Secondary Cat delete
Discussion in 'Performance and Tuning' started by BenJammn5, Nov 15, 2010.
  1. Nov 15, 2010 at 9:25 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Obviously living in California, and been thinking about removing the 2nd set of cats. I know, the 02 sensor is in front so shouldn't throw a code, but the question- would I still pass smog?
    thanks dudes
  2. Nov 15, 2010 at 9:27 PM
    dustin81
    dustin81 DUSTOFF
    Rio Rancho, NM
    09 TaCo Lifted TRD
    PRO COMP 6" Lift Stage II PRO COMP 2.75" Coilovers PRO COMP MX-6 shocks PRO COMP skid plate Bushwacker Fender Flares Smittybuilt Chrome Steps KC Chrome 6" SLIMLITES Billet Custom Grill JDM window vent visors Window Tint Flowmaster TRD CAI
    would you gain HP
  3. Nov 15, 2010 at 9:31 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Jose
    doubt I would feel a difference in throttle response, more after the noise.
  4. Nov 15, 2010 at 9:34 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You will be louder. You will most likely also not pass smog... I have my rear cats deleted. But I have other things done as well to my system. The rear cats are like an equivalent of a 3" glasspack, if you cared to know that haha
  5. Nov 15, 2010 at 9:38 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Jose
    Hmmm... I really wonder if I wouldn't pass smog, no sensors in there. Okay, if all fails I'll just delete the muffler(I know I know, 'back pressure man, you'll lose all your torque!')
    3" glass, so they're straight through with perforated padding or something surrounding?
  6. Nov 15, 2010 at 9:52 PM
    memario1214
    Colton
    Missoula, MT
    1. I really don't know what goes into passing smog because I don't have it here in MT. Don't they check your emissions with some sort of sensor? The rear cats burn that extra unburned fuel before it leaves the tailpipe.
    2. Do not just delete your muffler. Your truck will sound like the most pissed off lawn mower ever! I played around a bit when I was redoing my truck and when I cut out the muffler... No good. Put in some kind of muffler one way or another. Also, backpressure anymore doesn't really have any effect on anything. You will lose a little torque, but it is negligible
    3. The rear cats are just sound equivalents of a 3" glasspack roughly. It is essentially just a hollow metal tube with tight metal mesh in it that gets really hot and burns any fuel still in the line. I recall some kind of perforation inside when I cut mine apart, but exactly what it looks like is escaping me.
  7. Nov 15, 2010 at 10:09 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Jose
    Thanks Colton, I just repped you.
    Agreed on #2, and honestly I wouldn't ditch the muffler, especially since I just bought it. I made the comment on the torque and backpressure cause I think it's over rated and misconstrued by most. The results are negligible no doubt.
    So that's what those secondary cats do, burn the extra fuel. Excellent info, now if anybody in California could chime in on this.
  8. Nov 15, 2010 at 10:11 PM
    memario1214
    Colton
    Missoula, MT
    Yeah sorry on that one man... If I knew what went into smog testing I may be able to help you out.
  9. Jun 15, 2013 at 8:21 PM
    Yota4me
    Yota4me Active Member
    USSA
    charocal filter delete/kn intake, rear cat delete. horn mod, 20% tint front windows, bull bar, M1 Full Syn, black plasti dip emblems. Next up aero turbine 2525xl muffler
    Do it
  10. Jun 15, 2013 at 8:39 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Open it up too much and u will notice the tq down low go bye bye.
    Over rated maybe sometimes........ but under rating it is a slap in the nutz, and wallet if u go overboard n/a
  11. Jun 17, 2013 at 6:47 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    "smog" depends on where you are at, here it TX it is basically an OBDII connection, no codes = pass. In this case removing the rear cats will still pass. In CA I have "heard" that they also do a visual, in which case you would fail.
  12. Jun 17, 2013 at 3:27 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    But are the second set really cats or just resonators? I have wondered this since day one.
    PK
  13. Jun 17, 2013 at 3:58 PM
    Fast_Freddy
    Fast_Freddy Well-Known Member
    99 Black PreRunner
    ome suspension lift, Borla catback exhaust, S-runner bucket seats
    Your car has to have ALL the emission components that came with it(or some CARB approved variation of it), stock. You cannot, however, permanently remove any emission component and still pass smog. Im a smog tech in cali.
  14. Jun 22, 2013 at 12:50 AM
    Dirtysouthmafia23
    Dirtysouthmafia23 Member
    Jake
    Pensacola, fl
    06 PreRunner SR5
    Blue strobe "cop lights" for now
    You said you didn't know how they check smog in California. Don't take my word for because I don't live in California but I thinks they put a sniffer in the tailpipe and check how much hydrocarbon (gasoline) nox and carbon monoxide gases are coming out of it. In my opinion I wouldn't do it because I hear California is strict on there emission laws.
  15. Jun 22, 2013 at 12:58 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Just put a cat on I mean your cats are mostly dead from taking all those poisonous gases for your truck
  16. Mar 5, 2014 at 7:25 PM
    TACO FOR LIFE
    TACO FOR LIFE Well-Known Member
    Seth
    texas
    07 PreRunner
    i know this thread is old but i hope ill get a reply. if i remove the back 2 cats i will NOT get a check engine light correct?
  17. Mar 5, 2014 at 7:25 PM
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
    also i'm not worried about smog or loss in low end torque
  18. Mar 5, 2014 at 7:31 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Correct. No check engine light.
  19. Mar 5, 2014 at 7:52 PM
    TACO FOR LIFE
    Seth
    texas
    07 PreRunner
    ok thanks
  20. Oct 21, 2019 at 9:38 PM
    PErsing
    PErsing Well-Known Member
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Caliraised 52" curved lightbar, Fox Shocks, TacomaBeast projector headlights
    Any thoughts on if this will result in more exhaust pops and crackles due to the secondary cats not being there to remove the last of the unburnt fuel? I have just a basic muffler delete, and you can make it crackle in 1st and 2nd when you let off the throttle between 2500-2750 rpms and feather the gas.
    This forum is only 5 years gone, psh.
    BassAckwards likes this.
