Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Mar 12, 2018 at 3:16 PM
    #541
    Exf150
    Exf150 Member
    After encountering this same issue in rush hour traffic on the way home from work ,(CEL and limp mode) I stopped and got my codes read at the local parts store. Sure enough, P2442! Came straight to TW and read all 28 pages here in this thread! Gained a wealth of knowledge and ammo for my trip to the dealership . My CEL had cleared , but they did a diagnostic anyway. An hour later the service manger came to me and said, yep, P2442 code , about $2500.00 or so to fix. Before I could say anything in response he said Toyota would cover the replacement of all the parts at no charge, waived the diagnostic fee and put me in a 2018 Camry rental. Wow, I was kinda floored. After being blown off by ford for THEIR poor engineering when I had my f150, it gives me a little faith that I made the right decision going with Toyota! I know all your filings with NTSB and Toyota helped me in the long run and I thank you!
    CurtB, sioux, Pigpen and 1 other person like this.
  2. Mar 13, 2018 at 6:52 AM
    #542
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    I wouldn't give Toyota but so much credit, they told many of us 2012 owners to go pound sound when we had the failures leaving us to fork over money for an expensive repair on lower mileage trucks. Its great they are stepping up but it should of happened from the start.
    Glad they are taking care of you, hopefully you will get your truck back fairly quickly.
    rickydood and Exf150[QUOTED] like this.
  3. Mar 13, 2018 at 9:25 AM
    #543
    Pigpen
    Dan
    Northwest Montana
    You should request reimbursement
  4. Mar 13, 2018 at 2:50 PM
    #544
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I did, sent all my paperwork once this broke news that they were covering. Said its like an 8week process.
    Its great they are covering it now, but we shouldn't have been here in the first place. Especially since Toyota had seen the issue previously in the Tundra's.
    rickydood and Exf150 like this.
  5. Mar 13, 2018 at 5:50 PM
    #545
    Exf150
    Exf150 Member
    I totally understand your frustration Alloutdrs1 , I paid out 3k to fix bad cam phasers on my f150 back in 2004, either pay or blow the engine! Even though they admitted it was a flawed design and issued a new part. Went all the way to the top with data from my f150 forum . They told me basically that if no one died, it wasn’t an issue and it was my fault for not getting the extended warranty The 1100 dollar spark plug tune up was the straw that broke the camels back . Bought a Tacoma. Even though it took 6 years to admit fault and , I admit , that’s a long time, they at least are making it right. ford just quit making the triton and moved on to the next sucker. Toyota has its issues , I was just saying thanks to all the effort the people on this forum put out and that it actually got recognized by Toyota. I thought I was screwed again until I turned here . Taco owners are pretty perserverent !
    rickydood and Pigpen like this.
  6. Mar 26, 2018 at 5:59 PM
    #546
    ARtaco12
    ARtaco12 Member
    Arkansas
    2012 TRD OR
    Husky front mud flap
    Okay, I just read this whole thread. Got the P2440 and P2442 today for the first time WITH limp. Let me see if I understand this.
    I have 2012 4.0 with 109000 miles. If I am reading that letter correct, it SHOULD be covered by the warranty since it is under 150k miles. Is that right??
    What should I do now? Limp into the dealership? Has anyone done this now? Did you have to pay anything? Thanks!!
  7. Mar 26, 2018 at 6:04 PM
    #547
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    You are correct. I just had this done on the 16th. I left the codes/lights on, so the dealer would see it. They had it for about an hour diagnosing. Came back saying I was right and it was the known pump/valve issue but they had to order the parts. They cleared the codes and called me when the parts came in. Zero charge.
  8. Mar 26, 2018 at 6:17 PM
    #548
    Exf150
    Exf150 Member
    I believe it’s covered until February of 2019 if I read through the thread right.
  9. Mar 26, 2018 at 6:20 PM
    #549
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    Unlimited mileage coverage runs through February, 2019. After that, coverage is limited to "10 years from the date of 1st use, or 150k miles, whichever comes first".
  10. Mar 26, 2018 at 9:05 PM
    #550
    ARtaco12
    ARtaco12 Member
    Arkansas
    2012 TRD OR
    Awesome, thanks guys.
    Should I ask for a loaner? Kinda want to see what the 3rd gen is like...:D
  11. Mar 29, 2018 at 5:40 PM
    #551
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Received a letter today after submitting my info for a refund a few weeks back, no refund for me. Thanks Toyota, I submitted all my receipts, dealer warranty decline invoice, etc. I paid cash for my air valve so they will not refund, bunch of BS.
  12. Mar 29, 2018 at 8:28 PM
    #552
    Hunter.415
    Hunter.415 Well-Known Member
    Pete
    Western mass
    2012 Tacoma short bed 4x4
    Cooper t/a 3
    I was given a loaner , had it for 2 days. Everything was covered by corporate.
  13. Mar 30, 2018 at 1:49 AM
    #553
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I just got limp mode for the first time last Thursday (2012 61,000 miles). I took it to Toyota and they fixed it for no charge, didn't ask to see a letter or anything. The service tech said they see this all the time on the tacos and tundras. I picked it up yesterday afternoon so hopefully I'll be good for a while
  14. Mar 30, 2018 at 2:10 PM
    #554
    ARtaco12
    ARtaco12 Member
    Arkansas
    2012 TRD OR
    Well I got it fixed in 1 morning for free of course. Feel pretty lucky I wasnt one of the folks who fixed it on their own dime and are now trying to get refunds.
    Aside from this issue, my truck has held up pretty well, knock on wood. Going to be hard to go with a full size next time I buy a truck.
    Foozer likes this.
  15. Mar 30, 2018 at 8:08 PM
    #555
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    That system is one of the reasons I bought an '09...
  16. Apr 4, 2018 at 3:49 PM
    #556
    Deezee
    Deezee New Member
    Just got my letter in the mail today. Looks like this is covered in Canada now.
    rickydood, Atlas86 and Pigpen like this.
  17. Apr 4, 2018 at 4:31 PM
    #557
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    FUCK ME RUNNING!!!!
    Woohoo!
  18. Apr 4, 2018 at 4:32 PM
    #558
    Sharpish
    Brian
    Can you post a picture of the letter please?
  19. Apr 4, 2018 at 4:38 PM
    #559
    Deezee
    Deezee New Member
    Sure. I see you are in Victoria as well.
    zippo88 and Atlas86 like this.
  20. Apr 4, 2018 at 6:26 PM
    #560
    Sharpish
    Brian
    Mine arrived as well. Looks like I'm covered until January 2022 which provides a great deal of piece of mind. Hopefully it grenades a month before then!
    marcosh12 and Atlas86 like this.
