Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Feb 1, 2017 at 10:15 AM
    #201
    Boulder Taco
    Boulder Taco Well-Known Member
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    3" ToyTec Lift D.C. 285/75/16's ProComp ES9000 Shocks Avid Light Bar / Sliders Hella Black Magic Fog Lights Black Badges + Black Grille ARE Topper Sockmonkey TRD Decal Bulletproof Fab. TRD Skid Plate Blacked Out Rear Bumper
    I'll check on that and get back to u
  2. Feb 1, 2017 at 6:38 PM
    #202
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    My valves had the same part numbers also. I don't think we will know yet what the future holds, let me put another 50k miles on her and we will see.
  3. Feb 3, 2017 at 10:26 AM
    #203
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    Another Update:
    CEL came on again after a full tank of gas so > 300 miles. Made an appointment w/ the dealership to use that $1000 Toyota was giving me towards the issue on diagnosis so I would know which part to replace because they won't let me use it for just parts.
    Sitting at the dealership now, they said I needed to replace pump, valves & gaskets to the tune of $2300. The pump alone was $800 and I could have sworn I've seen it online for around $200.
    I asked them why the pump needed to be replaced and they told me that the impeller blades wear down over time.. I told them I took the pump cover off and that the impeller blades were perfect, and they admitted they wanted to replace both because that's what Toyota wants them to do, they said they didn't even look at the pump.
    Needless to say, I had them take the pump + labor off of the bill which brought it down to $1300 ($800 pump and 2 hrs of labor @ $125 per hour.)
    I told them to go ahead and replace the valves and gasket and apply the $1000 towards it... so I'm getting new valves, gaskets and the labor to do it all for $300.
  4. Feb 3, 2017 at 10:42 AM
    #204
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Funny how they charge 2 hours of labor just to take the pump off. I think it's held on by 3 bolts and pinch clamps. I think I took mine off in 10 minutes or less.
  5. Feb 3, 2017 at 10:45 AM
    #205
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    No kidding. They said 4hrs labor for the valves too.
  6. Feb 3, 2017 at 11:48 AM
    #206
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    I'd like to see if this bypass kit works for the Tacomas. That would be the easiest fix, right?
  7. Feb 3, 2017 at 1:29 PM
    #207
    elliott3
    elliott3 Unknown
    in the ozarks
    99 xtracab 4x4 03 dcsb 4x4
    I bought the valves from Toyota online parts with gaskets and shipping for $446.82. The valve might take 30min to put on and the only specialty tool would be an etorx socket to take the studs out
  8. Feb 4, 2017 at 12:48 PM
    #208
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    When those codes popped in my truck, I ended up replacing the pump, valves, filter, and lines. Not knowing which component failed first. Is there anyway to figure out what to replace first?
    Elliot33 - Why did you decide to get the valves first, as opposed to possibly the pump? Did that replacement work, and keep the codes from coming back?
  9. Feb 4, 2017 at 2:12 PM
    #209
    elliott3
    elliott3 Unknown
    in the ozarks
    Mine only had the 2442 code. That code is the switching valve. Checked my pump and it looked good.
  10. Feb 4, 2017 at 4:54 PM
    #210
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    I don't mean to get off topic of this thread, but does anyone have a recommended code reader / reset tool ? Thinking it may be a must to have handy.
  11. Feb 4, 2017 at 7:05 PM
    #211
    JayHaze
    JayHaze Member
    Nashville, NC
    2012 Tacoma TRD
    So to update you all.... I received my diverter valve assembly in the mail the other day, and replaced it today. I had my father come over and help me, (father son time), and we did it in about 2 hours all together. It was a pain in the ass to remove and reinstall the bolts closest to the bottom, but it got finished. So far, drove to the ABC store and back, and no lights yet. Before the light would come on almost immediately upon leaving the house. Keeping my fingers crossed. I decided to go only with the diverter valve because that was the CEL codes I was getting, was for the valves. I also opened up the air pump and all seemed well, looked it good condition. At least for now, if I start getting codes again, I should know that it's the air pump. That part is way easier to replace, considering I removed it today just to move it out of the way, 3 bolts and one rubber hose. If you were fulling switching it out, the only extra thing would be an electrical connector. As for the engine code reader TACO, I bought this one from Amazon, and it has worked good so far for me......https://www.amazon.com/gp/product/B007XE8C74/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  12. Feb 5, 2017 at 10:24 AM
    #212
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    The filter at the bottom of the page in the ad....that's the one people are buying for the pump?
  13. Feb 5, 2017 at 1:37 PM
    #213
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    If you have any sort of smart phone then just get a wifi or Bluetooth OBD adapter and an app on your phone. Way more flexible and useful than the dedicated readers. Adapter about $15 and apps from free to $10.
    Yep, the UP-107.
  14. Feb 15, 2017 at 9:10 AM
    #214
    TheWes
    TheWes New Member
    Wes
    2012 Tacoma 4X4
    I am also having this issue - just the p2442 code. My 2012 Tacoma only has 39k miles on it.
    My question for you guys is: Assuming I have the problem fixed, is it likely to occur again down the road? Or does the replacement resolve the issue going forward in most cases. From what I have read, I havent seen anything that would imply that this WONT happen again, but I could be wrong.
    Thanks in advance for the assistance. This is definitely not something I expected before even hitting 40k miles.
  15. Feb 15, 2017 at 9:13 AM
    #215
    Large
    Large Red
    It will happen again, same parts, same shit design
    richardbui23 likes this.
  16. Feb 17, 2017 at 8:06 AM
    #216
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    I don't see why it wouldn't happen again.
    You should be covered by warranty at 39k miles.
    Mine went out at 92.5k and they gave me $1000 towards fixing it, out of pocket for me was just under $200.
    I figured this new will last another 90k miles, but I'll hopefully remember to do the bypass before then.
  17. Feb 17, 2017 at 8:21 AM
    #217
    TheWes
    TheWes New Member
    Wes
    2012 Tacoma 4X4
    Thanks for the info. I have seen many different things when it comes to the warranty on other threads - I'm outside of my 3 year/36k warranty, obviously, but the dealership informed me that this repair is not covered under the powertrain warranty, which is still active. Is that inaccurate?
    And when you say that they gave you money towards fixing it - did the dealership or toyota directly?
  18. Feb 17, 2017 at 8:24 AM
    #218
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    From my understanding, EPA/Emissions parts have longer warranties, something like up to 65 or 85k miles because their only function is to comply with gov regulations.
  19. Feb 17, 2017 at 3:22 PM
    #219
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    They wont honor it under the emission warranty unless your in California, It is also not covered under powertrain as well. I was still under powertrain and had no luck getting any help at all. Took it all the way to corporate and after the truck being down for 4 days I finally bought the parts and fixed myself.
  20. Feb 25, 2017 at 10:47 AM
    #220
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Does anyone have an extra oem air pump bracket laying around. I would like to purchase it. Trying to get rid of the previous owners K&N "CAI" and get back to stock.
