Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Jan 13, 2017 at 2:53 PM
    #521
    Flyy58
    Flyy58 Member
    Jeff
    JAX, Florida
    2012 Super White Tacoma Prerunner
    K&n cold air intake Lund 5" oval nerf bars Pro comp 1069 17" Nitto Grappler G2
    Just got the dreaded p2442 code on my 2012 Taco at 58,000 miles. I decided to ordered the diverter valve for $430 and installed it myself. If you have any mechanical skills at all this part isn't that hard to replace. Took me 1.5 hours. Good luck.
    mrohaly and shakerhood like this.
  2. Jan 13, 2017 at 3:21 PM
    #522
    avnut48
    avnut48 Member
    NE USA
    2012 DCLB Base Auto
    Flyy58....where did you buy your diverter valve? Getting close to ordering myself. Thanks.
  3. Jan 13, 2017 at 3:54 PM
    #523
    Flyy58
    Flyy58 Member
    Jeff
    JAX, Florida
    Toyotaonlineparts.com was the cheapest place I found.
    Diverter valve #25710-31022. $429.98
    2-Gasket air tube #17377-32010 $0.92
    It was delivered in 4 days.
  4. Jan 13, 2017 at 4:04 PM
    #524
    Flyy58
    Flyy58 Member
    Jeff
    JAX, Florida
    You need 10 mm and 12 mm deep and shallow sockets to remove it. The bottom valve bolt is the toughest to get to. The valve bolts are 12 mm and the ridged air lines nuts are 10 mm
  5. Jan 13, 2017 at 4:31 PM
    #525
    avnut48
    avnut48 Member
    NE USA
    2012 DCLB Base Auto
    Thanks for the link. I notice today they are up $5 to $434. Not a big deal though in the big picture. Did you have any trouble breaking loose any of the fasteners especially the air tubes or did you use blaster on them for a couple of days first? The air tube bolts look a little whimpy and I don't want to crank too hard on them.
  6. Jan 13, 2017 at 5:13 PM
    #526
    Flyy58
    Flyy58 Member
    Jeff
    JAX, Florida
    Nope, they were snug but they broke loose fairly easy. The tube towards the cab are just nuts only. And the tube towards the front are bolts.
  7. Jan 16, 2017 at 8:19 AM
    #527
    Pcolabeachbum
    Pcolabeachbum New Member
    Lance
    2012 white double cab 4x4
    2440/2442 popped up 12/28/2016. My truck was 8 days out of warranty with 39,500k miles.
    Back and forth with Bob Tyler Toyota as well as regional and corporate Toyota. I have never been a triskaidekaphobe however they declined to provide a good will warrant of Friday 13th.
    I informed them this is my 3ed new Toyota in 12 years and they would lose a customer for life if they did not make the situation right. They still declined assistance.
  8. Jan 16, 2017 at 8:23 AM
    #528
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Man that just isn't right. Someone at Toyota needs a boot up their ass.
    Norton likes this.
  9. Jan 16, 2017 at 8:51 AM
    #529
    Pcolabeachbum
    Lance
    Toyota quoted me $1900.00 for the repair. Being the suspicious person that I am, I took it to my mechanic. The air pump which Toyota wanted to replace is fine. The valves are being replaced for $850.00 out the door. Not happy but I will take it. An honest mechanic saved me $1000.00.
    Toyota.
  10. Jan 16, 2017 at 8:57 AM
    #530
    TRD-ED
    Lenoir NC.
    I guess I'm one of the lucky ones. I was going to buy the Bypass Kit from Hewitt-Tech for $400. Until Toyota repaired mine under
    a "Goodwill" Warranty.
    mrohaly and Norton like this.
  11. Jan 16, 2017 at 9:15 AM
    #531
    Pcolabeachbum
    Lance
    I did notice in this thread and others that some were covered under "goodwill" warranty while others were not. I have no idea why they will provide "goodwill" warranty for one but not the other. The inconsistency is at best frustrating.
    Norton likes this.
  12. Jan 16, 2017 at 9:34 AM
    #532
    Large
    Large Red
    I can imagine, I bought the valves for $350ish and swapped them in an hour so it wasn't so bad. $1800? Nope.
  13. Jan 18, 2017 at 10:59 AM
    #533
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    Can you let us know where you bought the valves?
  14. Jan 18, 2017 at 11:19 AM
    #534
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    I have p2442 and p2440, obd2 app says that bank 1 and 2 are stuck on the valves.
    Does that definitively diagnose the valves as the issue or could it still be the pump?
    I took the casing off the pump and the filter was fully in tact, pump seemed clean and i was able to manually spin the impeller without resistance. Is there a better way to diagnose the pump? Just want to make sure I buy the correct replacement part.
  15. Jan 18, 2017 at 11:23 AM
    #535
    Large
    Large Red
    it's the valves.. I will have to find the invoice where I bought them
  16. Jan 18, 2017 at 11:28 AM
    #536
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    Thanks.
    I found it on "re-manufactured" on eBay for $365 but I was hoping to be able to find it somewhere that could get it to me before the weekend.
  17. Jan 18, 2017 at 11:33 AM
    #537
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    I got about 100 miles out of it from the last time I cleared the codes but it came up and cleared it about 5 times in 15 miles since then.
  18. Jan 18, 2017 at 11:35 AM
    #538
    TRD-ED
    Lenoir NC.
    That's the way it goes......Gets worse and worse.....Finally won't clear at all.....Soon as you pull it in gear comes back on....
    cricex likes this.
  19. Jan 21, 2017 at 4:58 PM
    #539
    blur
    blur Well-Known Member
    Has anyone else installed the Hewitt-tech bypass kit? There doesn't seem to be much feedback on it. I'd hate to spend this kind of money on something that should be handled by Toyota but I'd also like the peace of mind knowing I won't be stranded in limp mode when the truck decides to throw the light.
  20. Jan 22, 2017 at 8:06 PM
    #540
    Edtacoma
    Edtacoma Member
    2012 TRD Double Cab Longbed Tacoma 28k miles P2442 (per autozone) check engine and Trac off lights came on together this past Friday after work going in Monday to Toyota dealership *sigh* stuck in limp mode grrrrrrr
