Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Jun 22, 2017 at 6:15 AM
    #741
    Large
    Large Red
    All of y'all who bought the Hewitt tech module .. good luck. Dude has been MIA for me since I gave him money.
  2. Jun 22, 2017 at 7:57 AM
    #742
    slwburn
    slwburn Well-Known Member
    Winter haven Fl
    12 tacoma dclb 4x4
    I ordered mine online. Installed it already.
  3. Jun 22, 2017 at 9:41 AM
    #743
    Large
    Large Red
    Mine was installed and removed promptly. This was last year ..
  4. Jun 22, 2017 at 9:48 AM
    #744
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    When mine died. I stood on the throttle in park for about 2 min and I had maximum power. It only went into limp mode when it was cold. If you stand on the throttle for a few min before setting off it won't go into limp mode.
    slwburn likes this.
  5. Jun 22, 2017 at 11:48 AM
    #745
    slwburn
    Winter haven Fl
    12 tacoma dclb 4x4
    Why did you remove it?
  6. Jun 24, 2017 at 10:29 AM
    #746
    jokker1978
    jokker1978 Well-Known Member
    southeast texas
    2012 TRD sport 4dr 4x4 white
    If you change the valves out. The two studs on the top will unscrew from the block and make it very easy to install the new one.
  7. Jun 25, 2017 at 7:33 AM
    #747
    blur
    blur Well-Known Member
    I decided to try and get ahead of this and installed the HT kit before I started getting codes. Install wasn't too bad and the directions are more detailed than I thought, which was nice. The truck still starts and I have a little piece of mind now knowing I'm not driving a ticking time bomb.
    JuanitoBonito and Mrguitarguy01 like this.
  8. Jul 18, 2017 at 12:10 PM
    #748
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    So how have these valves been going? I just got my codes this AM and want want to see how your fix went.
    What did you update your ECU with?
  9. Jul 19, 2017 at 8:08 AM
    #749
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    No computer updates to solve the issue yet, I would for sure go with those Tundra valves as the cost is much cheaper and seems to be working just as well. Also don't forgot to call Toyota and file complaint, it wont get you anywhere and they will just blow you off but the hope is that Toyota may someday take care of this issue for the many who have had this failure. Good Luck!
  10. Jul 19, 2017 at 11:32 AM
    #750
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Ok, but the Tundra valves are plug and play aside from some minor sizing differences outlined in the previous post?
  11. Jul 24, 2017 at 8:20 PM
    #751
    sprocket4b
    sprocket4b New Member
    2012 Tacoma TRD
    I have the same issue showing the same codes. I took the one valve assembly off closest to the fire wall just by taking the four torx bolts off of the unit. I saw that the rubber gasket on the valve was destroyed. I pulled the valve up by using needle nose vice grips grabbing from the center and removed the damaged gasket leaving the gasket on the bottom of the valve in place and pushed the valve back down. I blew through the opening to check and see if air ran through and it did not. I put it back together and tried to clear the code but a circuit trouble still showed in that bank but my check engine light and traction control light were off. I test drove it and I no longer had the low speed issue. This is only a bandaid as I know I'll need to replace the valve and probably damaged the valve by forcing it up and down so I am not stating this as a permanent fix but only one that worked for me so far. Good luck!
  12. Aug 24, 2017 at 11:15 AM
    #752
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    This morning I went ahead and replced my bad valves with the doorman 911-643 valves from a Tundra. $200 from Rock Auto delivered. This is actually an easier install that buying a set of Tacoma valves as you leave the rest of the assembly in place and only have to take out 8 t25 screws and a couple hose clamps.
    I've put about 100 miles on the truck today and everything is just fine.
    JuanitoBonito and DriverSound like this.
  13. Aug 24, 2017 at 3:01 PM
    #753
    Hunter.415
    Hunter.415 Well-Known Member
    Pete
    Western mass
    2012 Tacoma short bed 4x4
    Cooper t/a 3
    So you just replaced the 2 valves and not the whole assembly. Do you have any pics.
  14. Aug 24, 2017 at 5:25 PM
    #754
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    No pics. The valves are held onto the cast body with 4 t25 screws each. Pop the screws off, and swap them out. The hardest part is that you need to open up the wording harness slightly to get a little more slack on the valve closest to the firewall because the tundra connector comes out at a different angle.
  15. Aug 24, 2017 at 5:30 PM
    #755
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Another member posted pictures of using the Tundra valves on page 36. Link to that post is here:
    Hunter.415[QUOTED] likes this.
  16. Aug 24, 2017 at 9:11 PM
    #756
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
  17. Aug 25, 2017 at 4:47 AM
    #757
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    The one thing to note on the pictures shown on page 36 is that you do not need to remove the bottom assembly from the engine. Just pull the two valves and swap them.
    vssman likes this.
  18. Aug 25, 2017 at 6:28 AM
    #758
    2011Streaker
    2011Streaker Well-Known Member
    Maine
    2012 DCSB TRD Sport
    Can someone explain the issue with the wiring on the tundra / doorman valves? I get that it comes out at the wrong angle but what is involved exactly in correcting this to work with the tacoma? I couldnt see it in the photos.
  19. Aug 25, 2017 at 6:32 AM
    #759
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    Makes it a lil easier
  20. Aug 25, 2017 at 6:40 AM
    #760
    Hunter.415
    Pete
    Western mass
    Cooper t/a 3
    I have not checked yet , but I think it's just changing how the wire is fastened along the engine to give a little more room to connect to the valve
