Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Oct 25, 2017 at 4:23 AM
    #401
    hdpower
    hdpower Member
    2013 Taco 4 banger
    According to him, I was the first to test and install his kit on the Taco. I have no check engine lights, limp mode etc... For the money his kit saved me it was definitely worth the $50. Truck running great !
  2. Oct 25, 2017 at 5:55 AM
    #402
    Pigpen
    Dan
    Northwest Montana
    Sounds like I might be the first V6
    EDDO likes this.
  3. Oct 25, 2017 at 7:30 AM
    #403
    hdpower
    hdpower Member
    2013 Taco 4 banger
    I suspect that it will work with the V-6 as well. Keep us posted !
    Pigpen[QUOTED] likes this.
  4. Oct 27, 2017 at 5:52 PM
    #404
    slyfox75
    slyfox75 Member
    Jeff
    Fellas.....Hey. I didnt go back all 20 pages on this post but I'm trying to catch up.
    @Pigpen.....been emailing you man:) need some info. Looks like the V6 tacos are Denso MAF sensors......all of the V8's I've been doing kits for are Hitachi branded sensors. The pinout appears to be the same (wire 4 is THA on both Hitachi and Denso)
    hdpower......was your 4Cy Hitachi or Denso?
    Edit: Nevermind hdpower.....looked back in emails and you sent me a pic.....your is a Hitachi. So the V6 are indeed different.
  5. Oct 27, 2017 at 6:38 PM
    #405
    Pigpen
    Dan
    Northwest Montana
    I keep forgetting to get measurements. I've been busy. Is there anything else I can do to help make this work for the V6? I have the weekend off.
  6. Oct 31, 2017 at 4:26 AM
    #406
    hdpower
    hdpower Member
    2013 Taco 4 banger
    Sorry for the delay Slyfox75, Yes it is Hitachi. Hopefully your kit will work for the Denso as well. My truck has been running great so far, no codes or problems !
    rickydood likes this.
  7. Nov 8, 2017 at 7:37 AM
    #407
    TacoVet
    TacoVet Well-Known Member
    Fred
    2013 Tacoma DCSB TRD OR
    So I have done the saip foam delete with the uni filter. Now I haven't read all the pages on this thread but seeing how this is going to affect our trucks and wallets, I was thinking about how we can get ahead of this.
    We know there's the foam issue which seems to be corrected but we have to deal with moisture now screwing up the diverters. Why can't we plumb in say a high temp hose to a higher/better location or even right into the intake?
    Here is a bulkhead fitting
    https://goo.gl/images/sko2WF
    Put this in before /after the filter, pin it so it won't come out and go where it's not supposed to go, suitable 90 degree fitting to a high temp hose. It would be wicked clean and solve this issue.
    Thoughts?
  8. Nov 8, 2017 at 10:17 AM
    #408
    Pigpen
    Dan
    Northwest Montana
    The foam is only one part of the problem. The valves often fail when the foam is perfectly fine. Bypassing the system, like with this kit, is the solution.
    I got my kit in the mail. Old man winter is in full effect right now and I'm moving next week. I'm not sure when I'm going to be getting around to installing it. The new spot has a garage, so once I'm in I'll hopefully find the time -assuming we don't go into seriously cold temps (not an assumption worth making in NW Montana).
    Here's a thought folks (especially @slyfox75 ):
    When we bypass the system, can we delete the pump. That's some valuable real estate being wasted in there!
  9. Nov 8, 2017 at 3:13 PM
    #409
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    How exactly does running a hose to the intake tube change anything? The intake is still pulling air from the fender at startup. I'm not sure I see how that air source is any different from a filter pulling from the engine compartment. If I have understood your proposed solution correctly. I think the fact of the matter is the valve material is just garbage no matter what air is being pulled in.
  10. Nov 8, 2017 at 4:05 PM
    #410
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Figure out a way to plumb in an air dryer like you have on an air compressor if that would even work and that would capture the moisture eliminating the issue.
  11. Nov 10, 2017 at 6:04 PM
    #411
    slyfox75
    slyfox75 Member
    Jeff
    Unfortunately no.
    Gotta keep the pump in there. The ECU does other checks on the system.....one of which is to check to ensure the motor/pump is not shorted or removed/disconnected. So it will all stay there....and collect dust. Another reason to do the bypass.....a lot of the older vehicles (05-07) have had the pumps fail electrically as well. The bypass wont help there. BUT.....if you bypass the system before you have issues, the pump will just sit and remain in good shape vs shorting out due to usage. I guess heat cycles could get the windings over time as well but I'm going on 4 years of bypassed system with no issues. 2UZ-FE V-8 4Runner.
    Side note.....I guess you COULD disconnect the pump.....you will just get CEL lights. I think performance will be fine tho(not tested, but cant imagine anything significant)
    DVexile and Pigpen[QUOTED] like this.
  12. Nov 11, 2017 at 6:27 AM
    #412
    dieselfan
    dieselfan Well-Known Member
    Joe
    western Pa
    2012 DC TRD 4X4
    Stock
    slyfox75; In your last sentence you mention disconnect the pump... you will just get CEL lights. Does this mean you can drive normally without limp mode? Do you know anyone that tried this? Thoughts
  13. Nov 11, 2017 at 7:00 AM
    #413
    slyfox75
    slyfox75 Member
    Jeff
    Nope.......pump and valves are small parts of a larger system. The ecu looks at exhaust pressure differential to know if valves are open or closed.....has nothing to do with the pump.
    Unplugging pump will not get you out of limp mode.
    rickydood and DVexile like this.
  14. Nov 12, 2017 at 10:55 AM
    #414
    Pigpen
    Dan
    Northwest Montana
    Elbows deep in install. Text message inbound
  15. Nov 12, 2017 at 11:56 AM
    #415
    Pigpen
    Dan
    Northwest Montana
    Install was a success!! Super easy and cheap insurance for a stupid, useless (and expensive) system.
    Great kit!! @slyfox75 was really helpful, as the guinea pig, I had to contact him about which wire to cut. Easy peasy
    BassAckwards, DVexile and vssman like this.
  16. Nov 12, 2017 at 12:03 PM
    #416
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Report back how it works after a few weeks. I anticipate a few more kits being installed....
  17. Nov 13, 2017 at 4:44 AM
    #417
    hdpower
    hdpower Member
    2013 Taco 4 banger
    Slyfox75's kit has been flawless on my truck. Just came back from another 500+ mile trip. Runs great !
  18. Nov 14, 2017 at 10:07 AM
    #418
    Pigpen
    Dan
    Northwest Montana
    I was 50 miles from pavement yesterday when I remembered I had recently installed mine. No hiccups. Works great!
    Now to figure out a pump delete without codes or CEL...
  19. Nov 14, 2017 at 5:37 PM
    #419
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Good to hear it works for the 4.0. Slyfox is a Pro.
  20. Nov 14, 2017 at 6:56 PM
    #420
    slyfox75
    slyfox75 Member
    Jeff
    I need a 2013+ 4.0 with some of the AIP codes to act as my next guinea pig. I have wiring harness that will eliminate the need to cut any cables. Will be ready to ship later this week or early next, but I want someone with codes present. The 2013 is programmed a little differently on the 4.0 and I need to test this thing out. Again, this test will require some time on your part but no cable cutting.
