Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Nov 14, 2017 at 7:37 PM
    #421
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    How do I go about getting a kit for my 2012? I have already repaired this once and would love to just bypass it and put the future failure behind me. Thanks
  2. Nov 14, 2017 at 10:04 PM
    #422
    Pigpen
    Dan
    Northwest Montana
    I want to put a second Northstar battery where that stupid pump is. There's gotta be a way to make the truck think the pump is still in when it's not there.
  3. Nov 15, 2017 at 7:34 AM
    #423
    slyfox75
    slyfox75 Member
    Jeff
    Kits for 4Cyl and 2012 V6 are $48. The kits require you to cut 1 wire. But no soldering or special tools/skills required.
    The 2012 V6 I will also offer in a "no-wire cut" needed format where you just clip in a wiring harness. Those can begin shipping later this week. Those are $65.
    Payment through paypal: jeffcole75 at gmail dot com Just leave me a note as to what you want and make sure to include your address! Instructions are included.
    Still need a 2013+ guinea pig......I know you're out there:)
    rickydood, sioux, Pigpen and 2 others like this.
  4. Nov 15, 2017 at 7:50 AM
    #424
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    My '13 is still working fine so I can't help but once the kit is confirmed to work without issue, I'll be in.
  5. Nov 15, 2017 at 8:11 AM
    #425
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Subscribed for 2012. My system is functioning but I want to get ahead of the issue.
  6. Nov 15, 2017 at 9:16 AM
    #426
    Pigpen
    Dan
    Northwest Montana
    Do it. If I had to do another one it would take 10 minutes to install. Less than and hour from prep to finish for your first time - probably more like 30 min, including celebratory beer.
    BassAckwards likes this.
  7. Nov 28, 2017 at 6:16 PM
    #427
    joe54tacoma
    joe54tacoma Joe in Indiana
    Joe
    New Albany Indiana
    2012 DOUBLE CAB TRD Sport
    Im new to the the secondary air injection problems. I have a 2012 4.0 Tacoma. Mine is currently working but would like to have a plan to avoid future problems. What is the difference between the slyfox75 system and the Hewitt-tech solution? Should I just wait to it fails?
  8. Nov 28, 2017 at 8:26 PM
    #428
    Pigpen
    Dan
    Northwest Montana
    Spend $50, install the slyfox kit in 30 min and the system stops running, so it will never fail.
    rickydood and vssman like this.
  9. Nov 29, 2017 at 3:35 AM
    #429
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    ^^^ this
  10. Nov 29, 2017 at 4:43 AM
    #430
    hdpower
    hdpower Member
    2013 Taco 4 banger
    From a price prospective you'll save a bunch of money by installing the Slyfox75 kit. I have had zero issues at this point, my truck is running great , install it and forget about it.
  11. Nov 29, 2017 at 7:44 AM
    #431
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    You got any pics of the kit? Im curious as to how it works.
    I have a 2013 but its functioning fine, but if you need me to test stuffs.
  12. Nov 29, 2017 at 10:30 AM
    #432
    Sharpish
    Brian
    I bought mine a week or two ago, just waiting for it to arrive. I'm in Canada so it takes a lot longer to ship. I'm also apparently the first person to get the 2012 "no cut" harness. Once I get it in I will post a review.
    TomTwo, DVexile and BassAckwards like this.
  13. Nov 29, 2017 at 12:02 PM
    #433
    joe54tacoma
    Joe
    New Albany Indiana
    Im also interested in the 2012 no cut from slyfox75.
    Just sent him a email
  14. Nov 29, 2017 at 1:33 PM
    #434
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Do not wait until it fails. I think the difference is about $150. Hewitt is more expensive. They both do the same thing - the pump will not activate, period. The pump will not activate, therefore no part of the system will fail. It's a simple, beautiful preventive measure.
    If you wait until a failure occurs, you'll be doing a lot more. As everybody on Tundra and 4Runners forums have stated for many years and now here, INSTALL THE BYPASS!
  15. Nov 29, 2017 at 4:03 PM
    #435
    slyfox75
    slyfox75 Member
    Jeff
    Hey guys....to answer question on Hewitt vs mine. Hewitt is in business.....has fancier product, pretty website, etc etc. I have a day job and started doing these kits to help fellow 4Runner guys who were needing a bypass but on the cheap. That was ~4 years ago. Since then, I've helped quite a few Tundra, Sequoia and GX folks along the way. Eventually I started getting hits from some Taco folks on here so here I am. Hewitt is great stuff....perfect for people that have zero DIY blood in them. Snaps in and your done. My kit requires you to cut 1 wire....takes about 15 mins to install but requires no special skills or tools.($48 shipped) The Taco V6's use a Denso MAF.....I have sourced a wiring harness that will allow those vehicles to not have to cut a wire.($65 shipped). The V6's can also do the original "wire cut" kit as well, your choice.
    I'm being told the 2013+ model V6s run the pump again when the truck shuts off. I'm not sure a work around for this and frankly dont have the time to pursue it. If anyone knows details of the newer systems (or link) I'd look into a way to get those to work as well. But i haven't scoured through Toyota service manuals to find how the newer systems work in order to defeat it. The current kit would work for bypassing the system on start.....but not on "engine off".
    DriverSound, Boyk1182 and DVexile like this.
  16. Nov 29, 2017 at 4:12 PM
    #436
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I will be in contact soon. Is here the place to do it?
  17. Nov 29, 2017 at 4:30 PM
    #437
    Sharpish
    Brian
    My kit arrived in the mail today. Installing tonight
  18. Nov 29, 2017 at 4:58 PM
    #438
    slyfox75
    slyfox75 Member
    Jeff
    I dont get on the forums every day.....best way to get me is jeffcolemaps at gmail or jeffcole75 at gmail you will get quicker response that way.
    rickydood likes this.
  19. Nov 29, 2017 at 5:08 PM
    #439
    joe54tacoma
    Joe
    New Albany Indiana
    Slyfox75 Money on the way tonight
    2012 4.0
  20. Nov 29, 2017 at 5:51 PM
    #440
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Will do. Better to spend a little money now than a shitload later, on a BS system.
