Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Jun 19, 2020 at 4:27 PM
    #1081
    roliver247
    roliver247 Member
    New York
    2015 TRD Pro
    TRD S/C, TRD Cat Back Exhaust
    Yes, they did replace the switch valve. Definitely last year, I can't find the invoice from 2018 right now but I think they did that time too.
  2. Jun 19, 2020 at 5:43 PM
    #1082
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    Are you using crap gas like from Sams or the cheapest place you can find? Try using some ethanol free or Chevron or Shell (they have techron). or mid grade. Had it decarbonized at the dealer or use a an injector cleaner? Just a few ideas to see if the codes will clear.
    roliver247[QUOTED] likes this.
  3. Jun 19, 2020 at 11:29 PM
    #1083
    roliver247
    roliver247 Member
    New York
    2015 TRD Pro
    Primarily Mobil or Shell and always premium (min 91), i've done injector cleaner but I could try again and look into decarb perhaps!
  4. Jun 20, 2020 at 7:10 AM
    #1084
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    I am no expert on this, but Tacoma manual says use 89 and "they" say you should only use mid or premium if the manual says you need to use it to prevent knocking (usually only on high performance engines. You may want to dial it back to low grade and see what happens.
    I only use 89 on my Tacoma and it never knocks...I use a Seafoam in the tank at each 5K oil change.
    Lester Lugnut likes this.
  5. Jun 23, 2020 at 10:44 AM
    #1085
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    Mine Tacoma just tossed out these codes and went into limp mode on the highway. Thankfully I had my OBDII Reader in the truck and was able to reset. I called Toyota and was told the service campaign didn't have a mileage limit, is anyone able to confirm this? Id hate to bring it to a dealer and then be told that the limit was 150k. My '12' currently has 200K on it.
  6. Jun 23, 2020 at 10:47 AM
    #1086
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I would call Toyota’s Cust. Service number and get it straight from the horses mouth
  7. Jun 23, 2020 at 10:48 AM
    #1087
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    https://www.tacomaworld.com/threads/toyota-now-covering-secondary-air-injection-pump.536972/
  8. Jun 23, 2020 at 10:57 AM
    #1088
    fadippides
    NEPA
    12 TRD Off Road
    I saw that thread which is why I'm not sure that its covered. I called the Toyota recall number and they said they don't see a mileage limit on it, but I dont know if they just weren't looking at the right thing.
    When I look in Owners Link it shows:
    Title
    Special Service Campaign - 20TC01 - (Remedy Notice) - Certain 2012 Model Year Tacoma - Air Injection Pumps and Air Switching Valves
    Status
    Remedy Available
    Description
    There is a possibility that moisture in the air may cause a filter in the vehicle emissions system to degrade. This degradation could cause damage to other parts of the vehicle emission system and illuminate the check engine light (Malfunction Indicator Light).
    Remedy
    Any authorized Toyota dealer will inspect the vehicle. Based on this inspection the dealer will repair the air injection pump and install an improved filter, or replace the air injection pump with one that contains an improved filter, as needed, FREE OF CHARGE. The dealer will also replace the air switching valves in the vehicle emissions system FREE OF CHARGE.
    Campaign Date
    May 28, 2020
    Dealer Reference ID
    20TC01
    The campaign date is listed as May 28th, 2020 so I don't know if its a newer one or not.
  9. Jun 23, 2020 at 12:10 PM
    #1089
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    First warranty -unlimited mileage first 10 yrs
    Second- 150k. I think y r good to go for the first one. Take it into the dealer.
  10. Jun 23, 2020 at 1:31 PM
    #1090
    fadippides
    NEPA
    12 TRD Off Road
    Thanks, I will have to set an appointment with the dealer. I got it back in limp mode so I can have it towed there.
  11. Jun 30, 2020 at 11:53 AM
    #1091
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    Today, I just took my 2012 in for oil changes and brakes... The Secondary air injector had been changed out about 2 or 3 years ago with no problems since then. The service manager informed it was under recall and they replaced secondary air injector with "all new parts, that is better than the previous"
  12. Jun 30, 2020 at 12:54 PM
    #1092
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    Would love to see the recall documentation so I could find out if it covered my 2013. No issues yet, but free part are always better than paying for them.
  13. Jul 9, 2020 at 8:56 AM
    #1093
    fadippides
    NEPA
    12 TRD Off Road
    Just talked to the dealer. Campaign was performed on the truck (air injection). It did fail the frame inspection so it is getting a new frame.
  14. Jul 9, 2020 at 10:54 AM
    #1094
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I also had the same issue at 35k. Paid out of pocket for new valves, removed stock foam filter crap and used a small filter made by uni. Several days ago I received a letter in the mail from toyota. They are finally acknowledging it is a problem and according to the letter they will reimburse customers for repairs but they have some stipulations. Must be checked by toyota certified shop, must have receipts verifying vin, date, and specific information regarding repair. This didn't help me but it is a step in the right direction. Like others said you should contact toyota and ask about it. The main problem with the pump as reported by owners is the filter degradation resulting in it being sucked into pump and damaging fan blades which then travels to valves blocking them from operating correctly. Pump is more than valves so I removed the foam and used a different filter. Mine personally was deterioration of the valves themselves from condensation build up but it seemed proactive to ditch the foam. As for warranty issues, the filter is easily removed and foam reinstalled before bringing to a stealership to avoid issues. Just fyi, there is a class action lawsuit against toyota with hundreds of people including myself on the list. I would assume that is why toyota is starting to recognize that there is a problem with the system. I can't speak for others but I don't want anything from them besides to not be held accountable for it failing and repairs to be done on their dime. If it would help I could possibly photograph the document sent to me and send it to you. Good luck, and for what it's worth I still believe that the tacoma is still one of the best vehicles for the money on the road today.
    Mully likes this.
  15. Jul 10, 2020 at 10:15 AM
    #1095
    roliver247
    roliver247 Member
    New York
    2015 TRD Pro
    So random update on my CEL issues, twice now since my post a few weeks ago, the lights have turned off (second time being today). Only common denominator is that both times it has been extremely hot and humid outside. I have no idea if its relevant, just thought I'd share as it's kind of baffling me. I'm hoping I can get a quick inspection before the lights come back on.
  16. Jul 10, 2020 at 8:41 PM
    #1096
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    If possible get a code reader on it when the lights are on. At least that should give you some idea where to start.
  17. Jul 31, 2020 at 8:28 AM
    #1097
    roliver247
    roliver247 Member
    New York
    2015 TRD Pro
    It was the p2443 code again, it'll be in for diagnostics again in a week or so. *Fingers crossed*
  18. Jul 31, 2020 at 12:43 PM
    #1098
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Ya thats your secondary air injection valves. On mine it was stuck open. The problem is it has a solenoid on it that opens and closes depending on the temp of the engine. Mine had deteriorated to the point that it wouldn't seal properly so it threw codes. Did your truck go into limp mode? Mine did and it was no fun, couldn't get past 30mph. Good news is toyota is finally stepping up and admitting it's a problem. They should cover it and repair the issue now for free, I think. Good luck and be aware if it does go into limp mode it severely limits the trucks performance so don't try to jump out into traffic. IMO, it's dangerous but I am definitely no expert.
  19. Jul 31, 2020 at 1:04 PM
    #1099
    roliver247
    roliver247 Member
    New York
    2015 TRD Pro
    Luckily its never gone into limp mode, I've read the horror stories on here. They've replaced the entire pump under warranty in 2018 and 2019, someone mentioned making sure they replace the valves which I've noted for this time around, I've got to check their notes if they did or not on the previous times. 2018 the light stayed off a day, 2019 was on before I could even get home. They eventually decided it was a clogged intake and cleaned the entire manifold (also under warranty), light came back on the afternoon I got the truck back. I get the sense the dealer is sick of me at this point :rofl:
    SamuelJ[QUOTED] likes this.
  20. Oct 12, 2020 at 7:04 PM
    #1100
    3NDLESS
    3NDLESS Member
    California
    '15 DCSB 1GR
    My 2015 1GR-FE just got it's valves stuck at ~61k miles. I turned off the car a while after cold start and instead of the usual whirring noise, I heard a surge. Checked pump, a bit dusty and ashy from the recent fires but nothing alarming. The valves though, caked in emissions though I haven't checked if they were actually stuck - but I'm gonna assume they are. Will get to cleaning it and pray that it'll free up the diaphragm or does something. Those repair bills don't look that enticing, especially for a young teenager like me.
