Secondary Air Pump / taking it apart / $1400 / If you own a Tacoma you should read this..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YEABOY, Sep 6, 2016.
  1. Aug 10, 2018 at 10:14 PM
    #421
    HandOfGod
    HandOfGod Well-Known Member
    Tacoma TRD 4x4
    Stock
    Just ordered it on Amazon so back in stock.
  2. Aug 10, 2018 at 10:35 PM
    #422
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    It is back in stock! Returning the K&N and ordering the Uni now. The K&N is pretty big...
  3. Aug 10, 2018 at 10:38 PM
    #423
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    I’m not buying the filter. I’m still on factory warranty and I hope in 2 years there will be a full delete option available for the 2012-2015 Tacoma.
    Getting the filter won’t stop everyone’s problems. I’m more worried water getting inside. Unfortunately this unifilter won’t stop water from coming inside. Matter of fact might make water come in easier.
    That said. Full delete option is the best solution.
  4. Aug 10, 2018 at 10:40 PM
    #424
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    :pray: One day maybe.
  5. Aug 11, 2018 at 12:40 AM
    #425
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    How will the original chunk of foam prevent water from getting in?
    I think the uni filter would be better at preventing water from getting in compared to the foam
    Not disagreeing with you about the delete though
  6. Aug 11, 2018 at 1:30 AM
    #426
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
  7. Aug 11, 2018 at 10:56 AM
    #427
    4wdExplorer
    Orange County, CA
    I'm not saying that the foam will not let the water in. But there seems to be more surface area on the unifilter to potentially let water in. Water is worse than having particles get inside the system.
    Again to me the ultimate solution to prevent any problems is a full delete. I off road alot and go through stream crossings, etc. So I do not want this system at all, especially since I am coming from a 2009 4runner 4.0 V6 without this annoying system.
  8. Aug 11, 2018 at 2:25 PM
    #428
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    My concern with the uni filter mod. is that it’s a paper filter material in an area that does get moisture.
    I’m thinking that paper filter material still needs to be washed and cleaned periodically in order to filter properly due to fine dust and moisture eventually closing the pours on the filter.
    There’s a reason why some dirt bikes , ATVs , lawn mowers use foam and foam lube and require periodic clean and re-lube.
    From my dirt bike days, I just see this as a maintenance item with the stock foam filter every 2 or 3 yrs with proper filter lube. It takes like 5 min. To get the foam out. Foam filter lube will keep the foam from drying out and catch dust and debris. I’m not drinking the kool aid on this mod.
  9. Aug 14, 2018 at 7:15 PM
    #429
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    @Kidwidataco this should answer any questions you have.
  10. Aug 14, 2018 at 8:27 PM
    #430
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Thanks!
  11. Aug 15, 2018 at 4:45 AM
    #431
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    @OVTune and their handheld tuner supposedly allow you to turn off the SAI system. I'd love some more info on this as a full delete with headers would be a very cool upgrade.
  12. Aug 17, 2018 at 12:05 AM
    #432
    MurderTaco75
    MurderTaco75 Member
    Shelton,WA
    13TRD Sport dc,Murder Black
    TRDPro catback exhaust,K&N cold air intake,3”Bilstein 5100 Lift,Toyo AT2 33”on 17’s,10”typeR alpine sub,
    At 85k miles no issues yet,finger crossed.
  13. Aug 17, 2018 at 3:21 AM
    #433
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Yeah I’m at 91k now and no issues (knock on wood)
  14. Aug 17, 2018 at 5:57 AM
    #434
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Because mods...
    Mully and scottalot[QUOTED] like this.
  15. Aug 17, 2018 at 6:31 AM
    #435
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    From Uni Filter's site.... "Uni’s Breathers are made of a new washable urethane which needs no oil or special cleaners." That said, it's not a paper filter....
  16. Aug 17, 2018 at 10:21 AM
    #436
    spitdog
    I never said the uni filter needed oil, I said the filter will need cleaning. All filters need cleaning or replaced. All filters catch debris, that’s there purpose. The debris doesn’t automatically evaporate or disappear. Eventually they become clogged and restrict air flow. The paper filter term I used was wrong I grant you that. But the material that it is made of has has no effect on what I was saying. It still needs cleaning,it still will hold moisture and trap dust and debris and needs cleaning. Your bold print confirms that. It actually means you need to wash and clean them. You just don’t need a special filter cleaner.
    So what it’s made of is immaterial.
    I would bet that a lot of people think they just slap on a uni filter and thats it. Problem solved forever. Nope! You still need to clean that uni filter. OK, so why not just clean and maintain the stock foam filter with a little lube to keep it from drying out.
    CMD-KY likes this.
  17. Aug 17, 2018 at 11:15 AM
    #437
    CMD-KY
    CMD-KY Well-Known Member
    South Central Kentucky
    2104 Tacoma AC SR5 4wd
    Do you have a recommendation for a good foam filter lube? I see that Unifilter sitting there either completely open or only half covered. It has the potential for water contamination, the cause of many of the problems with the system.
  18. Aug 17, 2018 at 1:01 PM
    #438
    spitdog
    In the past I always used maxima because you could pour a little bit into a baggie and toss the filter in there to work it around. But with my little foam filter with my truck I just wanted to keep it moist and prevent it from drying out and eventually breaking apart, I didn’t need the tackiness of a true foam filter oil, so I just used a little fluid film and it works like a charm. It’s lanolin based so in won’t degrade the foam,
    a small amount is not tacky like true foam oil, it can be washed out with dawn dish soap and warm water.
    It’s so easy to check and a no brainer to me. Another thing to think about, if your truck is still under warranty and you take it to a dealer with a engine problem and forget to remove that uni filter
    I can’t help believe that could maybe cause some problems along the lines of an altered engine in there eyes.
    The uni filter makes sense to me with someone with an old truck out of warranty with a dried out foam filter that’s about to fall apart due to lack of maintenance. But that’s not me and I would bet it’s not the case with most people.
  19. Aug 17, 2018 at 2:13 PM
    #439
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Regarding water contamination, I suppose it depends on how the truck is used and one should adjust accordingly. I agree that every filter requires either cleaning or replacement, but I've yet to see the OEM foam filter regarded as a consumable and can be replaced and or cleaned (in Toyota's eyes). It certainly opens up a hornet's nest and replacing it with a Uni-filter could be the lesser of two evils. It might not be the magic elixir to save every pump from failure but if you're beyond warranty, it is something worthy of consideration.....
    For the record, I changed mine out on my 2012 but not on our 2015.....
  20. Aug 17, 2018 at 2:37 PM
    #440
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I'm not familiar with Fluid Film so I had to look up the MSDS for it.....
    Unless I'm reading the composition incorrectly, there's a strong presence of petroleum products. I looked up the aerosol form but the brush on was very similar. Could I have been looking at the wrong product?
    https://ihiqa2kjxfb4dhp9872la1cm-wpengine.netdna-ssl.com/wp-content/uploads/2016/07/SDS_Aerosol.pdf
    Refined petroleum oil, hydrotreated heavy paraffinic, Petroleum gases, liquified sweetened, Calcium petroleum sulfonate
    Edit* In their FAQ section, regarding plastics & rubber - "FLUID FILM has no adverse effects on plastics. Caution should be used around non oil-resistant rubber goods. May cause swelling."
    It could be cause for concern, but I'm not positive......
    CMD-KY likes this.
