Secondary Air Pump / taking it apart / $1400 / If you own a Tacoma you should read this..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YEABOY, Sep 6, 2016.
  1. Sep 9, 2016 at 6:23 PM
    #101
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Has anyone actually had a air pump failure from this filter? Its a good idea but most the issues I see are stuck valves with only fix to replace. Need to figure out a way to evacuate the moisture in our systems and maybe extend valve life.
  2. Sep 9, 2016 at 6:27 PM
    #102
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've been wondering this as well.
    The stuck valves send you into limp mode, bad valves just give you a CEL.
    I'm more interested in valve maintenance.
  3. Sep 10, 2016 at 9:05 AM
    #103
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I just opened up mine, foam looks good, and clean, but only 40,000 on the clock. I did see little pellets in the bottom, before the foam, that looks like tiny rat turds. Wasn't foam, crumbled when ground between fingers, looks like the factory had bugs in everything. I have that external filter on the way. My cousin has a 2014 DCSB Sport with no issues at 70,000+ miles.
  4. Sep 10, 2016 at 9:47 AM
    #104
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Toyota and all manufacturers have therefore been lazy since the 1970s. Smog pumps were present on the 2F starting in 1975. The engine doesn't run dirty per-say, air injection just dilutes the exhaust to meet arbitrary tailpipe standards. Toyota implements it because they designed an engine that met 2005 rules but by 2012 the rules had tightened so they do this as an alternative to a new engine. I don't think the 2GR-FKS needs it but may at some point in the future and apparently to meet Federal rules in 2008 it wasn't necessary since my Tacoma does not have this air pump. Maybe the OP's truck is a California spec? I dunno if that was still being done back then, but my '78 FJ40 and '91 Pickup both were Federal models and had different outfits compared to CA models.
    From an engineering perspective it's probably better to have one engine configuration and ECU for all 1GR-FE, all models, all years, and patch on a system that lets it pass emissions specific to a year. The alternative would be a hardware and software control nightmare. It's easier for a person to pop the hood, see an air pump and know it's properly emissions spec'd for a model year and location. This is not unusual, some early cars had catalytic converters, some didn't (my 1978 FJ40 didn't need them), for example. It did have a smog pump, though, but back then it really was just a hack so it's not unusual to have a gutted air pump just to pass visual that doesn't do jack. As long as your truck is running well and passes the tailpipe sniffer the letter of the law is met even with a sham manifold injection system.
  5. Sep 10, 2016 at 1:12 PM
    #105
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I completed the filter mod on mine today. The foam was intact and had a small pine needles stuck to it. There's really nothing to keep the filter from being pulled into the fan blades of the pump if it begins to fall apart. Friction is all that holds it in place. The design could be improved if the filter were in the cap or tube with a press fit stainless steel screen behind it to prevent debris of any kind from getting into the blades. I stopped at my local Auto Zone and picked up a universal breather with a 1" tube and then used a 1" ID hose with two clamps to connect the two pieces together. The filter mentioned in above posts has the rubber tube molded on but I didn't want to wait for one and had time this weekend. This fix won't solve the moisture issue with the system but it will solve the foam failure problem which leads to broken blades on the pump.
    Casper66 likes this.
  6. Sep 10, 2016 at 4:44 PM
    #106
    YEABOY
    YEABOY [OP] Well-Known Member
    If you are referring to the filter which is addressed in this thread, that would be the exact reason multiple people here have cited for their pumps failure, including mine. (Am I missing something or did you not read anything on this lol??????)
  7. Sep 10, 2016 at 4:46 PM
    #107
    YEABOY
    As for an update, I found an 08 at a junk yard about 100 miles from me that still had the pump. With one year warranty it came to about $140. Much better than $1450 ish from the dealer. When the warranty runs out I will just take the foam filter out. I will probably take the worthless intake cover off and put on a breather like others have mentioned.
  8. Sep 12, 2016 at 9:51 AM
    #108
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Dilution with fresh air will certainly reduce the PPM counts. I also understand that air injection helps the catalytic converter in its function to incinerate everything into oblivion. In other words, any unburned fuel in the exhaust will be burned in the cat(s) but that secondary burn (in the cat) requires additional oxygen.
  9. Sep 12, 2016 at 11:58 AM
    #109
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    ^^ Exactly. The pump injects extra air in order to bring the cat converter up to temperature much faster, as well as burn off unburned fuel from the ultra rich cold start A/F mixture.
    Mine is still functioning after 102,000 miles and ten years, but this thread definitely makes me want to pull the foam filter and replace with the breather filter. Probably do it this weekend. Thanks OP for making this informative thread.
    PNW/TRD Steve likes this.
  10. Sep 12, 2016 at 1:28 PM
    #110
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    My 2012 has less than 50,000 miles and it started throwing multiple codes (P2440, P2442, P0418) all relating to the secondary air pump a few weeks ago. It only happens when the engine is cold and ambient air temp is below about 85F. Thanks to my UltraGauge Blue, I am able to read and clear the codes without going into limp mode. I will definitely be pulling it apart for inspection when I have time to do so.
  11. Sep 12, 2016 at 5:13 PM
    #111
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Sub'd this thread, sucks this pump can become an issue.
    Someone mentioned 13's function differently on shutdown as opposed to startup? I hear mine on my 13 run on startup
  12. Sep 12, 2016 at 5:33 PM
    #112
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    My 2015 Air pump went out at 7,800 miles. Toyota replaced under warranty. The pump goes on at start up and shut down.
    slcsez2000 likes this.
  13. Sep 12, 2016 at 5:47 PM
    #113
    Chephie
    Chephie Well-Known Member
    Chad
    Ohio
    2012 MGM DCSB TRD OR
    OME884/5100's Wheelers Progressive AAL LR UCA's 265/75/16 Duratrac Method NV wheels Color matched grille surround ImMrYo rear view mirror relocation bracket Avid slider/steps
    The pump on the 2012 only runs at cold start, 2013 and above runs both at start and shut down. I believe having the pump run at shut down was an attempt to correct the moisture issue and ultimate valve failure. At least that's my understanding...
    shakerhood likes this.
  14. Sep 12, 2016 at 7:55 PM
    #114
    kukimonsta
    kukimonsta Well-Known Member
    G
    Alameda, CA
    2012 SSM DCSB TRD OR
    Just did this simple mod. The foam was pretty clean for 100k miles. Mostly highway miles though so prob why it's semi clean.
  15. Sep 12, 2016 at 8:02 PM
    #115
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Sounds like you need this thread.
    The secondary injection valves (while related to the pump) are a whole different problem.
    https://www.tacomaworld.com/threads/secondary-air-injection-switching-valve.381997/
    Soul Surfer likes this.
  16. Sep 12, 2016 at 8:03 PM
    #116
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    Wow your engine bay looks spotless...no wonder it was so clean ;)
    kukimonsta[QUOTED] likes this.
  17. Sep 12, 2016 at 8:58 PM
    #117
    kukimonsta
    G
    Alameda, CA
    Bad habit from car show days. :rofl:
    Norton likes this.
  18. Sep 13, 2016 at 4:03 AM
    #118
    Scrubber3
    Scrubber3 Not really here
    2016 T4R XP 4X4 MS
    I wonder if the quality of gas (brand, not octane) has any effect on air pump failure rate. I see so many people talk about using high end synthetic oil with a great oil filter and how it'll prolong engine life.
    Using a good quality fuel is important as well. They are not all equal. Some foul more than others. Some have high water content. Some are just plain dirty. Ones like Shell, Mobil one, etc are found to run much cleaner.
    Those with air pump failures: realistically, where is your "go to" place for fuel?
    Those with higher mileage without failure?
    Also, location where these failures happen the most? Where is everyone having the most failures? Environmental effects on these must have some bearing on longevity of this part...
    kukimonsta likes this.
  19. Sep 13, 2016 at 6:52 AM
    #119
    kukimonsta
    G
    Alameda, CA
    I'm in NorCal with 99k miles and always used shell 91.
  20. Sep 13, 2016 at 7:06 AM
    #120
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If moisture is the big issue, I wonder how many people who wash their engines and/or do a lot of trailing through rivers/etc. are more susceptible to this device failing?
    In my area, you are allowed to clean the engine bay at the local do-it-yourself car wash. If I ever do that, you can bet I'm going to cover that corner of the engine bay.
    OP - thanks for taking the time.
