? The engine is still running fine. How long can I wait before I go the route @njdevil316 went?
  8. May 8, 2016 at 11:47 AM
    #268
    NCTacoma
    NCTacoma [OP] Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    Are you in limp mode? If so, I cleaned my valves with electrical cleaner and got 6 months of no issues. Came back on next time but never limped so I left it alone for a while. Just recently replaced the valve myself
  9. May 8, 2016 at 12:02 PM
    #269
    LocoLocal
    Large American
    No limp mode..yet. How hard was it to replace the valves?
  10. May 8, 2016 at 5:08 PM
    #270
    NCTacoma
    Caleb
    CLT, NC
    Easy. 2 air hoses and 4 bolts.
  11. May 9, 2016 at 12:36 PM
    #271
    Large
    Large Red
    No more CEL for some reason .. just randomly went off on its own.
  12. May 9, 2016 at 2:59 PM
    #272
    LocoLocal
    Large American
    I'm hoping mine resolves itself like that!
  13. May 9, 2016 at 3:00 PM
    #273
    Large
    Large Red
    This was after I installed the bypiass kit from hewitt tech, and got the infamous thermostat CEL.
  14. May 9, 2016 at 3:02 PM
    #274
    LocoLocal
    Large American
    dammit
  15. May 9, 2016 at 6:42 PM
    #275
    leebo556
    leebo556 Well-Known Member
    Lee
    2012 SuperWhite 4x4 TRD OR
    CVT on Allpro Al, Whynter 45qt, 100w Solar, Budget Boost and 255's
    So...2442 code set at 60k mikes on my 2012. Was able to clear the code for a few weeks, then 2440 hard set. I pulled off the valves and cleaned them, flipped the retainer piece over to block the valve off in anticipation of performing the resistor bypass mod. I hook everything up before I start on the wiring portion and crank the truck up. No codes, drive it, no codes... Should be throwing a stuck closed code... Confused, but glad it's running. Truck was cold, 70°F outside.
  16. May 9, 2016 at 7:14 PM
    #276
    ruffridha9
    ruffridha9 Well-Known Member
    West Coast
    2012 Tacoma base
    stock ish
    Did
    You didn't feel the need to disconnect the battery did ya?
    On first thought I'm thinking no, but just getting in there now to start breaking shit up and have a closer look
  17. May 9, 2016 at 8:05 PM
    #277
    Large
    Large Red
    It's funny - and by funny I mean infuriating - that it just happens to take a shit when our powertrain warranty is up.
    richardbui23 likes this.
  18. May 9, 2016 at 8:28 PM
    #278
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Toyota wont cover it under the powertrain warranty anyways so it doesn't really make a difference. It is very interesting though like you stated that once the 2012's are getting 50-60k miles on them we are experiencing this failure..Toyota knows what they did.
  19. May 10, 2016 at 3:19 AM
    #279
    NCTacoma
    Caleb
    CLT, NC
    I did to clear the code.
  20. May 10, 2016 at 6:11 AM
    #280
    jtv
    My idea and you .....stole it o_O. Hope it works out in the long run. Last week I open up the pump and happy to see it was clean and dry. One thing I notice on the Tundra forum that their engines were very dirty/dusty. Since I clean my engine once a year in summer, I don't know if that helps the pump clean and dry. But I will modify this crap filter by using motorbike filter. I did not have a gut/time on motherday weekend to open up the valves. What did you clean them with, carburetor cleaner or....?
