Secondary Air Pump relocation?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD_eman, May 9, 2020.
  1. May 9, 2020 at 9:51 PM
    TRD_eman
    TRD_eman [OP] Member
    2015 SuperWhite Tacoma TRD Sport
    2" leveling Kit Black Grill LED Headlight and Fig light Always on Fog Mod 32" BFG KO2 Stock Entune with 5 channel 1200w Pioneer amp with Alpine Type S 6x9 and tweeters, Alpine Type R 6.5 in back and 8" Polk Audio Sub.
    I am wanting to install my TRD intake, but that pesky secondary air pump is in the way. Anyone know of relocation kits available if any? Or any write ups? I have search with no solution.:notsure:
  2. May 9, 2020 at 9:55 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  3. May 10, 2020 at 9:32 AM
    TRD_eman
    ^^^^that didn't answer my question at all
  4. May 10, 2020 at 9:42 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There are various ways you can do it. All inconvenient, but some less than others. Snap a picture of your engine bay so I can see it. Focus more on the intake area by the passenger side.
  5. May 10, 2020 at 9:43 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    But it did, it provided another thread that even has a picture of where another member relocated the pump.
  6. May 10, 2020 at 9:47 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That relocate is a half baked way of doing it, not due to the actual relocate itself but because of the design of the brackets made to hold the pump in place. There is a way better made bracket out there designed to hold the pump in place without being so flimsy and have the harsh NVH those inherently have.
  7. May 10, 2020 at 9:56 AM
    TRD_eman
    I saw the pic of where he relocated it, I have plenty of pics of where people have put it, But no solid answers of how they did it, what brackets they used....I just basically got to the end if the movie without watching what happened
  8. May 10, 2020 at 9:57 AM
    TRD_eman
    Where I can find said bracket?! I have looked everywhere
  9. May 10, 2020 at 9:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I need to see your engine bay first because there may be a way of installing it as is and just bending the OE bracket a little bit, but I won't know until I see it.
    Gen 2 TRD intake right? This one?
  10. May 10, 2020 at 10:07 AM
    TRD_eman
  11. May 10, 2020 at 10:13 AM
    TRD_eman
    I have no idea if my response made sense just now
  12. May 10, 2020 at 10:17 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Shoot. Your ABS is in the way.
    Okay. Bracket is built by Holley/ Flowmaster, call them, part number AF5025. It should cost you about $41 for the bracket. You will need two M8x1.25 bolts one can be 20mm, the other 40mm two washers to mate with them and two nuts to match. You will have to drill a hole into the core support 5/8 I believe it was and you will have to extend your air pump harness either at the engine bay or the pump itself. You can pull a grommet from your old OE intake tube to use on your relocate for the bottom bolt hole. Oh yeah, you will also have to cut about a half inch of the air pump inlet hose in order for it to run right and not be kinked. Those measurements may vary for you though as you can see, I am running a coilovers tower bar across the engine bay. Pictures incoming.
    Here is where my extension of the air pump wiring lands. Right beneath the intake air cleaner lower lid.
  13. May 10, 2020 at 10:22 AM
    TRD_eman
    Yes!!! Thank you!! Exactly what I was looking for!
    12TRDTacoma likes this.
  14. Feb 1, 2023 at 3:44 PM
    pavement.is.lava
    pavement.is.lava Well-Known Member
    SLC, UT
    2015 DCSB TRD OR 6MT
    285/75r16 KO2s, Dobinsons 3” lift, BAMF bumper/sliders, skids, Allpro Rack
    Can you elaborate on how you extended the harness?
  15. Feb 3, 2023 at 4:52 PM
    patriot0331
    patriot0331 Member
    2012 Toyota Tacoma TSS
    Just get the Hewitt Technology kit and eliminate that whole crap. Mines been on now for several months here in Alaska with no issues. Anyone want to buy a used air pump!! LOL
    GilbertOz likes this.
  16. Jul 18, 2023 at 6:24 PM
    806Taco
    806Taco Mr. Worldwide
    Texas
    2013 Double Cab Short Bed
    Bilstein 6112 (Front) Bilstein 5100 (Rear) General Spring KC - HD Leafs Poly Swaybar Bushings Braided Stainless Steel brake hose Intake Manifold Spacer Retrofitted Headlights
    Can you explain how you extended the air pump wiring harness? Did you buy a kit somewhere or just cut and splice?
  17. Jul 18, 2023 at 6:28 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    i did a cut and splice
  18. Jul 18, 2023 at 6:30 PM
    806Taco
    Texas
    Soldered or just use butt connectors? Looks like it goes from 3-4 cables to 2 large cables?
  19. Jul 18, 2023 at 6:43 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Its been awhile, I don't remember.
    806Taco[QUOTED] likes this.
  20. Oct 18, 2023 at 7:42 AM
    ramonortiz55
    Ramon
    Texas
    stock
    soldered
