Secondary Air Pump / taking it apart / $1400 / If you own a Tacoma you should read this..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YEABOY, Sep 6, 2016.
  1. Sep 27, 2020 at 9:56 AM
    #481
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Would this cause the secondary pump to stop working?
    I filled up my tank yesterday. After pulling into the garage last night, and moving the truck this morning, I noticed that the smog pump 'whine' wasn't there, which I thought was odd. The next time I started the truck up, the CEL and Trac lights came on.
    When I pulled out of the garage this morning I also noticed a dead mouse on the garage floor, so now I'm all paranoid about mice chewing on wires...
    I re-tightened the gas cap and unhooked the battery for a minute. The CEL and Trac Control lights are now off.
    Drove it a couple times today. CEL lights remain off. Truck runs fine. But the smog pump still isn't engaging.
    I did the Uni filter mod a couple months ago, but I'm guessing it's unrelated.
  2. Sep 27, 2020 at 1:12 PM
    #482
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I’m not sure if it would or not. I’m not very familiar with how these Evap systems work.
  3. Sep 28, 2020 at 9:00 AM
    #483
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    idk. After a day the smog pump has started firing again - both start and shutoff. I'm guessing that the other day I just didn't screw the gas cap on tight enough, and/or it's going bad. That tripped the CEL lights, as well as some pressurization issue which has since corrected itself.
    I'm probably just making stuff up.
  4. Oct 25, 2020 at 5:30 PM
    #484
    whitcher
    whitcher New Member
    2003bLandcruiser; 2008 tacoma 4X4
    none
    There are plenty of inexpensive secondary air pumps on Ebay. Has anyone tried them? The reed valve seems to be an OEM only item, but the OEM air pump is the most expensive part of the system. The Chinese ones come with a 1 year warranty. You could buy a bunch for the cost of one OEM part.
  5. Sep 27, 2021 at 6:02 PM
    #485
    YEABOY
    YEABOY [OP] Well-Known Member
    I got one out of a wrecked truck from Bruce's in Richmond when this happen. Truck still running the roads under new ownership.
  6. Aug 29, 2022 at 3:03 PM
    #486
    Rmass
    Rmass New Member
