Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Dec 23, 2015 at 9:48 AM
    #101
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    If you don't have any check engine light on, then you're ok. From what I understand, this emission system runs when the engine is cold. To fool the ECM to run richer, in order to heat the catalytic converter to burn the exhaust fumes quicker. After turnning the engine off, it helps burn off exhaust fumes. If you're out of warranty, before it goes bad suggest getting a by-pass kit, it'll save you a lot of money and headaches. https://hewitt-tech.com/store/index.php?l=product_detail&p=7
  2. Dec 23, 2015 at 10:08 AM
    #102
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    That bypass kit says only up to 2007. Is that just not updated or is there nothing for 2008 and up models?
  3. Dec 23, 2015 at 10:27 AM
    #103
    billybob50
    Bob
    It's best to contact them. I just found out they're offering air injection pumps. As these trucks/cars get older there's bigger market for selling replacement parts.
    deeezy[QUOTED] likes this.
  4. Dec 23, 2015 at 10:35 AM
    #104
    deeezy
    Dana
    Hawaii
    Okay. I don't have any problems with my truck now, but you never know what'll happen in the future.
  5. Dec 23, 2015 at 11:33 AM
    #105
    billybob50
    Bob
    Toyota like all manufacturers have designed some flaws into their vehicles. This gets them to sell not only new cars but also parts that fail and service to install it. If you have time suggest to take a look at the top plastic cap of that air injection pump. The one torx screw located on top, right in the middle, unscrew it. There's a small cheap block of foam (it's the filter) hopefully it hasn't come apart due to age. When it does come apart it'll get sucked into the impeller, burning up the motor. In which it'll be a $1,000 for a new one, and if you think of not pay attention to it after it fails. It can cause a engine fire or the engine to go into a limp mode until fixed. The dealership normally wants to change out two parts, the valve and pump which runs well over $2,000 for 4 cylinder and 6 cylinder is over $3,000. https://www.youtube.com/watch?v=Q3Zoc2eqxqo
  6. Dec 30, 2015 at 7:53 AM
    #106
    NCTacoma
    NCTacoma [OP] Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    So, trying to determine what parts are needed for this repair. Mine is currently at valve stuck closed. Is this the valve? [​IMG]
    I would assume so.
  7. Dec 30, 2015 at 1:07 PM
    #107
    billybob50
    Bob
  8. Jan 12, 2016 at 7:44 AM
    #108
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Has anyone tried pouring seafoam in the hose and letting the pump blast seafoam into the valves to decrease carbon build up? I saw some bmw and porsche guys attempting this.
  9. Jan 14, 2016 at 6:58 AM
    #109
    NCTacoma
    Caleb
    CLT, NC
    Replaced bank 1 solenoid/valve with a new one, still showing the same code. I'm about over this shit already
  10. Jan 14, 2016 at 7:18 AM
    #110
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    My truck has only ever shown this po2440 code twice. Both times after restarting the engine hot after a short shut off time (like maybe 3-4 minutes) I wonder if the engine coolant temp sensor might have something to do with it...not sure. Again only twice in 5 plus years and stays off after clearing the code.
  11. Jan 14, 2016 at 7:33 AM
    #111
    billybob50
    Bob
    Did you disconnect the battery, to clear the codes? Suggest when you finally fix everything purchase this by pass kit so your system won't fail in the future. https://www.hewitt-tech.com/store/
  12. Jan 16, 2016 at 10:53 AM
    #112
    NCTacoma
    Caleb
    CLT, NC
    I cleared them with the battery and an obd reader.
  13. Feb 6, 2016 at 7:13 AM
    #113
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    2012 with 36,000km on mine. Havent called toyota yet. Being a mechanic my self i have a hard time dealing with rushed warranty work. I am getting code p2442 it has come on 2 times after sitting for a few hours, so when cold. Ive just been clearing it and driving away. Has any one had any issues doing this? Never had to touch this system before.
  14. Feb 6, 2016 at 8:59 AM
    #114
    billybob50
    Bob
    Not knowing what country you're in sugest to look at your owners manual and check you emissions warranty time/KM. Then call your Dealership Service Dept, inform them of the code. Hopefully they'll set up an appointment and cover it under warrenty work. It's about $2,000 for the repair to be done from the dealer. You buying the parts from an online part store and doing the work about $200. https://www.tacomaworld.com/threads/secondary-air-injection-system-p2440-and-p2442.370792/
    koditten likes this.
  15. Feb 6, 2016 at 3:36 PM
    #115
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    One time I removed the intake system to change spark plugs and forgot to reconnect one of the very small vacuum tubes (1/4" I think) and it threw a P2440 code. Might be a good idea to check those connections.
    Truck is 10 yrs old now, never had any issues with the air injection system.
  16. Feb 8, 2016 at 3:17 PM
    #116
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    My truck just graced me on the way home this evening with 2440 and 2442. Valve stuck open again, last time I was at 32k when it happened. Took it to dealer, they tested system and cleared code all is well they said. Now here I am at 53k same codes, I cleared them 3 times on my scan gauge on the way home so far. Now it doesn't seem to be coming back, fingers crossed.
  17. Feb 9, 2016 at 4:35 AM
    #117
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Well no such luck for me, truck keeps popping the codes and going into limp mode. Have you guys been able to have this covered under the powertrain warranty or should I not even waste my time with the dealer? I did take it in for the same issue when I was under the 3/36k warranty so maybe that will help me out since it was documented as an issue.
  18. Feb 9, 2016 at 5:07 AM
    #118
    nhtundra
    nhtundra Well-Known Member
    NH
    2015 Dcab Sport Barcelona Red
    NCTacoma, Did you ever get this problem fixed?
  19. Feb 9, 2016 at 5:25 AM
    #119
    billybob50
    Bob
    You could try, but if I had to guess. It's now on your dime $2000!
  20. Feb 9, 2016 at 6:31 AM
    #120
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Seems crazy to me that it wouldn't be covered under powertrain or emission warranty. I'm hoping since I had the issue before and its documented that they will take care of it. I just stopped by the dealer and they cant look at it until thrusday..so in the meantime I have to keep driving this thing around in limp mode holding up traffic. If they make it fall on my dime ill trade the truck off before I go sending 2k on it, unbelievably a truck with 53k is riding around in limp mode with a problem Toyota knows about but wont help us out on. Fingers crossed for Thursdays appt. I will keep you guys updated.
