"secret" settings screen, anything useful in there?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorrinRadd, Jun 2, 2020.
  1. Jun 2, 2020 at 5:18 PM
    NorrinRadd
    NorrinRadd [OP] Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    To get in you turn on the ignition, turn your headlight switch fully off then on one click, then after your HU screen has settled down press the Home button and then press-and-hold-in the Audio button and while pressing on the Audio button on the screen turn your headlight switch forward two clicks and back one click, three times, so you are cycling between the 2nd and 3rd options on your headlight switcher on the steering column. Remember to keep the on-screen Audio button pressed!
    If done correctly your HU will go into a secret settings screen that apparently allows the 2020's to change their onscreen truck color, among other things. Has anyone found anything useful in these screens for the 2019's by chance? Or perhaps there are other such secret screens to investigate?
    I did this on my 2019 with the non-JBL audio unit, so don't know if the JBL or aftermarket HU will work.
    Kev250R and HoboDave like this.
  2. Jun 2, 2020 at 5:27 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Jun 2, 2020 at 5:28 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I did it on my 2018, there is nothing good in there for us :(
  4. Jun 2, 2020 at 5:31 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Daisy dukes and Dr. Marten's to complete the look? Can't go around looking half assed.
    StayinStock likes this.
  5. Jun 2, 2020 at 5:34 PM
    Bishop84
    Bishop84 Well-Known Member
    There's nothing in there, it helps with GPS diag and screen touch spots, but that's all I use it for.
    Kev250R and StayinStock like this.
  6. Jun 2, 2020 at 5:35 PM
    My Name is Rahl
    I can change my screen color without all the broohaha.
    I wanna know how you found out about this combination of switches and buttons.
  7. Jun 2, 2020 at 5:36 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I went into those settings and changed my stock tune to a Yaris tune, rides much better
  8. Jun 2, 2020 at 5:40 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Did it right after I bought mine. Only diagnostic info in the 2019.
  9. Jun 2, 2020 at 5:41 PM
    Bishop84
    Toyotas entune have used this method since they came out. (2007ish I think?) I just hold audio and flick the lights, I don't even look it up anymore.
  10. Jun 2, 2020 at 6:28 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    @Hobbs
    Is this true?
    Canufixit and Hobbs like this.
  11. Jun 2, 2020 at 6:33 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Whaaa...?
  12. Jun 2, 2020 at 6:39 PM
    Hobbs
    Yep…
    What just happened ????? :notsure::notsure::notsure::notsure::notsure:
    Malvolio and StayinStock[QUOTED] like this.
  13. Jun 2, 2020 at 6:40 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Wut?
    Hobbs[QUOTED] likes this.
  14. Jun 2, 2020 at 6:40 PM
    Hobbs
    Yep…
    You didn't... did you??
    StayinStock[QUOTED] likes this.
  15. Jun 2, 2020 at 6:42 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I did because I thought you did!
  16. Jun 2, 2020 at 6:45 PM
    Hobbs
    Yep…
  17. Jun 2, 2020 at 6:46 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    how’d you get that image? That’s the same look I get whenever I say hello to a woman
  18. Jun 2, 2020 at 6:47 PM
    Hobbs
    Yep…
    Perhaps you should say it to a man.
  19. Jun 2, 2020 at 6:47 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Hobbs[QUOTED] and jmauvais like this.
  20. Jun 2, 2020 at 6:48 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :bananadead:
