Secondary Air Pump ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lickskillet, Dec 28, 2020.
  1. Oct 7, 2021 at 1:22 PM
    daveleau
    daveleau Active Member
    2015 gunmetal gray Tacoma SR5
    3" lift, winch
    Marc70 likes this.
  2. Oct 7, 2021 at 1:25 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    This
    I replaced the foam filter with a Unifilter a while ago and my pump failed last year.
    The valve failed and was stuck open.
    Covered by the TSB.
    I changed back to the crappy foam filter when the truck was serviced....just in case.
    They installed a new crappy foam filter as part of the kit.
    Unifilter went back on when I got home
    Positraction likes this.
  3. Oct 7, 2021 at 1:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Will the HP tuner simulate a Secondary Air monitor running and passing? If the monitors aren't allowed to run it'll show up on a scan
  4. Oct 7, 2021 at 1:40 PM
    Bootselectric
    Bootselectric Well-Known Member
    Stirling
    2004 PreRunner (RIP) 2013 TRD Sport (DCSB-BRM)
    To date the 2012s are the only ones that Toyota is replacing. Is there any word on why 2012s and not 2013-15? If so, are we to be included at some point under the pump TSB?
    Kolter45 likes this.
  5. Oct 7, 2021 at 1:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's my understanding that the later air pumps will purge the moisture out by turning on for a quick second on shutdown. That way the moisture isn't hanging around in the system overnight and causing corrosion. 2015 does it, not sure about 13-14.
  6. Oct 7, 2021 at 1:47 PM
    Bootselectric
    Stirling
    Interesting, my 2013 makes a wheezing sound upon shut off, I figure this is what you’re talking about, but my father’s 2012 does as well.
  7. Oct 7, 2021 at 3:07 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    daveleau[QUOTED] likes this.
  8. Oct 7, 2021 at 7:36 PM
    Pearson
    Pearson Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    Search YouTube for TacomaHolic smog pump mod. Be careful of the Diameter of the uni filter you order. There are a few links for Amazon filter offerings. The K&N there does not have a flange for a clamp so you would need to place a zip tie stop around the barrel to set the depth of the filter to keep it from accidentally closing off the available flow.
    https://www.amazon.com/dp/B003CJOTSA
    I should add that my OEM filter was somewhat worn but was like in 80% condition. As I understand it, the fear is the possible damage that might occur if the filter medium were to be sucked back into the engine etc.
  9. Oct 8, 2021 at 5:34 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I can't definitively say yes or no. But I would assume the answer would be yes that it simulates it whether or not it is installed. The reason I say that is when I installed the tune the system still functions as normal. Later when I got around to removing the system there were no changes in start-up, driving characteristics, fuel economy or anything noticeable except the annoying noises were no longer there. Again, this is not gospel. @nd4spdbh could probably answer that better as he has worked a lot with the HPTuner tuning development from the start.
  10. Oct 8, 2021 at 5:43 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Yep...'13+ rigs have an air dump that dries the reed valves off when the ignition is shutoff.
    BTW....6.5 years old and my foam filter is still pliable and looks new
    JGO likes this.
  11. Oct 26, 2021 at 3:45 PM
    mose1117
    mose1117 Well-Known Member
    Sacramento,CA
    2015 DCSB TRD SPORT
    Mine does this sound as well. Have only had the truck for a couple months. Is this thing that culprit?
  12. Oct 26, 2021 at 5:08 PM
    Bootselectric
    Stirling
    I believe so and it’s normal for our trucks, part of the purging moisture process. I was just wondering why the 12s qualify for a secondary air pump replacement and not 13-15. My father’s 12 purges same as my 13.
  13. Oct 26, 2021 at 5:18 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Modifications made for off-road use to bypass the system will show in a scan. However, most states allow for one NOT READY code in 2002 and later vehicles. In 2001 prior OBD equipped equipped most are allowed two NOT READY codes. Can’t speak the specifics of the Hewitt system but HPT tune NOT complete and successful READY code for Secondary Air Injection. You can still tune out the system for full deletion and retain all driveability to avoid limp mode and avoid a CEL or MIL lights.
    TacoFergie[QUOTED] likes this.
  14. Oct 27, 2021 at 4:53 PM
    Taco'09
    Taco'09 Well-Known Member
    I can confirm that the '14 also does it.
    That said, I still got a carbon-clogged reed valve and it sent me into limp mode way out in the middle of nowhere with low miles on my truck.
  15. Oct 29, 2021 at 8:18 AM
    #35
    TacoFergie
    Iowa
    The system will run after shut down, that is normal and annoying. It will also run longer on start-up the colder it is. In my case when it's below 0F it will run for 2-3 times longer. Basically it is trying to add more oxygen to the exhaust to make the cats warm up faster to burn the extra fuel that is required on cold start so it is more emissions friendly.
    zippsub9 likes this.
  16. Oct 29, 2021 at 8:21 AM
    #36
    TacoFergie
    Iowa
    That's good to know!! Not that it's an issue for me but for future reference. It makes sense with how you explain it. Now I want to hook up a scan tool to see what it shows, not that I'm doubting you, I just have an inquisitive mind.
  17. Oct 29, 2021 at 8:25 AM
    #37
    zippsub9
    Halfmoon, NY
    14 DCLB
    Turning CEL and MIL is fairly elementary for most tuning applications but READY codes are where are easily read with just about any scan tool and require a full vehicle DRIVE cycle (specified different per each manufacturer) to complete in order to reset each and all of these READY codes once a malfunction is fixed or corrected. This prevented folks from pulling up the gas station, unhooking a battery then getting there vehicle inspected or just shutting off lights. Cats, Secondary Air Injection, Fuel Tank Purge System, Upstream O2 Sensors are just some of the READY code categories. I believe there are eight total.
  18. Jun 7, 2022 at 7:56 AM
    #38
    hewitt-tech
    hewitt-tech Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    My understanding is that most tuners can stop the CEL from coming on by removing the code but the system won't be able to complete and show ready.
    This is where our GenII bypass kits are a better solution. They emulate the system so the ECM thinks the system is still there and running like it is supposed to.
    No messing around in the ECM and it will actually let the monitor run and show complete even if you were to take the air pumps off and toss them in the trash.
    https://hewitt-tech.com/product/secondary-air-injection-system-bypass-kit-gen-2-plug-play/
  19. Jun 7, 2022 at 8:04 AM
    #39
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    My 13 does this. I’ve had the uni mod for years. On my 2nd uni filter. A few years ago we had brutal wildfire ash & that was when I just bought another & kept the old one as a back up.
    Save the oem foam filter & the cap. If it ever fails, put them back on before taking it to a dealer when you ask them to pay for it. ESP if you have a 2012.
    First 2 years I drove with the plastic lid off but I put it back on.
  20. Jun 7, 2022 at 8:10 AM
    #40
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    New 2013 owner here. I checked my filter before buying the truck to see the condition; it wasn't brittle at all. Mine makes the purging sound on start up and shut down. I've considered the uni-mod just as an extra precaution, is it necessary to do this on the "updated" pump? I know it doesn't cost much to do.
