Secondary Air Pump / taking it apart / $1400 / If you own a Tacoma you should read this..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YEABOY, Sep 6, 2016.
  1. Apr 5, 2017 at 9:33 AM
    #321
    T U N A
    T U N A Member
    2012 Tacoma
    Thank you, Ordered my Uni today, replacing the valves tomorrow and will attached the Unit when it arrives. Sure wish the fan (impeller) could be found separately.
  2. Apr 5, 2017 at 9:47 AM
    #322
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Search for it used on E-bay or the likes. I doubt the fan blades will be sold separately.
  3. Apr 5, 2017 at 10:41 AM
    #323
    im4u2nvss
    im4u2nvss Well-Known Member
    Jesse
    2012 DC
    They dont always go that early. I am about to cross 90k and no issues. Checked my foam last fall and it looked perfect(but I dont think UNI replacement is a bad idea).
    Pirhett[QUOTED] likes this.
  4. Apr 5, 2017 at 11:01 AM
    #324
    tcjacado
    tcjacado Well-Known Member
    That impeller has to come off. There is a screw on the center of it. Like all pumps that screw is lefty tighty and righty loosey. They do that so the impeller doesn't just fly off if there is back spin.
    Get it off and make a new one from a 3d printer. I am sure it can be done.
  5. Apr 5, 2017 at 12:06 PM
    #325
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    While he's at it, why not just 3d print an entirely new pump. I'm sure it can be done.
    12TRDTacoma likes this.
  6. Apr 5, 2017 at 12:56 PM
    #326
    brandonpturner
    brandonpturner Well-Known Member
    Brandon
    Fremont, CA
    2013 SR5 4x4
    N/A... for now.
    Yall had me nervous for no reason. 2013 4.0 V6 ~50,000 miles.
    HandOfGod, TacomaMike37 and jamiec like this.
  7. Apr 5, 2017 at 4:26 PM
    #327
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Just received my filter today...hopefully get it put on this weekend! So are you guys using the oil with these filters that it recommends or are yall going without any oil? How often are yall cleaning them?
    jamiec likes this.
  8. Apr 6, 2017 at 1:59 PM
    #328
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I left mine dry.
  9. Apr 6, 2017 at 7:37 PM
    #329
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I replaced mine with the Uni last weekend. 2013 with 85,000 on her. The foam still appeared to be in good shape, although it did feel a little stiff around the edges.
    Super easy to do.
    Would prefer to remove all that emissions stuff anyway...
    jamiec likes this.
  10. Apr 7, 2017 at 2:49 PM
    #330
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Did mine when I got home from work.
    2012 4.0 with 32 k on the clock.
    Foam looked good, but as mentioned earlier, little funky on the edges.
    Filter took all of 2 minutes to do.
  11. Apr 7, 2017 at 4:46 PM
    #331
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Their website says no oil required:
    http://shop.unifilter.com/p/clamp-on-breather-1”
    jamiec and JWROSE4[QUOTED] like this.
  12. Apr 7, 2017 at 6:25 PM
    #332
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Cool...I never thought about it till I recieved mine and it said on the package to use the oil for best performance. Then my OCD kicked in and thats when I had to ask!
    jamiec likes this.
  13. Apr 8, 2017 at 6:01 AM
    #333
    Rosa Klebb
    Rosa Klebb Member
    Tucson, AZ
    2012 4X4 Access Cab
    Still Thinking ? ? ?
    Another 2012 V6 owner that freaked out after reading this thread and did the filter mod at 88,000 miles. Foam removed looked fine as did fan blades.
    jamiec and DVexile like this.
  14. Apr 8, 2017 at 6:16 AM
    #334
    DVexile
    Ken
    I've done the filter mod too, but I think the filter failure is probably quite rare and very dependent on the environment the truck is in. It is an easy and cheap mod at least.
    The larger issue is the valves on the 2012 which seems to be a quite frequent occurrence.
    We've got one or maybe two reports at most here on TW of filter failures while valve failures I've lost count of but probably close to fifty?
    One remaining concern I have with the filter mod is I suspect the filtering efficiency of the two filters is drastically different. The OEM has enormous depth as it is a big block of foam while the UP-107 is just a fraction of an inch thick. No idea how that may or may not affect the downstream cats.
    Sidney Vicious likes this.
  15. Apr 8, 2017 at 6:22 AM
    #335
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
  16. Apr 8, 2017 at 6:34 AM
    #336
    Rosa Klebb
    Rosa Klebb Member
    Tucson, AZ
    2012 4X4 Access Cab
    Fifty sounds more worrisome than two. Thanks to TW, I will likely know what is going on if my valves fail tripping the dreaded codes.
    My truck was in the desert for 2.5 years and now 2.5 years with some high humidity so environment has changed.
    scottalot likes this.
  17. Apr 8, 2017 at 7:39 AM
    #337
    apoteker
    apoteker Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    Maybe we need to take an actual count of the valve failures here... i know it has to be more than 50- mine just failed last month right around 50k miles
    scottalot and Rosa Klebb like this.
  18. Apr 8, 2017 at 7:54 AM
    #338
    DVexile
    Ken
    That would be useful. My post should have read "at least fifty". There is more than one thread on TW about this problem so reports are also spread around a bit. One could also look for NHTSA complaints as well.
    TRDSport10 and scottalot like this.
  19. Apr 8, 2017 at 8:15 AM
    #339
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    I just took a stab at posting a poll to hopefully capture that data.
  20. Apr 8, 2017 at 8:28 AM
    #340
    apoteker
    yeah i filled out a NHTSA complaint- these codes popped up on me while i was on the freeway and started into limp mode- luckily i cleared with ultragauge but still could have been an issue if there had been more traffic
