Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Dec 7, 2016 at 10:04 AM
    #101
    Jnewbern
    Jnewbern Active Member
    Thanks, I've never read or heard of a manual going into limp mode. I guess it could limit my rpms but not my transmission being that it is manual.
  2. Dec 7, 2016 at 11:42 AM
    #102
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    I did the Uni filter too, but can someone tell me if this filter needs to be oiled?
    I read on their website it did not, but when i got the filter the paper with it said it did?
    TIA!
    PC
  3. Dec 7, 2016 at 12:15 PM
    #103
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the filter is not made for a secondary injection system
    it is made for a small 2 or 4 stroke motor...so it would need oil if used as intended
    for secondary air injection it just needs to keep
    big particles out. micro dust that would harm an engine
    is ok. [the default secondary air filter is a cheesy foam piece]
  4. Dec 7, 2016 at 1:15 PM
    #104
    Collins
    North Carolina
    Ok, thanks Man!
    I took the foam pc. out of the canister...it was fine btw and the plastic fan
    looked new, so no worries, just some additional piece of mind.
  5. Dec 7, 2016 at 2:11 PM
    #105
    Boulder Taco
    Boulder Taco Well-Known Member
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    3" ToyTec Lift D.C. 285/75/16's ProComp ES9000 Shocks Avid Light Bar / Sliders Hella Black Magic Fog Lights Black Badges + Black Grille ARE Topper Sockmonkey TRD Decal Bulletproof Fab. TRD Skid Plate Blacked Out Rear Bumper
    So, this may sound like a newb question, but is replacing this filter a fairly straight forward job? When I get my rig back, I am thinking replacing the filter could be an easy inexpensive insurance?
  6. Dec 7, 2016 at 2:20 PM
    #106
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Super simple. Remove screw from the top of the pump, pull out the foam and replace cover back then slip on the filter. Done.
    Post 304, page 16.
    ruffridha9 and TACOVRD like this.
  7. Dec 8, 2016 at 4:44 AM
    #107
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    Update on my repair: Just picked it up last night, dealership here in Raleigh, replaced the pump, valves, and I believe some hosing. The tech I have been dealing with was super great. Did everything under warranty, and said they would also contact Toyota about this problem. He said anyone with this issue should be 100% covered under 5yr/60k Warr.
    I haven't looked at the new pump yet, but I am assuming it has a similar foam filter in it just like the original, but I will check. That said, is it worth removing whatever filter is in there, and clamp on the Uni Filter? Is there any chance messing around with these parts spits out those damn error codes again?
    Anyway, thanks for all the help.
  8. Dec 8, 2016 at 6:01 AM
    #108
    Collins
    North Carolina
    Hey, didn't notice you were in Raleigh, i'm up in Wake Forest.
    I've had no code issues since i did the Uni...maybe 3 months ago?
    Btw, If you decide to do it, the fastener on the top of the canister is a T-25 bit.
    Good luck.
  9. Dec 8, 2016 at 6:24 AM
    #109
    MattyJans
    MattyJans Well-Known Member
    BC, Canada
    2015 TRD Sport DCLB MGM
    Stuff and things
    Hey all, just an FYI, I ran the Hewitt tech delete kit in my 2012. It worked fine for a while but then the engine light came back on. Typically in cold weather (10*C or below) the engine light would not come on. Soon as the weather warmed up engine light would come back on. However, it did NOT put it into limp mode. Basically I just got used to my check engine light being on all the time... Toyota also wanted $2000 to fix mine but as I was talking to the service manager, a tech came out from the shop and told my about the delete kit. It was the cheap alternative but wasn't perfect.
  10. Dec 8, 2016 at 6:25 AM
    #110
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    Ok, great. So far so good. Sounds like the Uni is a pretty easy install. I'll make sure I have that bit. I think this whole air pump storm has just hit, so it should be interesting as the rest of the 2012's come up upon 50k.
  11. Dec 8, 2016 at 6:26 AM
    #111
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    Great Info. Thanks.
    I think I may be lucky having a dealership that was extremely cooperative about the warranty.
  12. Dec 8, 2016 at 10:29 AM
    #112
    tacomamitch
    tacomamitch Member
    Seattle
    I have a 2005 Tacoma, took it in yesterday and got diagnosed with the same problem. Picture attached below, there gonna charge me $1300 my truck seems to be running fine. Is there any alternatives to the solution, would it be easy to install the parts myself?
  13. Dec 8, 2016 at 10:33 AM
    #113
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Shouldn't this be part of the emissions? If so, it should be covered per law until 100,000 miles, shouldn't it?
  14. Dec 8, 2016 at 10:46 AM
    #114
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I'm not sure what pump yours has, but I think only 2012 & up have the secondary air injection pump.
  15. Dec 8, 2016 at 10:57 AM
    #115
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I believe 2.7L - 4 cyliders have the pump from 2005 to current.
    TACO TX[QUOTED] likes this.
  16. Dec 8, 2016 at 10:58 AM
    #116
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I have not looked at how the 4cyls are set up but it's not hard to replace if you can access the pump and the valves. Should still be on top of the engine somewhere and you can buy the parts for a lot less than going through the dealership.
  17. Dec 8, 2016 at 11:17 AM
    #117
    tacomamitch
    tacomamitch Member
    Seattle
    It's not under warranty already checked.
    Where would suggest I buy the parts, anyone have a write up for the install? Thanks
  18. Dec 8, 2016 at 11:38 AM
    #118
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Google OEM Toyota parts and see who has the lowest pricing. It's nothing really technical, it's bolt off, bolt on type of procedure.
  19. Dec 8, 2016 at 1:33 PM
    #119
    gottaToy
    JJ
    1985 Moped
    1995 and newer vehicles are covered for 8 years/80,000 miles for primary emission controls regardless of how many owners. Vacuum pump and the valves are in the list of covered parts according to the EPA rules.
  20. Dec 8, 2016 at 1:49 PM
    #120
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    24,000 miles on the secondary air
    this is what is covered by EPA
    https://nepis.epa.gov/Exe/ZyPDF.cgi?Dockey=P100NNQH.pdf
    Specified major emission control components are covered for the first 8 years or 80,000 miles (whichever first occurs).
    The specified major emission control components only include the
    catalytic converters,
    the electronic emissions control unit or computer (ECU),
    and the onboard emissions diagnostic (OBD) device or computer.
    If any of the parts listed below fail to function or function improperly because of a defect in materials or workmanship,
    causing your vehicle to exceed federal emission standards, they should be repaired or replaced under the emissions
    warranty if your vehicle is less than 2 years old and has been driven less than 24,000 miles.
    One manufacturer may use more parts than another, so the following list is not complete for all vehicles.
    Emission Control Parts
    1. Exhaust Gas Conversion Systems: oxygen sensor, thermal reactor, catalytic converter, dual-walled exhaust pipe
    2. Exhaust Gas Recirculation System: EGR valve, thermal vacuum switch, EGR solenoid, EGR spacer plate, EGR backpressure transducer, sensor and switches use to control EGR flow
    3. Evaporative Emission Control System: purge valve, fuel filler cap, purge solenoid, vapor storage canister and filter
    4. Positive Crankcase Ventilation (PCV) System: PCV valve, PCV solenoid
    5. Air Injection System: Air pump, diverter, bypass, or gulp valve, reed valve, anti-backfire or deceleration valve
    6. Early Fuel Evaporative (EFE) System: EFE valve, thermal vacuum switch, heat riser valve
    7. Fuel Metering System: electronic control module (unit) or EFI air flow meter, computer command module or mixture control unit, deceleration controls, electronic choke, fuel injectors, fuel injection units and fuel altitude compensator sensor, bars or rails for EFI or TBI systems, mixture settings on sealed fuel mixture control solenoid, diaphragm or other systems, fuel metering components that achieve closed/other feedback control sensors/loop operation switches and valves
    8. Air Induction System: thermostatically controlled air cleaner, air box Questions and Answers 4
    9. Ignition Systems: electronic spark advance timing advance/retard systems, high energy electronic ignition
    10. Miscellaneous Parts: hoses, gaskets, brackets, clamps and other accessories used in the above systems
    tacomamitch and DriverSound like this.
