Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Oct 24, 2023 at 10:17 AM
    #821
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    When you say they replaced the ECU, you mean they replaced the Air Injection Control Driver Module or they replaced the Powertrain Control Module (PCM) or both?
    hewitt-tech likes this.
  2. Oct 24, 2023 at 1:11 PM
    #822
    grgrynlds
    grgrynlds Member
    Greg
    2015 Tacoma
    Oh yes, the Air Switching Valve set is Denso. I'm trying to find out what wiring connector had the displaced pin. I think it was at the pump connection.
    Greg
  3. Oct 24, 2023 at 1:12 PM
    #823
    grgrynlds
    grgrynlds Member
    Greg
    2015 Tacoma
    They replaced the PCM.
  4. Oct 24, 2023 at 2:38 PM
    #824
    grgrynlds
    grgrynlds Member
    Greg
    2015 Tacoma
    Looking at the Air Injection Control Driver Module, looks like PN 89581-34041 does not fit this 2015 Tacoma (if I'm looking at the correct part):
    https://autoparts.toyota.com/products/product/driver-air-injection-control-8958134041
    This product fits 403 vehicle variants.
    TOYOTA : 5 models, 403 variants between 2005 and 2014
    I'm not clear on how this part fits into the SAIS...
    Greg
  5. Oct 24, 2023 at 9:03 PM
    #825
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not sure about part numbers.
    The AID essentially is responsible for controlling the Air Injection Pump and Bank 1 switching valve, it has several inputs and outputs consisting of:
    Inputs:
    A main power input from the Air Pump Fuse (50A)
    An Ignition input from the EFI Fuse (10A)
    A constant Ground from Ground point EA
    A Bank 1 Switching Valve Command signal from the PCM
    An Air Pump Command signal
    Outputs:
    Power to Air Pump
    Power to Air Switching Valve (Bank 1)
    Diagnostic Signal to the PCM
    As for the codes based upon what I have read in service info the PCM uses a combination of two methods to determine valve operation:
    1 With the Air Pump commanded on it looks for a pressure change/pulsation when the valve is commanded open, if it sees no change/pulsation it assumes the valve is stuck closed and sets a code.
    2 With the Air Pump commanded off it looks for pressure pulsations when it commands the valve open, if it sees none it assumes the valve is stuck closed and sets a code.
  6. Oct 20, 2024 at 8:16 PM
    #826
    redneckhell13
    redneckhell13 New Member
    Sorry new here, is slyfox75 still active i need a bypass kit, thank you.
  7. Oct 21, 2024 at 6:26 AM
    #827
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I have a new hewitt bypass kit if you're interested. Send me a pm.
  8. Jun 3, 2025 at 11:36 AM
    #828
    VATACOMA39
    VATACOMA39 Member
    RICHMOND VA
    15 TACOMA DC
    I'm late to this information. Is the 2015 Tacoma included in this TSB ? If so what is the number ?
  9. Jun 3, 2025 at 12:11 PM
    #829
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    There is no TSB, extended warranty, recall, etc for the SAIS on 2013+ Tacos. The TSB/extended warranty for the SAIS only covered 2012 models with the 4.0L for 10 years from date of first use or 150K miles (whichever occurs first) so all are well out of the extended warranty by now anyway.
    The system was updated in 2013 to address the main issue that 2012 models had which was condensation collecting in the valves.
    VATACOMA39[QUOTED] likes this.
  10. Jun 3, 2025 at 8:10 PM
    #830
    Pigpen
    Dan
    Northwest Montana
    Bought my '12 new in '12. It has 195K on it and they just did the TSB work for free.
    VATACOMA39 and TegoTaco like this.
  11. Jun 3, 2025 at 8:17 PM
    #831
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting, guess you got lucky because per the letter is 10 years from date of first use.
    Pigpen[QUOTED] likes this.
  12. Jun 4, 2025 at 11:39 AM
    #832
    Pigpen
    Dan
    Northwest Montana
    Yeah. They offered to do the work a couple different times over the years, when I went in ti buy parts. Recently they called me out of the blue to offer. I reckoned this might be my last opportunity to get it done for free - I had the paperwork in hand stating the 10 year limit. It took them all day, but they got it done. Here's to hoping it doesn't fail. Ever.
    TegoTaco likes this.
