Secondary Air Pump / taking it apart / $1400 / If you own a Tacoma you should read this..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YEABOY, Sep 6, 2016.
  1. Sep 7, 2016 at 4:43 PM
    #81
    Team Flatline
    Team Flatline Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    If memory serves me correctly, that is just to keep large objects out of the pump. If you look to the lower left in thet photo, that is the pump and you have to remove the screw in the middle to access the culprit foam which is what everyone is removing. Then rplace that large cap like piece you asked about with the filter that was Amazon linked.
    ruffridha9 and Nessmuk like this.
  2. Sep 7, 2016 at 4:50 PM
    #82
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That is for the tundra. 10 years or 150k miles. I have no idea why the tundra gets a warrantee, but the Tacoma doesn't. It's the exact same system
  3. Sep 7, 2016 at 5:16 PM
    #83
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Dumb question, but does the ECU need to sense a certain flow volume from the pump? If not, can we just wire in a random, similar size air pump?
  4. Sep 7, 2016 at 5:27 PM
    #84
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pop that off as well as open up the top of the pump and remove the original foam filter.
  5. Sep 7, 2016 at 5:53 PM
    #85
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    ordering that filter now.
  6. Sep 7, 2016 at 6:08 PM
    #86
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    ^^^what he said
  7. Sep 7, 2016 at 6:19 PM
    #87
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I'm holding off, until my emissions warranty has expired. Don't want to do anything to jeopardize warranty coverage.
  8. Sep 7, 2016 at 6:22 PM
    #88
    ramonortiz55
    Ramon
    Texas
    stock
    you can always keep the parts and pop them back in place if there is an issue
    tomwil[QUOTED] likes this.
  9. Sep 7, 2016 at 6:41 PM
    #89
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I picked up the new version of the Hewitt Tech bypass and the pump replacement pack for my '12 and got rid of the pump all together. Used that newly founded room for a second battery.
    ruffridha9 and slcsez2000 like this.
  10. Sep 7, 2016 at 6:46 PM
    #90
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    I might use the pump replacement pack too down the road
  11. Sep 7, 2016 at 6:52 PM
    #91
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This, exactly. There is no filter in that stove inlet piece. The chunk of foam filter is inside the lid, under a single screw, as described above.
    Just inspected mine -- foam filter chunk is intact and soft/pliable, no debris or foam bits inside the check valve, all good. Will re-check every 2 years. May be relevant to note that my truck has been garaged most of its life and has it pretty easy in general.
    Here are pics... First pic is the main air pump housing, after removing the single screw and cover; second pic is the inside of the cover with foam filter block; the last one shows the foam a little better. The light-colored square shape on the side of the foam is what the filter trapped, looks like fuzz or hair and a little dust and dirt. Nothing noteworthy, and pretty clean for 10 years old. I really like the crankcase breather mod but I'm leaving the foam for now. It's super easy to check and mine is doing great.
    AZ_Charles and IronPeak like this.
  12. Sep 7, 2016 at 6:57 PM
    #92
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Where is this filter located?
  13. Sep 7, 2016 at 7:00 PM
    #93
    ramonortiz55
    Ramon
    Texas
    stock
    if you read the next few posts after, itll tell you everything. I just asked the same thing :)
  14. Sep 7, 2016 at 7:00 PM
    #94
    DGXR
    Friend
    Sacramento, CA
    The air pump is mounted to the fender well, under the hood, directly in front of the airbox (2.7L engines)
    See my post directly above yours, with 3 pictures.
    utetaco and ruffridha9 like this.
  15. Sep 7, 2016 at 7:02 PM
    #95
    ARB1977
    North Texas
    Mines a 4.0L. Are the pumps the same?
  16. Sep 7, 2016 at 7:04 PM
    #96
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    The 4.0 has the pump behind the air box on the passenger side against the fender.
  17. Sep 7, 2016 at 8:07 PM
    #97
    nd4spdbh
    SoCal
    This, I kept the original foam piece as well as the end cap of the inlet pipe that blocks big pieces entering. Everything can be returned back to stock without issue. Dont wait on this, people are not getting this stuff easily replaced under emissions warranty.
  18. Sep 8, 2016 at 2:45 PM
    #98
    Chephie
    Chephie Well-Known Member
    Chad
    Ohio
    2012 MGM DCSB TRD OR
    OME884/5100's Wheelers Progressive AAL LR UCA's 265/75/16 Duratrac Method NV wheels Color matched grille surround ImMrYo rear view mirror relocation bracket Avid slider/steps
    Ordered it today as well...2012 with 72k, I suppose I'm on borrowed time at this point.
  19. Sep 8, 2016 at 4:50 PM
    #99
    kukimonsta
    kukimonsta Well-Known Member
    G
    Alameda, CA
    2012 SSM DCSB TRD OR
    Ordered too...have almost 100k on my 2012...i'm really on borrowed time :fingerscrossed:
  20. Sep 9, 2016 at 6:00 PM
    #100
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Only 40,000 on the clock, but I've got one on the way as well.
