Secondary air pump mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by packers15, Jul 16, 2018.
  1. Jul 16, 2018 at 2:35 PM
    packers15
    packers15 [OP] Well-Known Member
    I was going to do the secondary air pump mod on my 2006 but don't see one mounted by washer bottle. Does the 2006 have one and if so where is it mounted ?
  2. Jul 16, 2018 at 2:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    We don't have one. That's 12-15
  3. Jul 16, 2018 at 2:38 PM
    packers15
    10-4 Thanks for the quick answer.
    EatSleepTacos likes this.
  4. Jul 17, 2018 at 7:36 AM
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    Thank your lucky stars.
  5. Jul 17, 2018 at 7:45 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Anyone have a link to what the mod is?
    Thanks
  6. Jul 17, 2018 at 7:50 AM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  7. Jul 17, 2018 at 8:07 AM
    Pigpen
    Dan
    Northwest Montana
    It doesn't help with the valves though, only the filter/ pump issue. Toyota is covering the cost when the system grenades now, so at least there's that.
    PzTank likes this.
  8. Jul 17, 2018 at 8:38 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Do you know if Toyota is covering cost for only 12-15 trucks with less than 3 yrs. age or 30K miles or did they extend this? Thanks.
    @Pigpen
  9. Jul 17, 2018 at 8:47 AM
    Pigpen
    Dan
    Northwest Montana
    IIRC, there is no time limit or mileage cutoff. I received a letter from Toyota and I just keep it in my truck for when I need to limp the truck to a dealership. I know I'll be hundreds of miles from one when it finally fails though.
  10. Jul 17, 2018 at 9:05 AM
    Lester Lugnut
    Thanks - I never received a letter from Toyota. Mine is a 2015 - extended warranty may not apply.
  11. Jul 17, 2018 at 9:08 AM
    Pigpen
    Dan
    Northwest Montana
    It's a TSB and I'm pretty sure it applies to all '12-15 4.0 Tacomas.
  12. Jul 17, 2018 at 9:16 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I thought it was 2012 only? The 2013-2015 have different software that runs the pump on shutdown, removing moisture from the system that would otherwise corrode the valves.
    The warranty is a two part, first is unlimited mileage until march 2019, then there is a 10 year extension from in-service date, up to 150 000 miles.
  13. Jul 17, 2018 at 9:32 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Thanks, that explains why I can’t find it on my 2010
  14. Jul 17, 2018 at 12:20 PM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Does this include the 2.7? I have a 2012 that I bought a year ago.
  15. Jul 17, 2018 at 12:22 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The 2.7L has had this since 2005. It was mainly the 4.0s that have had issues with this setup on the 2012 year models. I would venture to say no, that yours wouldn't be covered, but I could be wrong, so hopefully someone else can chime in with more info.
    WoodsGhost[QUOTED] likes this.
  16. Jul 17, 2018 at 1:00 PM
    WoodsGhost
    PA
    Thanks.
    BassAckwards[QUOTED] likes this.
  17. Jul 18, 2018 at 2:43 PM
    Pigpen
    Dan
    Northwest Montana
    There's a "fix" for the 2.7 that tricks the truck to not run the pump. It costs $50 and is made by @slyfox75
    I ,and others, installed this mod on my 4.0 and found it does not work on our engines (he didn't charge me).
    It's a simple install and I highly recommend it for 2.7 owners to avoid the headache of dealing with it failing.
    I don't know about a TSB for the 2.7.
    WoodsGhost likes this.
  18. Jul 18, 2018 at 3:22 PM
    fuzzywuzhe
    fuzzywuzhe Active Member
    Fuzzy
    2014 Tacoma Short Bed w/4 doors
    I ordered the filter from Amazon ... will do the mod when it gets here.
    themanbearpig012 likes this.
  19. Jul 18, 2018 at 3:55 PM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    think i might do the same.
    link to the part?
  20. Jul 18, 2018 at 4:17 PM
    fuzzywuzhe
    Fuzzy
