Secondary air injection switching valve.......?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NCTacoma, Jul 17, 2015.
  1. Feb 14, 2016 at 4:48 PM
    #161
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    I found the AIP parameters and it looks like mine is running correctly, they bypass we are all talking about makes the truck think its below 40* therefore keeping the system from running.
    "pxsp is correct that the AIP mode will have no effect on an emissions test. The AIP system would not normally operate during an emissions test. It only functions under a specific set of conditions. These are from the AIP system description.
    Operation Condition :
    Engine Coolant Temp. 41 to 104F (5 to 40C)
    Intake Air Temp. 41F (5C) or more
    The only condition where the pumps operate is when the engine has been off long enough for the coolant temp to get below 104 degrees and the outside air temp is above 40 degrees.
    SteveJ's original AIP mod (and pxsp's 2nd generation mod) prevent the operation by telling the system that the air temperature is below 40 degrees."
  2. Feb 14, 2016 at 4:49 PM
    #162
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have the proto type to the above system. The cost is about $45 to build your own. Might want to look into that before dropping the long dollar that they are asking.
    I'm on my phone, so searching for my instructions isn't going to happen until I get to a computer tomorrow.
    12TRDTacoma likes this.
  3. Feb 14, 2016 at 4:52 PM
    #163
    koditten
    Kirk
    Central Michigan
    The o nly thing it would fail would be the "visual test". Would have to be a pretty sharp tech to see the 2 18 gauge wires going into the engine loom.
  4. Feb 14, 2016 at 5:47 PM
    #164
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh yeah, by no means am I saying that a failing AIP system would cause the truck to fail smog. UNLESS the pump itself was stuck on due to a bad relay or something, which would radically change and affect the emissions a negative way during fuel control.
    The only other way the pump system would cause a smog issue is if it triggered the MIL to trip on or leave a pending trouble code which the OBD 2 reader could pick up on.
    By successfully bypassing the system, however, the computer would be tricked into thinking all is well and never cause an issue during smog, as an AIP individual test has never been a requirement for an OBD 2 equipped vehicle in the CA smog program.
    Interesting that they don't work under 40*... possibly that does have to do with "protection" of the system from trying to work when it could potentially be frozen is my idea behind them disabling it's functionality.
  5. Feb 15, 2016 at 5:14 AM
    #165
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    https://www.hewitt-tech.com/store/ Hopefully they sell a kit for your Model. When I purchased mine the kit came with two block off plates, so their was no way hot exhaust gasses would back feed into the hoses, rubber, and plastic pieces. As our Trucks get older, more of this stuff is going to fail. Other part suppliers are offering new or rebuilt parts to the public. http://www.toyotamarinparts.com/p/T...System-Control-Valve/48195687/258600P010.html
  6. Feb 15, 2016 at 9:46 AM
    #166
    koditten
    Kirk
    Central Michigan
    Found the original PDF that I used to build my by pass for the Tundra. I'm willing to bet most everything i s the same for a V-6 Tacoma.
    If you have the ability to hook up your own off road lights using relays, you can do this mod. It really is electrical 101.
    I hope my computer skills are up to sending over the PDF.
  7. Feb 15, 2016 at 2:15 PM
    #167
    Twalt87
    Twalt87 Well-Known Member
    Travis
    Vancouver island Bc
    Thank you for this. Going to get some resistors and give this a try asap. the bypass kit is a week or 2 away for me, so this is alot quicker and cheaper. Will post up pics of anything different with the 12s
  8. Feb 15, 2016 at 2:59 PM
    #168
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Resistor idea is genius.
    Ill have to note when my 13' runs, but i know id does on startup and shutdown almost always when its a cold start. Really cold starts, im not sure, never taken notice of it when i start in freezing temps.
  9. Feb 16, 2016 at 4:21 AM
    #169
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Thanks for the PDF! Twalt keep us updated in how it works out on our trucks, good luck!
  10. Feb 16, 2016 at 4:40 AM
    #170
    koditten
    Kirk
    Central Michigan
    You're welcome.
    Now someone with a second gen Tacoma do this and report back. I'm just as curious as others.
    Later
    Kirk
  11. Feb 16, 2016 at 5:57 AM
    #171
    billybob50
    Bob
    This seems to be a MUCH cheaper fix, than what https://www.hewitt-tech.com/store/ has to offer! I remember installing the plug and play kit. After I installed it I was having issues, cause the air injection motor was bad. He replied that that the air injection system had to be in working order for his by-pass system to work. I hope there's a follow up on this, to verified the color wires and connections. One thing on landing wires on the starter relay. Had issues with getting a good contact with the blade, so I made a small notch/grove in the blade close to the body and solder the wire to the blade.
  12. Feb 16, 2016 at 3:50 PM
    #172
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I was just thinking about this bypass mod and we will still need to install block-off plates on the exhaust tubes or else the system will detect the exhaust pulses and still set a code for the valves stuck open.
  13. Feb 17, 2016 at 11:31 AM
    #173
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I read where that is true, but what is its purpose other than emissions?
  14. Feb 17, 2016 at 11:45 AM
    #174
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's what I am thinking myself. So I am wondering if we'll still have to purchase block off plates anyways.
  15. Feb 17, 2016 at 1:36 PM
    #175
    nd4spdbh
    SoCal
    It is 100% an emissions item... id fight them like hell to explain how it is not.
  16. Feb 17, 2016 at 2:02 PM
    #176
    NCTacoma
    NCTacoma [OP] Rather be in the mtns
    Caleb
    CLT, NC
    Sold- Searching for 1st gen
    Who gave you this answer? Corporate? Dealer?
  17. Feb 17, 2016 at 4:01 PM
    #177
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That was Corporate, but since visiting the dealer that has changed and we are back to sorry its only 3/36k and we don't care that the truck was in at 29k with the same issue as was my case. I love how they don't let it fall under the emissions when that's its main purpose or powertrain when it places the truck in limp mode rendering it useless drive. I have a case open with Toyota on the issue but after todays most recent conversation with them it looks like they could careless. So over $500 they have lost a customer as this is the last Toyota I will ever buy, I have never had a vehicle have a failure like this with such low mileage. Its unacceptable and on a part Toyota knows very well has issues, but that seems to b the common theme with them as a manufacturer.
    We will have to purchase block off plates for a bypass to work or the valves will still throw codes for stuck open/closed.
  18. Feb 17, 2016 at 4:52 PM
    #178
    nd4spdbh
    SoCal
    alls im reading is, glad i got a 13 thats programmed to run this on shutdown to clear condensation!
    Still bought a uni breather, and am going to use that instead of the foam that will end up deteriorating and clogging everything up.
  19. Feb 17, 2016 at 6:25 PM
    #179
    NCTacoma
    Caleb
    CLT, NC
    Thanks bud. That's the response I got. I'm thinking about trading the bastard in. Been through several f150's and 250's with no huge issues. And most of them were older body styles with a ton of miles. Kinda bullshit in my opinion :eek:. Such is life I guess. Live and learn
  20. Feb 18, 2016 at 1:04 PM
    #180
    Twalt87
    Travis
    Vancouver island Bc
    Block off plates will still need to be made or bought. Im going to make mine using exhaust gasket and a cut a small aluminum plate.
    Ive been busy as all hell this week and havent got around to this yet. been riding my bike to work haha.
    I have the resistors, the 4.7k tests at 4.6k so i hope its still good.
    Figuring out the wires i need to tap into today and when im done ill post up how it went. Im going to make 2 incase it fails on me somewhere i can plug a new relay in
    Edit: Got the wiring diagram for the 2012
    The Maf wires are:
    1= 12V power source Blue-White
    2= MAF sensor ground Red-White
    3= MAF sensor signal Red-Yellow
    4= IAT sensor signal Red-Blue
    5= IAT sensor Ground Brown
    incase anyone doesnt know L is the blue code in the diagram
