Secondary air pump and diverter valve failure 2014 6 cyl
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jackpotnav, Aug 30, 2020.
  1. Dec 30, 2020 at 10:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well to be fair here, Secondary air injection systems have been proven to reduce emissions by up to 50%. Do I agree with the design especially with how shittily designed it is? Hell no, BUT I understand the necessary evil there is in place to make Toyota feel compelled enough to run them in place.
    CAFE, ARB, and especially CARB is looking for any excuse to tell them that their engines are too dirty to run these trucks on public roads and they are legally not allowed to sell them given how much fuel they consume even with the SAI system in place.
    Secondary air injection systems are considered an emissions exclusive item. That is it's sole and primary purpose.
    ALL emissions items down to the catalytic converters are covered under an 8 year 80,000 mile warranty under federal law.
    If the SAI system is failing, they are legally not allowed to deny you of warranty repairs and if they do or attempt to, a nice conversation with service manager or even the general manager of the dealership attempting to deny you would QUICKLY lay down the red carpet for you the moment you tell them such, and if they don't, the hot water they'll get in will be scalding hot.
    It won't help.
  2. Dec 31, 2020 at 2:08 AM
    blur
    blur Well-Known Member
    I also installed the Hewitt tech bypass as a preventative measure. I installed it a few years ago and wasn’t experiencing any issues when I put it on but I bought this truck for it’s reliability and I’m not chancing going into limp mode when I could be hundreds of miles from home.
    At the time there wasn’t a solution for an all out delete and the HT bypass kit was easy enough to install. I haven’t noticed any problems with it or the sais system. I believe HT now has a second gen bypass kit that is even easier to install and for a couple hundred bucks it was a no brainer for my peace of mind, especially after hear some guys are getting charged over $1500 for the dealership fix.
    Given the price difference between the OEM fix and the bypass kit, I’m surprised not to hear more guys fitting the HT kit. I haven’t read any bad experiences with it.
  3. Dec 31, 2020 at 3:45 AM
    Soylent Green2012
    Soylent Green2012 RestoRides MotorSports
    jake
    Apopka, Florida
    2012 Tacoma Pre runner SR5 V6 Limited Edition
    chrome bull bar, 20" vision wheels, LED lighting, Custom grill.
    Blur, Have you been denied any service work from any source dealership or private mechanic shops? since the HT was installed
    or do you perform all your maintenance yourself?
  4. Dec 31, 2020 at 3:58 AM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    That's a damn good question, I even took it to corporate. Toyota made good on it a few years later when they issued the recall of them for the 2012 trucks and I submitted my receipts and they sent me a check reimbursement of parts only, not my time to install.
    Both dealership and corporate would not cover, they even tried to charge me a $100 diagnostic fee when I took it in at 51k. I fought that and they waved it and sent me on my way. I tried the emissions route and no dice. At that point I had to just bite the bullet and fix myself to get the truck going, missing work for to the truck down and aggravation over battling was not with it anymore to me. Toyota has always fought me tooth and nail when something needed repair under warranty.
    At 29k one of the valves was got frozen in the stuck closed position. So I had codes but no link mode. At 51k they both failed completely stuck open position and left my wife and daughter stuck in limp mode with the truck, I was not happy.
    If any of you have taken the valves apart they are destined to fail, the valves are surrounded by rubber to help them seal up. The rubber degrades and causes them to stick open and screw up.
  5. Dec 31, 2020 at 5:01 AM
    blur
    I haven’t been denied any service work because I have done everything myself (did all my driveline fluids and plugs last year). I only have about 35k miles on my ‘12 so other than your typical oil and air filter changes I haven’t needed to do much.
  6. Dec 31, 2020 at 5:03 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Has anyone had success with the Hewitt tech bypass and passing emission tests in states that still require them, for example in the people’s republic of Jersey?
    Soylent Green2012 likes this.
  7. Dec 31, 2020 at 6:09 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Is it true that the current version of the Hewitt bypass requires having a normal functioning SAI or can it be installed on a failed SAI system and still function as designed?
  8. Dec 31, 2020 at 6:43 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Wrong. Common with 2012, not the higher years.
  9. Dec 31, 2020 at 6:53 AM
    blur
    I know the first gen HT bypass required a functioning system. That is the main reason I jumped on it when I first learned about it but I believe they have a 2nd gen bypass now that is even easier to install but I haven’t looked into any operating differences so I’m not sure if that is still the case.
  10. Dec 31, 2020 at 7:33 AM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    With the Hewitt kit, the only visible evidence of the kit is a black wire running under the plastic engine cover.
  11. Dec 31, 2020 at 7:34 AM
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    X2
  12. Jun 16, 2025 at 9:12 AM
    Stu_22
    Stu_22 New Member
    1998 Tacoma
    Hi I am experiencing this problem now myself, I am wondering if the people on here that used the Hewitt kit had noticed any difference in fuel economy? TIA
  13. Jun 16, 2025 at 9:27 AM
    RockinU
    RockinU Well-Known Member
    Texas
    If I had done the delete, and if I was still using my truck on road, I don’t think I would have noticed much difference in fuel economy.
    Stu_22[QUOTED] likes this.
