Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Feb 2, 2018 at 10:20 AM
    #861
    waynelauld
    waynelauld New Member
    Wayne
    Lexington,SC
    2012 Tacoma TRD Off Road Nautical Blue
    3"Lift,Tires.Window Shades,Bug Deflector,Bull Bar,Tool Box
    I had the same codes come on last night and truck went to limp mode...2012 Tacoma. My Service Guy made a copy of the warranty Service Bulletin.
    Taking it in Monday to have work done. Here is a copy of the Bulletin.20180202_130722.jpg
    Sub_Par likes this.
  2. Feb 2, 2018 at 1:06 PM
    #862
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    Does anyone know what the difference is between Primary and Secondary coverage? The bulletin states Primary coverage expires February 28th, 2019 and Secondary coverage is 10yrs or 150k miles. Is there a different monetary coverage for the two different terms?
  3. Feb 2, 2018 at 3:17 PM
    #863
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    thank you for posting!
  4. Feb 3, 2018 at 6:06 AM
    #864
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    Primary coverage is unlimited mileage until February 28th, 2019.
    After that date, secondary coverage will be considered, 10 yrs since first day the truck was in service or 150 miles
  5. Feb 3, 2018 at 8:59 AM
    #865
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Wow Toyota stepping up and fixing the issues. This is great. But the real question is whether this includes an update to the ECU so that the pumps comes on with shutdown too, otherwise the new parts will fail just like the old ones.
  6. Feb 5, 2018 at 3:11 PM
    #866
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    I received my notice letter today. That’s awesome that Toyota is taking care of the problem. Nice to have some peice of mind if the system fails.
  7. Feb 5, 2018 at 3:34 PM
    #867
    12tacop
    12tacop Well-Known Member
    2012 DCSB 4x4
    You received a letter for the 2440-2443 codes that are associated with the parts responsible for codes? What did it say?
    Edit: Post a pic of letter if you dont mind.
  8. Feb 5, 2018 at 3:54 PM
    #868
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Look up a few posts, someone posted it already.
  9. Feb 5, 2018 at 4:00 PM
    #869
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
  10. Feb 5, 2018 at 4:01 PM
    #870
    12tacop
    2012 DCSB 4x4
    Awesome, thanks for posting
  11. Feb 5, 2018 at 4:05 PM
    #871
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
    I wish they would just replace the system before it goes out. I have 91,000 on the clock. Mine will probably go out with 151,000 and won’t be covered. Doesn’t say anything about a how they fix the problem though. If they just replace the parts, it still doesn’t fix the problem of the pump not running when you shut the truck off. Who knows.
  12. Feb 5, 2018 at 4:07 PM
    #872
    12tacop
    2012 DCSB 4x4
    Exactly what I was thinking also.
  13. Feb 5, 2018 at 4:48 PM
    #873
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    I thought someone had posted that they're new part numbers, meaning they're not replacing the parts with the same faulty ones. Not sure if the new parts hold up any better though.
  14. Feb 5, 2018 at 5:20 PM
    #874
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
    Hopefully. I think 13-15 model yrs. also had failures. Maybe it’s a new part altogether. Wonder if anyone’s had the service done under this csb yet??
  15. Feb 5, 2018 at 5:35 PM
    #875
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    I would love to get it done but my codes are completely random and haven’t come back in months. I’ll wait until they do and take it straight to the dealer.
  16. Feb 5, 2018 at 5:50 PM
    #876
    poseytaco
    Nicholas
    Indiana
    2012 Off-road
    image.jpg For anyone interested, this was also included in the letter. A reimbursement checklist for those who have already done the repair.
  17. Feb 5, 2018 at 6:05 PM
    #877
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Brought my truck to the dealer with P0418 and pending 2445, they are replacing both pump and valve when the parts come in. Glad Toyota is finally doing something they should have done years ago.
  18. Feb 7, 2018 at 9:38 AM
    #878
    jtv
    You can make it go down at 145k miles by feeding water through the pump or break some blades or you worry too much.
    I bought the by pass kit 6 months ago at 74k miles in case I need it immediately. I am at 85k now without a problem. Look like I will not need it for a long time
  19. Feb 7, 2018 at 11:56 AM
    #879
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I mean the new part number is changed by 1 digit right? So is it possible they just changed it to reflect when repairs went into effect/track the ones that have been replaced? Probably the same crappy valves, but maybe the pump has a new foam filter style? No one has said if it is the same inside or not yet.
  20. Feb 7, 2018 at 11:58 AM
    #880
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I wouldn't be surprised if the only change to the pump is to connect the cover onto it. Lol
