Secondary Air Pump / taking it apart / $1400 / If you own a Tacoma you should read this..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YEABOY, Sep 6, 2016.
  1. Sep 20, 2016 at 4:24 PM
    #241
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    If you are in a hot state then perhaps moisture in the valves has not been an issue.
  2. Sep 20, 2016 at 4:55 PM
    #242
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Oh for sure! Its 100% not a cure all, but like you stated if it fixes one of the possible causes of the failures, its worth it.
    vssman and MTopp like this.
  3. Sep 20, 2016 at 5:34 PM
    #243
    Pigpen
    Dan
    Northwest Montana
    Filter ordered. Now I want the cover. Shit.
    @ChadsPride read this thread
  4. Sep 20, 2016 at 5:50 PM
    #244
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    The Air Pump cover part # on my '14-V6 is 17613-0P010. Elmore Toyota has it for $31.14.
  5. Sep 20, 2016 at 6:33 PM
    #245
    a330us
    a330us New Member
    arch
    winston salem, nc
    2010 gray tacoma sr5 4 cyl auto
    none
    Ok, thanks for the reminder about ebay, I did order one although several of the vendors I checked were out of stock, seems to be a really popular size. Arch.
  6. Sep 20, 2016 at 7:06 PM
    #246
    im4u2nvss
    im4u2nvss Well-Known Member
    Jesse
    2012 DC
    WA state
  7. Sep 20, 2016 at 7:23 PM
    #247
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Also noticed that the price of the filter has gone up from around $12 to around $16.
    This thread seems to have created more demand vs supply just like that gas pipe leak fiasco in the SE US, artificially raising prices.
  8. Sep 21, 2016 at 10:08 AM
    #248
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I know UNI has an e-bay store and saw it on there for like $12 and some change. Doesn't have to be "UNI" brand as long as it's a 1" inlet filter/breather.
    Here's a K&N alternative.
    Part # 62-1370
  9. Sep 21, 2016 at 10:23 AM
    #249
    kukimonsta
    kukimonsta Well-Known Member
    G
    Alameda, CA
    2012 SSM DCSB TRD OR
    Is the pump cover for looks or function to silence the pump?
  10. Sep 21, 2016 at 10:29 AM
    #250
    Soul Surfer
    Jimi
    ‘25 TRD OR
    I think that it serves as protection. And it does give the pump a finished look. Mine came with one.
  11. Sep 21, 2016 at 10:49 AM
    #251
    Soul Surfer
    Jimi
    ‘25 TRD OR
    The pump noise is the same with the New filter on. I haven't experimented with running the truck with the cover off.
    kukimonsta[QUOTED] likes this.
  12. Sep 23, 2016 at 1:11 PM
    #252
    skrazz
    skrazz 2013 SR5 4x4 4.0L AC
    Joshua
    St. Petersburg, FL
    2013 SR5 4x4 4.0L AC MGM
    Mine's on the way from an eBay seller. Took a look at my filter and while it was whole, it looked and felt like it could possibly deteriorate with another year of heat. I'll sleep soundly once the old filter is out. Thanks to the thread starter and all of those who provided their experiences and photos!
  13. Sep 24, 2016 at 11:19 AM
    #253
    Chephie
    Chephie Well-Known Member
    Chad
    Ohio
    2012 MGM DCSB TRD OR
    OME884/5100's Wheelers Progressive AAL LR UCA's 265/75/16 Duratrac Method NV wheels Color matched grille surround ImMrYo rear view mirror relocation bracket Avid slider/steps
    Finally got around to getting this installed today. Foam was not in too bad of shape.
    Question for the experts here...since I have 2012 which does not have the cover, is the consensus to purchase said cover? Really don't see any benefit other than making it look a little cleaner so to speak.
    Thanks in advance...
  14. Sep 24, 2016 at 12:25 PM
    #254
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have no idea what purpose that cover serves, but the way that they try to continuously cut costs there must be a reason for it or they would not have started to put it there.
  15. Sep 24, 2016 at 2:21 PM
    #255
    Nessmuk
    Nessmuk Well-Known Member
    Bob
    Charlottesville, Va
    2.7 5sp AC w/SR & convenience pkg
    But there are some of us with 2014s and 2015s that came brand spanking new off the lot with no cover. :confused:
  16. Sep 24, 2016 at 2:40 PM
    #256
    kukimonsta
    G
    Alameda, CA
    Maybe for harsh weather states? I'm guessing cali won't have it?
  17. Sep 24, 2016 at 2:42 PM
    #257
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    I have the cover. 2015 sr5 4x4 DCLB 4.0. From CA.I would think if you 4 wheel or drive thru water or mud that you would want the cover for extra protection against moisture. Especially if you've removed your fender liners like me
    CMD-KY likes this.
  18. Sep 24, 2016 at 6:48 PM
    #258
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My '15 has a cover.
  19. Sep 25, 2016 at 7:15 AM
    #259
    Chephie
    Chad
    Ohio
    Good points everyone, thank you. Maybe I'll just get one for good measure :notsure:.
  20. Oct 2, 2016 at 12:15 PM
    #260
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I put this filter on last Friday. The old foam was fine, just slightly dirty. The impeller was fine. This morning my truck threw a P2432 code. I can hear the pump run when the truck is cold and it sounds normal.
    Could the new filter not let enough air through it? I wouldn't think so.
    Anyone have any ideas?
    Also, the code didn't clear using my UltraGuage.
    http://www.autocodes.com/p2432_toyota.html
