Secondary Air injection System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cgolfer, Jun 22, 2018.
  1. Jun 22, 2018 at 5:48 PM
    cgolfer
    cgolfer [OP] New Member
    2012 Tacoma
    Yes I also have an issue with this system. Codes showing P2442 and P2440. I have read quite a bit about the issue and if what i learned was correct it could be a faulty air injection valve, one way check valve, pump, pressure sensor, vacume switching valve or just bad wiring. Is there a method to determine the actual part of the system that is failing. I have pulled the pump and attached a current to it and it worked fine so i was thinking of ruling that out.
  2. Jun 22, 2018 at 7:21 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    If you have the codes, why don't you just bring it to the dealer for warranty replacement?
    Edit: I'm assuming you're aware of the extended warranty since you said you've been reading threads on the issue. If not - Toyota has an extended warranty for 2012 models for this exact issue. If you bring it in they'll replace the valves and the pump free. Check the link in the post below mine for more info.
    Stemmy and MolonLabeTaco like this.
  3. Jun 22, 2018 at 8:19 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  4. Jun 22, 2018 at 8:20 PM
    Bishop84
    Bishop84 Well-Known Member
    2012 has warranty extension.
  5. Jun 22, 2018 at 10:42 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    This.
  6. Jun 23, 2018 at 7:09 AM
    cgolfer
    2012 Tacoma
    i was not aware that the dealership would replace the pump and valves for free. The threads I read were dated and said that there was no warranty for the Tacoma but was for the Tundra. I am so glad to hear this. I thought i was in for a $1000 job. That was why I was asking about determining the exact cause of the issue. I am most happy that i joined this site. You all have been very helpful and i am most appreciative.
  7. Jun 25, 2018 at 6:15 PM
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    :cheers:
    Let us know how it goes at the dealer!
  8. Jul 1, 2018 at 5:44 PM
    cgolfer
    2012 Tacoma
    Couldn't have been any easier at the dealer. Although I hadn't purchased the truck there they replaced the parts in a couple of days after confirming the issue. NO CHARGE at all. Rockingham Toyota of Salem NH was wonderful. i was really impressed!
    bendilzerian and sioux like this.
  9. Jul 1, 2018 at 6:21 PM
    RicanTacoma
    Andres
    Fountain, Colorado
    2014 DCSB OR
    Thank you for the update,:thumbsup:
