Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Jan 16, 2018 at 6:08 AM
    #841
    dieselfan
    dieselfan Well-Known Member
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    Y2Kbaja; My p2443 code came back last night, I have appointment soon at dealership to read the code and have what ever fixed. Do you know when this code is shown does the dealer replace just the valves and the pump or just the valves? Do you know if this p2443 will at sometime change to the limp mode code of P2440 and p2442? Thanks for breaking the good news to all of us and thanks for any input to my questions!
  2. Jan 16, 2018 at 12:56 PM
    #842
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    5 parts are listed: air switch valve assy (new #25710-31022), cover installed, air pump assy, and 2 gaskets. Keep in mind YOUR VEHICLE MUST BE EXPERIENCING THE CONDITION BEFORE TOYOTA WILL DO ANY WARRANTY WORK. This is NOT a recall! The CSP refers back to the TSB which says P2440/P2442. I don't know of the technicals after that.
  3. Jan 16, 2018 at 1:27 PM
    #843
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Well my CEL had on for about 3 years because of a code related to the Secondary Air Injection pump/system. I though it strange because I have a 4 cyl, but I had been saving up for the plug and play solution anyways. Recently my airbag light went on, and many other electrical problems starting occurring intermittently. I thought all of this was unrelated, but when I took my truck to the dealership for the airbag light, it was discovered that a rodent had been chewing on the wires in my truck (I lived in a rural area for quire some time), thus causing my myriad of electrical issues. The new wiring harness in certain areas cured my CEL! I know it doesn't really help anyone here, and for that i apologize, but I wanted to share so as to rectify any bashing of Toyota I had previously done in this thread.
  4. Jan 16, 2018 at 1:46 PM
    #844
    Y2kbaja
    Sacramento
    Total Chaos
    As the tech notes might say, "fire the cat!"
    LocoLocal[QUOTED] likes this.
  5. Jan 16, 2018 at 1:49 PM
    #845
    LocoLocal
    Large American
    What's funny is that we had 2 barn cats! But, I am wondering if the cats pushed the mice out of the barn and into my engine bay. Tech also said it could have been squirrels, and we also had a groundhog problem. So, who knows? I had found evidence of mice before (dropping and chewed up corn kernels and cob), but never thought their chewing the wires could of been a source of my problems.
  6. Jan 16, 2018 at 2:36 PM
    #846
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    My code is p2443 secondary valve stuck closed valve 2, that's what my scanner states. service man today stated codes from p2440- p2444 are covered I'll let you all know thursday afternoon after they evaluate my truck
  7. Jan 16, 2018 at 8:15 PM
    #847
    Undertow
    Undertow Well-Known Member
    CT
    2020 Cement DC OR 6MT
    Stock
    You are lucky on the 2443 code as your truck is not/will not go into limp mode and is fully drivable. Those of use who have 2440 and 2442 codes, the truck immediately goes into limp mode.
  8. Jan 17, 2018 at 6:09 PM
    #848
    donniep
    donniep New Member
    2012 prerunner
    Guys I can confirm Toyota is fixing this issue under warranty. I put mine in shop last week with p2442 codes, was going to cost me $2052.32 for repairs. I picked my truck up today and was informed that there was no charge, Toyota was paying for the fix so call your dealers if you have had this fixed, Toyota owes you money back.
    waynelauld, TomTwo and 175908 like this.
  9. Jan 18, 2018 at 3:13 PM
    #849
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    Had my 2012 trd or 4.0 at the dealership for p2443 like I said earlier posts. The mechanic found and cleared the code said he tested system 3 times and no code came up. He opened up the air pump and found no water present. He felt that the valve must have gotten a tiny bit of water in the valve and froze enough the it was able to throw the code. He said that this happened to some Tundra's in the past when they had this happen. The service man did say I was the first Tacoma to be look at under the warranty. They did this with out charging me anything and said the warranty was good for 10 years or 150k. But I know it is only a matter of time!
  10. Jan 18, 2018 at 4:29 PM
    #850
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Mine started out like yours and acted up when cold, 20k miles later they were done. I think where your at now is the start of the plunger seal in them going bad.
  11. Jan 18, 2018 at 5:22 PM
    #851
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    At least we now have the warranty 10 years from the day your truck went into service.
  12. Jan 18, 2018 at 5:24 PM
    #852
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Anybody have a link to the Warranty info in case we run into a not so brite Service Manager.:facepalm:
  13. Jan 18, 2018 at 5:34 PM
    #853
    dieselfan
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    It is called CSP2HA this was giving to me by the Toyota rep I spoke to.
    JuanitoBonito, sioux and TomTwo like this.
  14. Jan 18, 2018 at 5:42 PM
    #854
    330d
    330d Active Member
    Caleb
    Upstate NY
    Shopping for it....
    Anyone know if they are reimbursing for parts previously purchased?
  15. Jan 26, 2018 at 10:37 AM
    #855
    Undertow
    CT
    Stock
    All fixed. They replaced the pump, valve and gaskets, along with a new cover for moisture resistance. Cost was $0 point 0 dollars.
    JGO, 175908 and TomTwo like this.
  16. Jan 26, 2018 at 11:22 AM
    #856
    12tacop
    12tacop Well-Known Member
    2012 DCSB 4x4
    Excellent, thanks for keeping us posted.
  17. Jan 28, 2018 at 6:20 PM
    #857
    TacomaBaja
    TacomaBaja New Member
    Wesley
    Tacoma Baja Edition
    Stock except for the 2012 Baja package
    Yeah my 2012 Tacoma Baja edition is on its way out I do believe, Friday my truck went into limp mode and wouldn't let me get above 50mph on the way home. It was the same issue with the Secondary air valve switch stuck open. Weird thing is that once I made it home my truck was fine but still had the codes/lights on my dash, watched some YouTube videos on it and it's a piece of cake to replace since I worked on cars for a few years in the automobile business.. I checked the fuses in the fuse box under the hood and replaced the red 50 amp fuse for the switch valves and haven't had another issue yet. The blue relay for the blower motor was good so didn't mess with it.
  18. Jan 28, 2018 at 7:16 PM
    #858
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    yeah i spent a ton of time the phone with toyota when mine went out on my '12 before i hit 50k miles and they gave me the runaround
    i paid a lot of money to have this fixed when toyota should have taken care of it under warranty
  19. Jan 28, 2018 at 8:07 PM
    #859
    scocar
    scocar Patron of the Farts
    Excellent. Now take the top off, remove the shitty foam internal filter, and install the uni filter.
    Actually, It would be great to see if they are still using that same shitty internal filter that can be ingested.
    TomTwo likes this.
  20. Jan 29, 2018 at 6:41 PM
    #860
    im4u2nvss
    im4u2nvss Well-Known Member
    Jesse
    2012 DC
    Just got my letter in the mail today about the 10year 150k extension on Secondary Air Pump. Nice to know I have 4 more years to not worry about this possible expense.
