Secondary Fuel Filter
Discussion in 'Performance and Tuning' started by PMK, Jun 5, 2013.
  1. Jun 5, 2013 at 6:38 AM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    On the newer trucks, has anybody installed an inline fuel filter between the tank outlet and engine?
    I searched but came up with stuff for the older trucks or about the URD pump replacement.
    PK
  2. Jun 5, 2013 at 6:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. That is part of the fuel pump upgrade kits, from www.dezod.com or www.urdusa.com.
    It replaces the factory non serviceable filter, with a serviceable inline filter.
  3. Jun 5, 2013 at 10:16 AM
    PMK
    Florida
    10 DCLB TRD Sport
    I don't need a different fuel pump, rather just add a second filter.
    Does Gadget sell just a filter installation kit?
    PK
  4. Jun 5, 2013 at 10:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  5. Jun 5, 2013 at 10:56 AM
    PMK
    Florida
    10 DCLB TRD Sport
    I see your concern for the oem filter clogging. I was under the impression that was a pretty coarse filter, but honestly have never seen it.
    The URD filter looks like a typiical Ford filter.
    Seems the logical choice is to upgrade and sell the oem pump assembly.
    PK
  6. Jun 5, 2013 at 10:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
