Secondary / remote automatic transmission filter install
Discussion in 'Technical Chat' started by PMK, Apr 7, 2012.
  1. Apr 7, 2012 at 9:40 AM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Pretty straightforward. Used a Trandapt brand remote filter mount. Went with the typical TRD 4 liter engine oil filter. The filter assembly is mounted to the right side front suspension brace. Everything is well protected and there is no clearance issue with the sway bar at full extension.
    Scary part was how nasty looking the fluid was at 22000 miles. This mod will make a full tranny flush much easier by disconnecting the hose at the filter housing.
    PK
    crtx likes this.
  2. Apr 7, 2012 at 9:41 AM
    PMK
    Florida
    10 DCLB TRD Sport
    More photos
    PK
    crtx and Poncate like this.
  3. Apr 28, 2012 at 11:49 PM
    docjake
    docjake Well-Known Member
    Fredericksburg VA
    Does it have to be mounted that low? Seems like that filter is exposed to dam near anything on the road (or off).
    MTopp likes this.
  4. Apr 29, 2012 at 4:25 AM
    PMK
    Florida
    10 DCLB TRD Sport
    No it can be mounted anywhere you prefer that it fits. Merely a matter of getting longer hose to connect it.
    FWIW, you do realize the photos are taken with the skid plate removed. The piece it is mounted to is a frame support. The hose route is oem Toyota. While anything is possible, and this is not a race truck where it would be better higher and aft, along with the transmission cooler, if this location has the filter in trouble, the radiator and the transmission cooling lines are less protected.
    PK
  5. Apr 29, 2012 at 4:36 AM
    PMK
    Florida
    10 DCLB TRD Sport
    From what I read here, these transmissions do not have a fiberous filter to capture dirt. They do have a screen.
    One of the easiest cars to work on was a Mitsubishi I bought for my daughter. It had from oem a spin on transmission filter. Also, any industrial hydraulic systems and aircraft systems use fiberous filters.
    A few days ago, the truck had 22700 miles on it, no towing or hard driving. Changed the transmission fluid by using the flush method here. already the fluid was turning brownish. I installed this filter and drove a few hundred miles before changing the fluid. Time will tell if it's a good move, cost wise it was less than $50 to install the added filter.
    Fluid wise, I did some homework, and while not approved by Mobil, I went with Mobil 1 ATF. I compared spec sheets and MSDS of approved fluids to the Mobil 1. The truck shifts better and the gear selector is less notchty feeling.
    PK
  6. Apr 29, 2012 at 7:10 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    good job pmk,i like
  7. Apr 29, 2012 at 7:11 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Nice job, may do this when I do a flush.
  8. Apr 29, 2012 at 7:26 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    PMK,
    I like your idea. I think I will look into a possible mounting location in the engine compartment fender well. I would be able to use the lines going to an auxiallary transmission cooler as a way to hook the filter up. Do you know the Trans Adaptor model number that you used?
  9. Apr 29, 2012 at 7:41 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Is there any concern about drop in trany fluid pressure?
  10. May 1, 2012 at 4:29 PM
    PMK
    Florida
    10 DCLB TRD Sport
    As for the Transdapt part number, no I don't know the exact PN. You should get one with the 3/4" thread size for the filter. The threaded ports were fairly large, I believe 1/2 NPT. I may change to a smaller ports size like 3/8 or even 1/4 NPT.
    Transdapt makes remote oil filter adapters as do other companies. I went into the parts store inquiring about ordering one. The manager says we have an entire small block Chevy oil filter relocation kit. Originally this kit was probably $50, he says, how about $15 and it can be good for both of us. Done.
    I picked up the hose & fittings at a local hydraulic shop. I used oem hose clamps from Toyota.
    Yes this can or could be installed in conjunction with an aftermarket trans cooler. My prerunner came from Toyota with a towing package which included a transmission cooler.
    As I mentioned, I also switched over from Toyota WS fluid to Mobil 1 ATF. The truck drives no different.
    I did setup the Scangage II using the codes from the Scangage website. I did find additional codes on TW. Currently the Scangage is showing the trans fluid temp in the pan and the torque converter fluid temp.
    As for the question about a pressure drop in the transmission, the oem cooler and this added filter are in the fluid return line back to the pan. That circuit is after the work has been accomplished, therefore pressure should be virtually none. Adding the filter may have raised it slightly.
    PK
  11. Dec 16, 2012 at 5:03 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    PMK, with the filter relocation does the screen internally that the truck comes with require service still?
  12. Dec 17, 2012 at 3:37 PM
    PMK
    Florida
    10 DCLB TRD Sport
    In theory no. The filter is capturing all the returned fluid that ultimately ends up in the pan.
    The oem filter then is there for any failures where parts fall into the pan or maybe a careless filling will introduce stuff.
    PK
  13. Jul 21, 2017 at 2:41 PM
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Saved to be used as my guide when i get all my needed parts :)
