Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Aug 25, 2017 at 7:58 AM
    #761
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Throw away the little bracket that holes the wire loom and cut open one of the loops of electrical tape.
    Hunter.415[QUOTED] likes this.
  2. Sep 2, 2017 at 11:22 AM
    #762
    crazeepetrvs
    crazeepetrvs New Member
    forgot to come back and post from a few months ago but since i didnt want to pay for the new pump and valve I ended up just using a bypass kit from hewitt-tech. trucks been fine since I put it in. it needs an extra half a second sometimes to turn over on startup but thats it. I dont have to smog my vehicle unless I sell it so it was a good option for me. but if you have to smog it wont work.
  3. Sep 17, 2017 at 11:57 AM
    #763
    dieselfan
    dieselfan Well-Known Member
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    Hello, If Twalt87 is out there, has your setup with the Tundra valves on the Tacoma valve body proven to work with any problems. It been about 4 months now, that should have given you a lot of starts, I'm really hopeful for a good outcome. My truck is a 2012 and no problems yet, but I'm sure its only a matter of time. This is by far the cheapest fix I' have seen. thanks in advance for the great write up and pictures.
  4. Sep 17, 2017 at 5:31 PM
    #764
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    I did Twalt87's Tundra valves about 3 weeks and 4000 miles ago (I'm a salesman). No CELs. No issues.
    JuanitoBonito likes this.
  5. Sep 17, 2017 at 6:33 PM
    #765
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
  6. Sep 17, 2017 at 6:49 PM
    #766
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Some, left the bottom peice on the truck. I could have cleaned it but here was no where enough to stop airflow. Even if I did, the pipe leading into the lower piece would still be full of carbon.
  7. Sep 17, 2017 at 7:06 PM
    #767
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    If and when my fails, this repair is what I will try first. thanks again for your input.
  8. Sep 20, 2017 at 12:33 PM
    #768
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    mabepossibly, where did you buy the Tundra valve and how much? Thanks
  9. Sep 20, 2017 at 12:36 PM
    #769
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
  10. Nov 6, 2017 at 3:07 PM
    #770
    linker711
    linker711 Member
    Columbus, OHIO
    2012 TRD Sport 4x4
    My 2012 finally joined the club this weekend. Went into limp mode while on the Ohio turnpike near Cleveland during rush hour and was nearly sandwiched between a couple of semis. Was able to limp to my destination while at the same time infuriating every person behind me in the slow lane.
    Pulled the air pump for inspection and found it clogged up with the gummy remnants of the sponge filter. I cleaned out the fan and at least was able to free it up then moved on to the valves. Here I found plenty of carbon build up and degradation of the rubber. I did a pretty through cleaning and a code reset hoping it would get me up in running until I figured out a solution. Luckily no return of the CEL but it will be back soon.
    Also sent in detailed and professional complaints to NHTSA and Toyota yesterday. Was shocked to get a response back from Toyota USA by 8:30 this morning. The rep was empathetic but offered no immediate solution. That being said, she did admit this was a known issue but Toyota did not have enough complaints to prompt a warranty extension similar to the Tundra. Her suggestion was to get everyone on the various forums to send in the complaints en masse to prompt more action. She also strongly recommended keeping any repair receipts for reimbursement in the case of a service bulletin. Not sure if this means anything at all but I hold out hope for some sort of change via Toyota before my CEL flashes again.
    scocar likes this.
  11. Nov 7, 2017 at 5:30 PM
    #771
    Tekcru
    Tekcru Well-Known Member
    Calgary, AB
    '13 TRD SPORT - DCLB Supercharged
    TRD Supercharger, SPC UCA's and ELKA 2.0, DOBINSON SHD Leaf Springs w/ Fox 2.0 rear, ALU-CAB Explorer canopy, Quarantine Restraints Cargo Net, American Racing ATX Series Wheels, BFG 285/70-R17 Mud Terrain, Custom Relentless Fabrication Aluminium Front Bumper, Relentless Ditch Light mounts, Off Grid Engineering Dual battery system, National Luna 60l Fridge/freezer, Prinsu Cabrack, Treeline Outdoors Ponderosa Constellation RTT
    2013 DCLB. Add me to the list with code P2443. Trying to get this paid for via ECP. The dealer just quoted me $1100 CAD in parts.
  12. Nov 8, 2017 at 11:28 AM
    #772
    scocar
    scocar Patron of the Farts
    The sad part is this: The solution is $13 Toyota. Just do it. Oh, plus $100 dealer labor for 10 minutes. :rolleyes:
  13. Nov 8, 2017 at 3:17 PM
    #773
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I finally ordered the uni filter...
    Seeing as we are beginning to have more and more 12+ owners come out of the woodwork with this issue. I don't mind replacing the valves with the cheaper tundra setup, but I'm not paying $400 for a pump that was screwed over by 5cents worth of foam.
  14. Nov 9, 2017 at 6:07 PM
    #774
    Stanky taco
    Stanky taco Well-Known Member
    Auburn
    16 Tundra 1794 CM / 11 FJC / 19 GX460 / prev 13 TACO DCSB OR
    My threw a p2443 the two weeks ago but I had to get to work just cleared it with my scan gauge 2. Hasn’t come back since and i drove 500 miles
  15. Nov 11, 2017 at 7:38 AM
    #775
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    It will...
  16. Nov 11, 2017 at 9:31 AM
    #776
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    So I had my valve replaced... And I have the old unit. Can these be rebuilt or is it just junk now?
  17. Nov 12, 2017 at 12:03 PM
    #777
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    They can be cleaned out to squeeze a little more life out of (possibly). You can also replace the actual valves on the housing. The Tundra setup is about $200 on rock auto. They bolt to a different assembly but are functionally the same.
  18. Nov 13, 2017 at 9:45 AM
    #778
    apoteker
    so i guess the next question is is it worth to try to sell it or just trash it
  19. Nov 13, 2017 at 12:31 PM
    #779
    Large
    Large Red
    just trash the valves, they are useless
  20. Nov 13, 2017 at 2:21 PM
    #780
    apoteker
    recycle?
    i hate to toss em in a landfill... if anyone wants my old one...it's yours (local pickup in so oregon or you pay for shipping)
