Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Jun 1, 2021 at 4:19 PM
    #741
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I had to pay $110 because I purchased a secondary warranty, but was reimbursed later
    rickydood likes this.
  2. Jun 1, 2021 at 4:23 PM
    #742
    Nickpayne556
    Nickpayne556 Member
    Nick
    2012 Tacoma DCLB
    Ok. I guess we will see. Hopefully they can do something for me. Thanks for the feedback.
    rickydood and 308savage[QUOTED] like this.
  3. Jun 1, 2021 at 4:27 PM
    #743
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    If you wanna Tag 'em you gotta put a "@" in front of the name handle, Nick. :)
  4. Jun 1, 2021 at 4:30 PM
    #744
    Nickpayne556
    Nickpayne556 Member
    Nick
    2012 Tacoma DCLB
    Sorry kids. New fella here:thumbsup:
  5. Jun 1, 2021 at 4:30 PM
    #745
    FastEddy59
    Eddie
    :hattip:
  6. Jun 4, 2021 at 1:58 PM
    #746
    Nickpayne556
    Nickpayne556 Member
    Nick
    2012 Tacoma DCLB
    Update:
    Dealership changed air switching valves and repaired the air pump all under warranty. They did not ask about the cold air intake. They will be undercoating in two weeks for the frame recall/remedy. Just thought I would leave the update.
  7. Jun 4, 2021 at 2:10 PM
    #747
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I actually just had this done as well, not because I wanted to, but because I had to for registration. Whatever. It was a relatively painless process which took me two trips there because they knew what needed to be done. I was out of the truck for less than one business day at a time so it worked out in the end.
  8. Jun 4, 2021 at 2:28 PM
    #748
    dblwall
    dblwall Active Member
    Az
    2012 TRD Sport
    My 2012 has about 90,000 on it and runs great. Did the Uni Filter mod a while back, the foam was dirty but didn't look like it was failing. Just for shits & giggles is there a way to get it to throw a 2440 & 2442 code before the extended warranty runs out this year to get the dealer to fix it.
  9. Jun 4, 2021 at 2:35 PM
    #749
    Nickpayne556
    Nickpayne556 Member
    Nick
    2012 Tacoma DCLB
    I’m not sure really how to make it do it. Basically what was wrong with mine was that there was water and dust in the air valves that made them stick open or closed. They also changed the filter/sponge in the air pump because that sponge falls apart they say and can ruin the pump and valves. Truthfully, depending on your dealer, they might just do it because it is technically a recall notice for those valves and to fix the pump.
    dblwall[QUOTED] likes this.
  10. Jun 4, 2021 at 3:22 PM
    #750
    308savage
    Adam
    East Tennessee
    Remove the filter and spray water in it. Excessive road spray is what killed mine the first time.
  11. Jun 4, 2021 at 3:30 PM
    #751
    Nickpayne556
    Nickpayne556 Member
    Nick
    2012 Tacoma DCLB
    If you say that codes came up, and have water in the hoses or the filter is wet, they might just do it anyways. Also when I took my air valves off, there was water sitting right below the valve inside where it goes together. That would probably do it especially if they found water.
  12. Jun 4, 2021 at 8:10 PM
    #752
    RtacomaN
    RtacomaN Well-Known Member
    Taylor
    Colorado
    check your “My Toyota owners” website. I have an “open recall” not an “extended warranty”
    Called the dealer and they confirmed. Valves will get replaced no matter what if you throw a code you will get a new pump as well ...without a code you will just get a replacement filter and some other repair on your original pump
    rickydood and dblwall[QUOTED] like this.
  13. Jun 4, 2021 at 8:40 PM
    #753
    Climberclimb
    Climberclimb Well-Known Member
    Stacey
    British Columbia
    2020 TRD Sport premium
    Stock!
    Sorry if this has been covered - does anyone have the part number for the original foam filter? I thought I might just replace it rather than doing the uni filter mod. Truck has 130,000 km on original filter. Thanks in advance. Cheers
  14. Jun 5, 2021 at 5:19 AM
    #754
    Taco'09
    Taco'09 Well-Known Member
    Guess what? The filter does not seem to be available as a separate part but only as part of the pump assembly. Perhaps a salvage yard or make your own from a suitable piece of air filter foam.
    Climberclimb[QUOTED] likes this.
  15. Jun 5, 2021 at 10:02 AM
    #755
    Climberclimb
    Stacey
    British Columbia
    Stock!
    @Taco’09 that’s what I was thinking but thought I would ask. I will go the uni filter mod route then. Thanks!
  16. Jun 5, 2021 at 11:22 AM
    #756
    dblwall
    Az
    2012 TRD Sport
    Someone mentioned a Briggs & Stratton filter that is the same height as the Tacoma one. All that had to be done was cut to size.
  17. Jun 21, 2021 at 8:06 AM
    #757
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Summer is here and the codes have returned. No dealer love for 2.7 owners though.
    Either I'll ignore the lights as usual, or I'll cave and get the block plate kit.
  18. Jun 21, 2021 at 3:03 PM
    #758
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    No limp mode on the 2.7?
  19. Jun 21, 2021 at 4:46 PM
    #759
    dirty deeds
    Nick
    Eastern KY
    Well, sure, it always limps along. I just downshift and stand in the gas tank lol
  20. Jun 21, 2021 at 5:46 PM
    #760
    Sharpish
    Brian
    On the V6 a SAIS code will put the truck in limp mode and it’s undrivable.
