Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Apr 3, 2024 at 8:13 AM
    #1141
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I did the Hewitt kit and my truck is still throwing P2440 and P2442 codes. Yay me.
    Lucky for me I have an ultra gauge and can just delete the codes on the fly while driving. Shouldn't have to though...
    Captainskidmark likes this.
  2. Apr 5, 2024 at 6:12 AM
    #1142
    Slashaar
    Josh
    Kansas City, MO
    I'd buy a VF/HP tuner or equivalent that can turn off ECU reporting on the system, and then just delete the whole thing.
  3. May 16, 2024 at 6:13 PM
    #1143
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    2014 with a P2443 code have the filter on since 10k pos
  4. May 16, 2024 at 7:26 PM
    #1144
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    See my posts on the previous page. I had the same thing happen one morning pulling out of my garage. I pulled the pump apart and cleaned everything I could including sanding the inside of the top where the white fan blades were clearly rubbing. I cleared the code after putting it all back together and have not had an issue since. (Knocks on wood)
  5. May 17, 2024 at 2:44 PM
    #1145
    Dacapster
    Hugh
    14 trd
    Many coming
    So I tool the blower motor apart, Looked good. put back together. No fix, Disconnected both Vac lines to the valve and drove it 10 miles.. no fix Bat neg terminal off 3x times Still had thge P2443 code, SO I start the truck go out to the pump and pinch the line twice while the pump is in operation. Shut down Check codes P2443 is gone! I sure its only a matter of time to when it comes back.
    Slashaar likes this.
  6. May 20, 2024 at 5:04 AM
    #1146
    Slashaar
    Josh
    Kansas City, MO
    Those codes are 'valve stuck open' typically. So the valves are where you need to take a look.
  7. May 21, 2024 at 5:55 PM
    #1147
    Dacapster
    Hugh
    14 trd
    Many coming
    P2443 is stuck closed not open
  8. May 22, 2024 at 9:36 AM
    #1148
    Slashaar
    Josh
    Kansas City, MO
    Either way.
    I got P106B the other day. That's a new one. I have the Hewitt kit...
    Looking to buy the HP Tuner now.
  9. Sep 30, 2024 at 2:47 AM
    #1149
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Hp tuner,scan gauge 2 or 3,ultra.
    Whats the best option now days?
    Been running an old scan gauge in my 2000 4runner for years but just got a 2012 tacoma.
    62000 miles in mint condition and two months past expiration on recall.
    What about ott tune on the 2012,is that or the Hewitt the best option?
  10. Sep 30, 2024 at 9:07 PM
    #1150
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I have a Scangauge 2 in mine, does everything I need it to do. I believe the 3 is just a bigger screen that is touchscreen and color, allowing for more PIDs to be displayed at once.
    You would have to check with @JustDSM but I believe they are only doing emissions legal tunes.
    Most legit tuners have stopped doing any kind of "emissions defeat" tunes for fear of getting fined out of existence due to all the recent EPA actions against such things.
    You can still buy HPTuners and disable the codes yourself as far as I know but I doubt any tuner would do it for you at this point.
    The HewittTech module is certainly the easiest option but the cost is right up near what the MPVI and credits for a tune would cost so...
  11. Oct 3, 2024 at 8:50 AM
    #1151
    Slashaar
    Josh
    Kansas City, MO
    This.
    Just get an HP tuner, you can disable the reporting in the ECU and then it won't even come up. Being the cost is the same as the Hewitt Tech (with the sim sensors at $250 a pop on top of the Main unit itself...), just get the HP Tuner. Then you can get a nice baseline tune and delete whatever you want all for one price.
  12. Nov 24, 2024 at 2:40 PM
    #1152
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    Please tell me what the v6 tuner is and as much info you can give please.
  13. Nov 24, 2024 at 2:42 PM
    #1153
    Littlemule1
    More info on hp tuner and where I get it
    Slashaar[QUOTED] likes this.
  14. Nov 25, 2024 at 5:21 AM
    #1154
    Slashaar
    Josh
    Kansas City, MO
    HP tuner's website or through Overland Tailor Tuning
    You buy the Dongle + credits (check HP's Website for the amount), then you get a Vin locked tuner that you can hook up to a computer running their included software to tune your engine. But you can also turn off CEL reporting for various things, such as the Secondary Air Injection System. This allows you to completely remove the system and either swap to non-SAIS headers or bolt on block off plates.
  15. Nov 25, 2024 at 7:25 AM
    #1155
    Littlemule1
    Thanks
    Seems pretty expensive and complicated.
    5hundo
    Does this device need to stay attached to keep changes?
  16. Nov 25, 2024 at 12:23 PM
    #1156
    Slashaar
    Josh
    Kansas City, MO
    Nope, writes to the ECU. The Hewitt kit costs $500 just for the brain and another $500 for the two sim valves and that has to stay attached. So HP Tuner is actually cheaper.
  17. Nov 25, 2024 at 12:55 PM
    #1157
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Even with my full delete kit from Hewitt, once in while I’ll get the codes when there’s a lot of moisture in the air.
  18. Nov 25, 2024 at 6:44 PM
    #1158
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I'm now getting the P2443 code and learned about the Hewitt kit but now see this HP Tuner thing might be better to do? Get block off plates and disable the SAIS via a tune?
  19. Nov 25, 2024 at 6:47 PM
    #1159
    Littlemule1
    i was just reading the hp tuner website and if im reading it right the epa has made hptune only delay codes and doesn’t fully work as a delete option
  20. Nov 26, 2024 at 5:24 AM
    #1160
    Slashaar
    Josh
    Kansas City, MO
    Not sure to the validity of this. As far as I know, you can turn off reporting in the tuning software. I haven't had hands on experience with it though. OTT will also deny any ability to do so.
    You turn off the DTC and then the ECU reads it as though the SAIS system was never there to begin with.
    Doing a little google-fu, I've come up with this:
    from the editor menu select the edit on the top, engine diagnostics, click the DTC tab, and go down to the codes associated with the SAI System and set them all to the way you want them off, either disabled, or just no error reported.
    Even with the Hewitt system I still get error codes on occasion, even after them sending me a new unit. Nothing like starting the truck into limp mode.
