Secondary air injection system P2440 and P2442
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Saseun99, Apr 13, 2015.
  1. Jan 10, 2017 at 11:03 AM
    #161
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Maybe it's just good ole Southern hospitality. :thumbsup:
  2. Jan 13, 2017 at 11:57 AM
    #162
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    This just happened to my 2012 v6 Tacoma immediately after a software update for a recall relating to brakes. I called the dealership, he told me he had never seen the issue with a Tacoma before and it would likely be "thousands."
    I'm going to mention the goodwill warranty and see if I can get a break.
  3. Jan 13, 2017 at 12:04 PM
    #163
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    My truck has 92k miles but is pristine, never got a CEL before.
  4. Jan 13, 2017 at 12:06 PM
    #164
    TRD-ED
    Lenoir NC.
    Good Luck. I took it all the way the the GM the 1st day I was there. Toyota helpline was closed for the New Year's holiday.
    The Service manager told me the same thing. That he had seen this many times on Tundras. But this was the 1st time ever on a Tacoma.
  5. Jan 13, 2017 at 12:09 PM
    #165
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    If you don't mind, would you be able to send me the whole service report/receipt so they can see the date?
  6. Jan 13, 2017 at 12:10 PM
    #166
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    I don't need any of your personal information but I think having that report would be helpful.
  7. Jan 18, 2017 at 10:27 AM
    #167
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    No dice with the dealership. I'm going to see if perhaps I can just clean the pump.
  8. Jan 18, 2017 at 10:48 AM
    #168
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    Saw some other threads where people blamed the little foam filter in the pump for the issue so I took a peak under the cover and thankfully my filter is fully in tact still.
    DVexile likes this.
  9. Jan 18, 2017 at 5:17 PM
    #169
    JayHaze
    JayHaze Member
    Nashville, NC
    2012 Tacoma TRD
    Hey all....or ya'll as we say in NC. Noticed there are some other NC peeps on this thread. I just joined to get in on this conversation, cause I have the cursed code as well P2442, not the other, but assume it's the same problem. I got what was probably this same code some months back, and it sent the truck into limp mode. I needed to get home, so thankfully I had a tool kit with me and disconnected the battery, and all was fine. Months went by and today, got the code. Already had bought me a code checker for when it happened again. Turned it off, and now seeing what happens. I'm wondering if I could get some of that love from Fred Anderson Toyota, or my local dealership in Rocky Mount.
  10. Jan 19, 2017 at 7:03 PM
    #170
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Good luck, not many have had luck with the dealers and most have taken it all the way to corporate. Just save yourself time and aggravation, order the parts and fix yourself.
  11. Jan 20, 2017 at 9:28 AM
    #171
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Get your VIN documented with the NHTSA. With enough complaints, maybe one day Toyota will extend the warranty or reimburse.
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
  12. Jan 21, 2017 at 5:44 PM
    #172
    Boulder Taco
    Boulder Taco Well-Known Member
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    3" ToyTec Lift D.C. 285/75/16's ProComp ES9000 Shocks Avid Light Bar / Sliders Hella Black Magic Fog Lights Black Badges + Black Grille ARE Topper Sockmonkey TRD Decal Bulletproof Fab. TRD Skid Plate Blacked Out Rear Bumper
    Does disconnecting the battery reset the codes? Or just get it out of Limp Mode?
  13. Jan 21, 2017 at 8:15 PM
    #173
    WetTaco
    WetTaco Well-Known Member
    Louis
    Northern California
    2012 DCLB 4x4
  14. Jan 23, 2017 at 9:29 AM
    #174
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    With mine, the pump was the issue. Resetting the codes did not do anything as it came right back on when started.
  15. Jan 23, 2017 at 2:56 PM
    #175
    JayHaze
    JayHaze Member
    Nashville, NC
    2012 Tacoma TRD
    Disconnecting does do both, a matter of time before it comes back on. Seems to happen more when moist or wet outside. I'm to the point of riding with CEL checking device now just to turn the code off and get out of limp mode. I'm going to document my vin with the site, but I need to do this before that will ever come about. Went to the dealership today, nothing. Same reaction... Tacoma? Really? The guy did note there was a bulletin out, but not a recall. Did you guys replace the pump or valves or both? I was thinking of just the valves, the mechanic agreed. I have 2442 only, not the other.
  16. Jan 23, 2017 at 3:03 PM
    #176
    WetTaco
    Louis
    Northern California
    2012 DCLB 4x4
    Yea I carried my code reader for a few months while I argued with the dealer. Got me snowhere so I ordered the Hewitt module and have had no problems since. If Toyota ever decides to take responsibility and fix the issue I will remove the module and drive it in to be fixed.
  17. Jan 23, 2017 at 6:15 PM
    #177
    JayHaze
    JayHaze Member
    Nashville, NC
    2012 Tacoma TRD
    Yeah it sucks..... I was looking at them kits, did you purchase the simplest one? The Original SAIS Bypass Kit, for 349? Easy to install?
  18. Jan 25, 2017 at 8:48 AM
    #178
    cricex
    cricex Member
    Austin, Texas
    2012 V6 Tacoma
    Update on my situation:
    Local dealership didn't want to work with me because I'm over 85k miles, but they asked me to call Toyota's main help line. The lady there was great. She did a little investigating and called me back the next day telling me she gave me $1,000 credit at that dealership towards "parts and service."
    The dealer is saying the repair is going to be about $2.4k, and they're asking me to drop it off so they can get to it.. But I just emailed them to let them know that I'd like them to diagnose it, and depending on the result, I may opt to just purchase parts from them with that credit. I don't think they're going to like that, but I'm crossing my fingers.
    Also, I think the issue is definitively linked to moisture. The first day the CEL came on, it was raining. I cleared it, got about 100 miles out of it before it came on again on a rainy day. I drove through some big puddles on my way to work and the CEL would come on every few miles after that.
    I cleared it that night a final time and now that it's been dry, I have gotten well over 150 miles without a CEL.
  19. Jan 25, 2017 at 6:05 PM
    #179
    JayHaze
    JayHaze Member
    Nashville, NC
    2012 Tacoma TRD
    I talked to my local dealership yesterday and they could not help me, but gave me the number to call. I called today and could not get anywhere with them, no credit or nothing. Hell, I would have love it if they gave me that credit, that could pay for the diverter valve assembly and maybe the air pump also. I'm willing to do the work, though it may take me a few extra minutes than the more experienced guy, but saving money is higher on my list of priorities.
  20. Jan 26, 2017 at 12:38 PM
    #180
    Boulder Taco
    Pete
    Tampa, FL
    2012 Tacoma TRD OR
    I would say to the guys in the NC region to go to the Fred Anderson of Raleigh. I spoke to a Service Rep named Matt. Like I said prior, they did the whole job free of charge.
